wcampbell47
I'll throw it out there since I didn't see it mentioned yet. If you can afford it - even if you don't think you need it - consider a model with a backhoe. Based on the description of the property, it sounds like sooner or later you'll wish you had it. Then add the three point hitch as an option.
Austin - from what you have described I think you will be doing a lot more with the 3 point attachments first than you will be digging with a back hoe. Bush hogging, tilling a garden, etc. You could buy several 3 point implements for what one back hoe will cost.
