3-point capacity
/ 3-point capacity #1
ajamison
Charlottesville, VA
none
I have a Truax II88 no-till grass drill, which weighs about 2800 lbs. I'm looking to buy a tractor big enough to mount the drill via the 3 point hitch (makes moving it a lot easier).
There a lot of 60-70hp 4Wd tractors I've seen that could pull it very easily (like a New Holland TT75A), but they have 3 point hitch capacities of 3300 lbs or so. Is that cutting it too close w/ something big and bulky like the drill, esp w/ over rough ground w/ a lot of banging, etc when the drill would be lifted up?
Is it necessary to step up to a heavier tractor with 5000 lbs 3 point lift capacity or would tractors rated for around 3500 lbs be ok? Not sure how much wiggle room there is with those figures.
/ 3-point capacity #2
Ajamison
Why not just move it with the front end loader. you may be able to stay with a smaller HP tractor and save some money.
If this is the only reason you want the tractor and not to actually use it on the three point.
Just asking
/ 3-point capacity #3
You need to know what the total weight of the the drill full of seed is and the approximate loacation of the drill center of gravity(cg). Then you can compare that to the lift capability of the three point. Three point hitches are rated at two locations: at the end of the lift links, and with the load cg located 24 inches aft of the lift links. So you need to pay attention to what number you are qouted. The lift at 24 inches behind the links will always be less then the lift at the links. You can correct one to the other very easily if you can have the correct location for the rating.
If you all ready have the drill, find out what it really weighs when it's full of seed and ready to go. See if the manufacturer can tell you where the cg is located.. The measure the length of the lift link (L) and the distance from the lift links to the drill cg (a). If the spec lift is X pounds at the lift links, and Y is the max weight of the loaded drill, then
X *L = Z*(L+a) or,
Z=(X*L)/(L+a). If Z > Y, the lift will pick up the max weight of loaded drill.
Remember that once you start runing the drill, the load goes down and the drill gets easier to pick up as it's weight decreases.
You lift system has a position control and a relief valve so driving on rough ground with the drill raised may cause some high intertia loads on the lift system and the relif valve will respond by relieving pressure to prevent damage and then the position control will reset the height of the implement. If the ground is really rough, you want to not be highballing in high gear with a heavy weight on the three poinnt, however. Thats' just common sense.
This is the long way around to answering your question.
/ 3-point capacity #4
Ajamison
Just asking
I dont know about you, but I have NEVER seen a tractor that has a FEL capacity greater than the 3PH.
So if he is wanting the "smallest" tractor to lift it VIA the 3PH, a tractor smaller than that certainly wouldnt move it with the FEL.
Ajamisin: I cant answer your question directly because I dont own tractors that big, but here is my take:
Personally I would want a larger tractor. Even though a 3PH rated @ 3300 will lift it, I dont like pushing capacitys to the limits on a regular basis. Just asking for problems sooner rather than later. And you also have to think about keeping the front end down, and how far back it hangs off the tractor.
I dont know all of the other brands, but the smallest kubota I'd consider is the M8540 w/a 4600lb capacity @ 24" and an optioal 7200lb capacity. With a total tractor weight of 5000-5400 lbs.
For deere...the 5065M and 5075M's have a optional 3PH capacity of 4600lbs @ 24"
And for NH...it looks like the T5000 series.
And you could also consider something like the kioti DK75
But again, I dont have a ton of experience with these larger machines. So I am sure others will chime in with better advise
/ 3-point capacity #5
As mentioned, what is the weight of the drill when it is full of seed? And then you need to consider the center of gravity issue, compared to the typical 2 foot behind most tractor manufaturers figure for their weight ratings?
I'd not want to cut it too close - add some mud weight - sure we want to only farm in the best conditions, but someday you'll have a couple lbs of mud on each disk blade - it adds up.
--->Paul
/ 3-point capacity #6
A kubota M59 FEL would handle the drill easy. And the rear lift and front are about the same on that tractor. You could remove back hoe and use 3 point to pull around with power to spare. No problem.
/ 3-point capacity #7
Ok after looking at what this drill is you are not going to put in the bucket and move it around. ( sorry ) . But the one I googled has wheels on it and would not know why you need to lift it of the ground to move it. And it did not look like it was 3 point ready but draw bar instead.
Unless they make a different Modle then I seen your going to need a 60 to 80 horse tractor to handle it safely in my opinion . Good luck.
/ 3-point capacity #8
I didn't look through the whole 160+ page manual on line, but:
They sure look like they could be 3pt from the layout of them, but they only talk about setting up with a drawbar hitch which they say all models come with..... Then later in the specs at the end, they mention a 3pt model. So obviously somewhere you can get it or use it as a 3pt model.
