Tires Narrower tires on 5105m
/ Narrower tires on 5105m #1
Jdmano
Everson, wa
5105m
Some relatives of mine just purchased a 5105m tractor to use in there raspberry fields. To fit down the rows properly we need it narrower than the rear fenders. We installed 9.5-24 goodyear duratorques for front wheels. Jd says to install 14.9-28 on rear. Did that and it dropped the drawbar 6 inches. Which was too much. Talked to salesman and he said we could install 14.9-30 on the rears which would be same rolling circumferance as 16.9- 28 which is a drawbar height we like. Recieved and mounted 14.9-30 tires and it raises the drawbar only 2 inches. And when measured to the 16.9-28 is the inches shorter. Can anyone explain how this works and what size tire will give us the same height as a 16.9-28.
/ Narrower tires on 5105m #2
How narrow do you want to go? I have 12.4R42s on my 5420 and 5310 with 11.2R24s on the front.
/ Narrower tires on 5105m #3
You should be running at least 30-38's on that tractor. Tell your dealer to install the 38 Firestone radials on your tractor.
Id like to stay with a 14.9 width it fits nicely under the fender. How tall is your tires the 14.9-30s were about 53 inches tall and the 16.9-28s were about 57.
/ Narrower tires on 5105m #5
I would say get 15.5R38s or something like 14.9R34/38 but I'm not sure if 14.9R34 or R38 is a common size.
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2017 TAKEUCHI TB290 EXCAVATOR (A64279)
2017 TAKEUCHI...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
EZ Trail 3400 (A63118)
