question about hydraulic valves
/ question about hydraulic valves #21
/ question about hydraulic valves #23
Thats right. No, I want to make ik by myself.
Wilco.
It'll be hard and complicated job, don't you think so? Not only the hydraulically but mechanically as well. Before that you could compare what might be the financial difference between if you would trade this tractor and obtain another with a factory FEL and if you'll make a FEL yourself. And finally you'll probably sell a 3ph bucket, which will not be needed anymore. There are many aspects to be taken into account: tractor capability, loading capacity, subframe strength, hydraulic pressure to be enough, bucket size, safety ... It means you will need lots of calculations.
Or you can search for a similar but factory FEL to be adopted to your tractor.
Concerning me, I'm using a 3ph bucket. Meanwhile it's enough for me. If the great demand for the FEL will come on, I'll probably better change a tractor into another one with a FEL or will purchase a complete FEL designed for my tractor. Everything is possible, but in my case it's very expensive to make a FEL.
I'm sorry, I don't want to reduce your resolution, but I'd better think twice before entering such a serious project. :)
I still want to do it by myself :) I've been calculating and I can make it halve the price of a factory one.
I don't think hat i would sell the 3pt bucket, because the 3pt is stronger than the fel, I don't want to use it for heavy things.
And also the mechanical things would not be an issue, because that is what I learn for, and always do.
Wilco.
/ question about hydraulic valves #25
Wilco.
I appreciate your optimism. :thumbsup:
It's not me who should tell you what you must do. And OK, if you have mechanical skills, than I have nothing to add except to wish you a good luck. Hope soon to see some pics of your project.
Thanks, it can take some time because I firsth ave to save some money.. :2cents::2cents:
/ question about hydraulic valves #30
I believe it stands for Top Link and Tilt - a hydraulic top link and side arm tilt on your 3 point hitch. The hydraulic top link lets you change the angle of your whole implement front to back and the tilt cylinder for one of the side arms lets you change the side to side vertical angle (tilt).
Ken
Ken
Thank yoy for the information.
You've also a nice site with some interesting pics.
Wilco.
Hello,
I've been thinking, and can I put it together this way?
/ question about hydraulic valves #35
If your new valve had a PB port, you would not need the ball valve.
With a normal FEL valve with PB, and no lever activated, the fluid just flows through all valves and then to tank. Flow path = pump to FEL valve, out of FEL PB port to 3pt. Return hose to tank
You can activate any valve and have flow to that circuit just by moving the lever.
If you have a 10 GPM flow and the FEL is only using about 5 GPM, then the other 5 GPM is available for the 3pt.
Yes, your ball valve would work as long as you did not shut off the hyd flow. If you deadhead the pump, it may burst. You could put a relief valve in front of the ball valve.
This valve is what you need.
http://www.surpluscenter.com/item.asp?item=9-7863&catname=hydraulic
http://www.surpluscenter.com/Instruct/I9-7863.pdf
@J_J
Yes, I should do it that way, but i cant find any online shop here who sells anything like that for not ridiculous high prices.
I would do what you say, and put a relief valve before the ball valve.
When i'm done i will post some pic's of it.
Thank you.
Wilco.
/ question about hydraulic valves #37
Where you show a 3-way ball valve should be a single selector valve like this:
Surplus Center - 1/2" NPT 20 GPM PRINCE SELECTOR VALVE
It is designed for that function and will not have a dead zone.
You really will be better off with a single multi-spool valve that has power beyond. Take your time and shop around for a good price. You won't need it until your loader is complete. When you break it up into multiple low priced valves the cost for extra hoses and fittings will usually eat up any savings in valve prices. Put together a complete bill of materials to compare options and you will see what I mean.
I've removed my side fender to see what's possible.
at my first glance I saw that a ball valve is impossible right next to the pump, and i don't see a place where I could it else so I should buy a valve with PB.
here are 2 pictures of how it is.
the flexible hose is the prssure line, at the bottem of the pump. at the top of the pump is a hard line and thats the suction line. There is a rubber tube on it, probably a leak of the previous owner.
on the second pucture you can see it with the protection before it.
/ question about hydraulic valves #39
You would be wise to get the valve with PB and install it and run the return port to tank, and Install the PB plug to connect all the hydraulics.
If you don't have the loader yet, just plug the work ports.
With everything connected, you should have pump to IN port of FEL, FEL PB OUT to IN port of remote valve, and out of remote valve PB to 3pt IN port.
All returns hoses go to tank.
If you don't have remotes, or will not use one, the PB from the FEL goes to the 3pt.
You could also put QD's in the work ports of the FEL, and just plug in the hoses when you get the loader.
Once the loader is connected, check and adjust the FEL relief and set it to about 50 to 100 below the pumps max pressure.
To know the pump pressure, should I tee in a gage to the in port of the valve?
Wilco.
HAMM H11 PADFOOT ROLLER (A58214)
HAMM H11 PADFOOT...
2006 Ford F-650 S/A Dump Truck (A61568)
2006 Ford F-650...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2010 Volkswagen GTI Passenger Car, VIN # WVWFV7AJ7AW231214 (A61569)
2010 Volkswagen...
2025 Heavy Duty Booster Cables (A61568)
2025 Heavy Duty...
2011 Ford F-350 Service Truck, VIN # 1FDRF3GT8BEA38908 (A61165)
2011 Ford F-350...