The II-88 is listed as 3000# with the notill option. You can hold up to 2.3 bu of seed per foot of width depending on box options. It is 5.6 feet long, not sure where that puts the center of the weight, but likely more than 2 feet beyond the tractor 3pt arms. They suggest at least a 60 hp tractor with front weights - of course that will depend on the 3pt lift which is what you are asking about.....
--->Paul
/ 3-point capacity
That what's I've been thinking. There is a used CASE IH JX75 I might look at, which is more along the lines of some of the models you mentioned.
/ 3-point capacity
--->Paul
Right. I currently use it with the drawbar, and a smaller 40 hp tractor that I rent. But I plant at a lot of different sites, so for the sake of moving equipment more easliy, I want to take the tongue off of the drill, hook the drill it to a tractor via a 3 point hitch, and then move both together on one trailer from job to job. I have used them hooked up this way, and they still plant fine.
/ 3-point capacity #11
It appears that most of the finer points have already been covered in response to your question. I only wish to suggest this additional concern. If you use the FEL, it would be advisable to have sufficient rear ballast weight to compensate for the weight up front. Just a thought.
/ 3-point capacity #12
Yes, the FEL and 3PH capacities are the same on that machine....But that aint no ordianry tractor. That is a Backhoe with a super strong FEL with a 3PH as an option on that machine. But neither the FEL or 3PH have a sufficient enough rating lift the drill with any level of comfort at all.
"Most" farm tractors have about double the capacity out back vs the FEL
/ 3-point capacity
X *L = Z*(L+a) or,
Jerry, thanks for all the great information. If I follow you calculations correctly, then if (a) is less than 24", then whatever the manufacturer quotes as the rear lift capacity at 24" is the figure I can use in determining whether or not it will pick up the drill. If (a) is greater than 24", than I need to go through your calculations. Is that right?
/ 3-point capacity #14
Find a good used JD 4020, they can handle the weight, plenty of power, and reasonable priced.
/ 3-point capacity #15
Not necessarily.
Those "would" be the correct calculations if it were a simple lever.
BUT....the 3PH is a parallelogram linkage. Which means the capacity doesnt diminish that much.
In that "simple lever formula" if you lower links are 24" long, that would be @ 24" behind the ends, you would have 1/2 the rated capacity. And that simply isnt the case. Because "IF" it were a simple lever, that point @ 24" would raise 2x's higher than the "ball ends", and it does NOT because of the parallelogram.
I will note that it is NOT a perfect parallelogram. BUT it is an adjustable parallelogram. Most tractors have several mounting locations for the toplink and the toplink length is also adjustable. Adjusting those two things changes the geometry. The lower hole will cause the implement to rotate about the lower links MORE, causing the point @ 24" back to raise HIGHER than if the top hole were selected. THUS changing the lifting capacity by simply mounting the TL differently. Same goes for its length.
What you should take away from this is that there is no easy way to calculate the lift capacity. All tractors have different geometries to their 3PH's and different ranges in which they can be adjusted. So dont cut yourself that close on capacity. Because if you select one that is right on the bubble, doing something as simple as adjusting the TL to gain a little more height and you might not be able to lift it.
/ 3-point capacity
One more question. How much does the weight of the tractor factor into 3 point capacity?
I'm looking at a Kubota M7040 which has the same lift capacity as a MF 375 (I know someone who has a Truax drill attached to the MF 375 and it works well), but the Massey weighs almost 2000 lbs more.
/ 3-point capacity #17
Additional weight (depends on how it is distributed) helps keep the front end of the tractor on the ground:thumbsup:
If you are going to be using the 3PH at more than about 50% of its rated capacity, some additional front end weight is almost required. Especially with the newer and lighter tractors of today.
My tractor has a 2000lb capacity @ the pins and a 1500lb capacity @ 24", and with either the 700lb blade or 1000lb bushhog...The front end is TOO light without the FEL to work safely on anything but perfectally level ground.
And not to nit-pick, but I dont know where the rating for the 375 is taken. Tractor data lists it @ 4200lbs. The 7040 is 4200 @ ends and 3300 @ 24". So if the older 375 is 4200 @ 24", that is a pretty big difference?? But again I dont know where it is rated.
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2014 Ram 1500 4x4...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
SD Lanch SDLGC80 Electric Golf Cart (A62177)
SD Lanch SDLGC80...
2012 Peerless CH-43-2A T/A High Rate Magnetic Frac Blender Trailer (A60352)
2012 Peerless...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2020 CATERPILLAR 304E2 CR EXCAVATOR (A62129)
2020 CATERPILLAR...
