Tire Repair Options
   / Tire Repair Options
Thanks guys! After closer inspection it appears to have a plug in it already (not the same spot) so plug it is!
   / Tire Repair Options #13
I put 3 holes in the same front tire in the same week, never punctured a tire before or since, go figure. Plugged each one and haven't had an issue since. Cheap and easy, good choice.
   / Tire Repair Options #14
They say "things happen in threes"
   / Tire Repair Options #15
Plugs here. They've been in for years.
I also had a slow leak in a very worn front tire and added slime. The leak stopped. Not sure where the leak was, there are some deep cracks and gouges.
   / Tire Repair Options #16
I got tired of plugs leaking in my front tires and had tubes put in. $25/piece. No more leaks.
   / Tire Repair Options #17
Tube is what my Kioti dealer put into my front tire; said he couldn't plug it.
Hey Murphy, See you are facing forward now!:thumbsup::D
   / Tire Repair Options #18
Fixed numerous ones on my vehicles, no leaks. One on my front from sapling puncture on my Kioti, no leaks. I say plug.
eddie
2018 KUBOTA SVL75-3 SKID STEER (A52709)
2018 KUBOTA...
2016 Ford F-150 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
CASE INTERNATIONAL 183 4R DANISH TINE CULTIVATOR (A52708)
CASE INTERNATIONAL...
John Deere 1025R (A53317)
John Deere 1025R...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56436)
LMC 2-Row Planter...
