OBD2 Scanner
/ OBD2 Scanner #41
I've seen some ads for ODBII dongles that attach to the normal ODBII port, and then broadcast using Bluetooth to a smartphone, which uses a cheap or free app to display and control the dongle.
The dongles cost anywhere from $25 to maybe $90 or so, I think (haven't researched these much).
Does anyone have any experience with this setup? Basically, re-using the smartphone to get UI.
Obviously, not the setup for a pro, but for those of us who need the occasional code reset or lookup, there's some appeal.
-Rick
/ OBD2 Scanner #42
I have one that I use with my laptop. Nice to not need a wire going across the car. Have heard good things about the Torque app for Android.
Aaron Z
/ OBD2 Scanner #43
-Rick
I have the Garmin ecoroute that will xmit via bt to your smartphone or to a Garmin GPS. Works OK but i wish it would work with other software, but because they use a proprietary protocol it can't. Still the Garmin Mechanic app is pretty good, the ecoroute is overpriced for what you get. If i had not received it as a gift i would have looked at palmer performance products.
/ OBD2 Scanner #44
Just wondering what folks are buying for OBD2 scanners now days? I had always just ran to Auto Zone and gotten a code read if need on my stuff but to be honest its been 2 years since I had a problem and that was on my Saturns Neutral Safety Switch and that car has now been sold and totaled by the new owner.
Anyway, I have had the need for one twice in the last 2 weeks. Once on my BIL's truck to clear a code that we allowed to happen by driving it with a Fuel Injector unplugged and another on my neighbors wifes car after it failed to start due to cold temps.
I do not want to spend a fortune but I want a unit that will allow me to read codes, clear them, and read live data such as water temp, RPM, speed, oil press, ect. HF has a unit for $59 that will do all this plus I have a 20% off coupon.
I looked into the lap top based units but most do not work with Windows 7 which is what I have.:confused:
Chris
I bought a ScanGauge II for ~$150 nearly 10 years ago.
OK, not a good deal TODAY (Moore's Law) but at the time having an extra 4 gauges (selectable from a menu of a dozen or so) the ability to scan and reset was a good deal.
If/when I want another one I will check into their offerings, though a blue-tooth one that will communicate with my GPS seems attractive.
I don't need it, I have better spending opportunities for the money, I don't need...
(write it out long hand 500 times)
/ OBD2 Scanner #45
not answering the original question.. just a followup on a previous OBD post I had made.
I got an obd scan tool from a buddy.. new, in box/zipper bag.. never even put a battery in it. was a harbor freight model.. one of the 'more expensive' chinese ones ( :) )
so far I've used the heck out of it. neat lil tool.
now that all my friends know I have a scan tool, they hit me up weekloy to use it ontheir vehicle.. :)
I see HF now has much cheaper 20$ units that run off vehile power. etc..
the one I got has a cdrom and a usb cable for i guess doing reports or printouts..e tc.. i've never used that part.. just the scan tool...
160 GALLON FUEL TANK (A64281)
160 GALLON FUEL...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
UNUSED AGT MX-MRW14 STAND-ON SKID STEER (A64280)
UNUSED AGT...
2014 Ford F-150 Pickup Truck (A61573)
2014 Ford F-150...
LOT LOCATIONS (A59914)
2023 CATERPILLAR 299D3 XE SKID STEER (A62129)
2023 CATERPILLAR...
