Block heater for Beaver
/ Block heater for Beaver #1
blackforestbeaver
Satoh Beaver S-370
I have had a Beaver since it was new with a block heater installed by the dealer (long gone), and it burned out recently. I had it replaced by the local Kubota dealer twice, and each time it burned out within a few weeks. Is there a specific type or make of heater that is required for the Satoh?
Thanks for any help.
/ Block heater for Beaver #2
Not to my knowledge. I also had mine go last year and man was it cold out.
Mine simply died from old age and the new one is fine.
Generally as long as it is immersed in coolant it won't burn out.
Could you have low coolant? bad pump?
Is it mounted low on the block in a frost plug hole or is it a hose type heater.
/ Block heater for Beaver #3
I had a series of bad ones for mine. I forget what diameter they are, 40mm maybe? The one in there now heats just fine but I start noticing a bit of a coolant leak through it (I think) when it's in use.
I don't use it much, haven't in a couple of winters as the tractor is now my secondary machine, I haven't used it since before Christmas.
The coolant level is good. Don't know about the water pump although it hasn't overheated. It's a block heater located down behind the starter in a freeze plug hole. Maybe they are made in China now.
Do you know what brand the bad ones were?
/ Block heater for Beaver #6
I've picked them up from a number of sources, at least one came from NAPA. Sticks in my brain that the brands of some were a good name but of course I cannot call it to mind at the moment.
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
iDrive TDS-2010H...
2008 DRAGON KILL TRAILER (A65643)
2008 DRAGON KILL...
2018 Land Rover 4WD SUV (A61574)
2018 Land Rover...
LOAD OUT AND SHIPPING (A65563)
LOAD OUT AND...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
