Tire Repair Options
/ Tire Repair Options #1
CanuckGT
Dino Valley,Ab Canada
Kioti CK30 HST
Cleaned up a pile of garbage,house reno material,etc last fall, lots of nails ,etc.
Thought I made it without a puncture but I see my front right tire has a slow leak now.
So, never repaired a tractor tire before but do have plugs for my quad tires and was wondering if this would be a good way to fix a flat? Or do I have to remove it and take it in to a tire shop to get a patch on it?
/ Tire Repair Options #2
The best way is to have it patched. You could use your plugs but they aren't as strong of a repair but may last until the tire wears out.
/ Tire Repair Options #3
Slime it!!!:eek:
/ Tire Repair Options #4
I plug mine, and there are two in one tire and one in another...zero problems. I have also probably plugged two dozen tires and only had one that would not seal because the hole was too big even after doubling up on plugs. If your tires are filled just make sure you roll the nail to the top before the repair, or fluid will run out making a mess.
Murph have you had luck with slime? It's never worked worth a hoot for me, tried it twice, still got flats so I gave up on the stuff.
/ Tire Repair Options #5
Plugs are a temp fix, good for a few months. You can reign but I would patch.
/ Tire Repair Options #6
I've had good luck with Slime in little, thin lawn tractor tires. I think the actual punctures were made by multiple perforations from thorns so the holes were pretty small and leaks were slow. But I think a real tractor tire would require a huge amount of slime and that would only work for very small leaks in unfilled tires.
Given the difficulty of patching a tractor tire, I'd be inclined to plug it and patch it later if the plug failed. Particularly so if the tire was filled with liquid. Just my opinion.
/ Tire Repair Options #7
If it is only a nail or screw just plug it!
/ Tire Repair Options #8
I would take the tire to a tire shop and have it patched. A properly applied patch has the best chance of being trouble free. The slime may work but if it doesn't, you probably won't be very welcome at the tire shop.
All of this of course is just my opinion.
/ Tire Repair Options #9
You are going to get a zillion replys about Slime. I would take it to a tractor dealer and have it repaired.
/ Tire Repair Options #10
Realistically, plugged(if done correctly) is as good as, if not better than "patched at the tire shop".
Thanks guys! After closer inspection it appears to have a plug in it already (not the same spot) so plug it is!
/ Tire Repair Options #13
I put 3 holes in the same front tire in the same week, never punctured a tire before or since, go figure. Plugged each one and haven't had an issue since. Cheap and easy, good choice.
/ Tire Repair Options #14
They say "things happen in threes"
/ Tire Repair Options #15
Plugs here. They've been in for years.
I also had a slow leak in a very worn front tire and added slime. The leak stopped. Not sure where the leak was, there are some deep cracks and gouges.
/ Tire Repair Options #16
I got tired of plugs leaking in my front tires and had tubes put in. $25/piece. No more leaks.
/ Tire Repair Options #17
Tube is what my Kioti dealer put into my front tire; said he couldn't plug it.
Hey Murphy, See you are facing forward now!:thumbsup::D
/ Tire Repair Options #18
Fixed numerous ones on my vehicles, no leaks. One on my front from sapling puncture on my Kioti, no leaks. I say plug.
eddie
2014 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2014 Caterpillar...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
More info coming soon (A61574)
More info coming...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
2024 POLARIS GENERAL XP1000 RTV (A64278)
2024 POLARIS...
Swict 72in Bucket Skid Steer Attachment (A64553)
Swict 72in Bucket...
