Tires Narrower tires on 5105m
/ Narrower tires on 5105m #1
Jdmano
Everson, wa
5105m
Some relatives of mine just purchased a 5105m tractor to use in there raspberry fields. To fit down the rows properly we need it narrower than the rear fenders. We installed 9.5-24 goodyear duratorques for front wheels. Jd says to install 14.9-28 on rear. Did that and it dropped the drawbar 6 inches. Which was too much. Talked to salesman and he said we could install 14.9-30 on the rears which would be same rolling circumferance as 16.9- 28 which is a drawbar height we like. Recieved and mounted 14.9-30 tires and it raises the drawbar only 2 inches. And when measured to the 16.9-28 is the inches shorter. Can anyone explain how this works and what size tire will give us the same height as a 16.9-28.
/ Narrower tires on 5105m #2
How narrow do you want to go? I have 12.4R42s on my 5420 and 5310 with 11.2R24s on the front.
/ Narrower tires on 5105m #3
You should be running at least 30-38's on that tractor. Tell your dealer to install the 38 Firestone radials on your tractor.
Id like to stay with a 14.9 width it fits nicely under the fender. How tall is your tires the 14.9-30s were about 53 inches tall and the 16.9-28s were about 57.
/ Narrower tires on 5105m #5
I would say get 15.5R38s or something like 14.9R34/38 but I'm not sure if 14.9R34 or R38 is a common size.
2010 DMI 3200 Fertilizer Applicator (A63116)
2010 DMI 3200...
2018 CATERPILLAR 320 EXCAVATOR (A62129)
2018 CATERPILLAR...
2014 John Deere 6125R Tractor (A64047)
2014 John Deere...
2012 Peterbilt Semi (A64047)
2012 Peterbilt...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2011 WESTERNSTAR 4900SA (A63569)
2011 WESTERNSTAR...
