M62 TLB for Maintaining Hilly Land ?
   / M62 TLB for Maintaining Hilly Land ? #51
I suspect that a lot of compact & utility suburban tractor dealers don't employ a real mechanic. About the farthest they go in the mechanical direction is to have someone who can guess at a problem and change parts. Their "mechanics" uncrate new machines, service them, do routine maintenance by the book, and bolt on accessory kits. It's "cookbook". You can do as much or as little of that for yourself as you wish.
And honestly, that's about all the level of competence you should ever need. The "parts swapping" approach to being a mechanic works fine during a warranty. And after using a warranty period to expose any manufacturing flaws, the machine should be reliable for many years. In fact, most are. So in spite of us old guys grousing about the lack of real mechanics these days, the new approach has advantages.
If you are curious about old fashioned real mechanics, here is a hint: You can often spot a real mechanical shop because they will have a specialized shop truck & offer mobile service. The construction dealer where I go to get parts and chat about our full size TLB has a whole shop full of real mechanics and several trucks. My favorite mobile mechanic was a helicopter mechanic in Afganistan..... 'nuff said.
But now you have me curious. I used to have a mechanical shop. And you've said before that dealer "A" is one that you like.
Since apparently they don't know their products, and their mechanics are limited to maintenance, then just what is it about that dealership that is so attractive?
As a confession - I've always been a Deere guy and my Deere dealer that is about a half mile from Dealer "A". The Deere dealer does have an excellent service department and the service manager is top notch. However, today's Deere, like most other stuff, is not the same Deere of yester-year.
My limited interaction with Dealer "A" has been on implements. I think they know the tractor line which is their normal inventory. They aren't the used car type of sales force and everyone I've dealt with has been very helpful. That and the location is very convenient.
   / M62 TLB for Maintaining Hilly Land ? #53
Well me too on JD. When my wife said it was new tractor time, I just naturally figured it would be a Green Machine. And I love that color... but persimmon?? Is that a color or a tree? The year was 2008, we had honestly never set foot in a Kubota shop. When my wife saw the off-orange color she started laughing.
The day before we had almost bought a new JD110 TLB which was about 2/3 of the M59 in price and ability. A JD110 is similar to a Kubota L39
In retrospect the JD110 would have been a mistake, but they are a JD and they sure are cute. I wish JD had continued with the small TLBs. By now I'm sure they would have gotten the bugs out.
If your JD service manager is that approachable, he would probably be a good one to ask about the Kubota service dept. Alternately, you might ask the Kubota guys who they call on when they have something serious like a warranty job needing a transmission swap. My guess is they have someone - maybe semi-retired - that they use.
Unless abused, tractors don't require much. I've used the Kubota service dept exactly once in 16 years. They replaced a hydraulic cylinder under warranty. Their mechanic didn't even take the threaded end off the cylinder to tighten the nut causing the problem. Just bolted on a new cylinder - two bolts, connect two hoses, and done in half an hour. They scrapped the old one. That cylinder today is $3425.71.
rScotty
   / M62 TLB for Maintaining Hilly Land ? #54
So I went to my local Kubota dealer yesterday to see if they had a M62 I could look at or if they were getting any in. Asked the counter guy, and thought I was speaking Greek for a minute. Another guy walked up and said he wasn't sure they could sell them. They are not a construction dealer. He checked and they can order them. He said they could maintain it as well. I like the dealership "A" but buying a M62 from them didn't give me the warm and fuzzies since they don't appear to have any experience with them. Am I just being paranoid?
If they service a Lot of Grand L and M series tractors, should be ok. The frame and hydraulics are what sets the TLBs apart. The rest is nothing special.
   / M62 TLB for Maintaining Hilly Land ? #55
Had Ford 4500 backhoe for over twenty years. 2wd. Very tippy on our hillside farm but proved just how handy a backhoe was. So much improved over ag tractor backhoes.
Had the M59 for years before finding an backhoe attachment. Pleasantly surprised how stable the M59 was with the backhoe. Still have to carefully, constantly swinging the boom when traveling or loader work on slopes. Comfortable to control. Good power and controls for a compact machine.
Not the machine for large excavation jobs but more than capable for owner, farm and construction. Footers, septic, road, ponds, creeks, trees, etc. Compact size more valuable than larger capacity for our use.
Was concerned how well the HST plus M59 could handle chores like bushhogging or road grading compared to my previous geared tractors. It’s performed well and is even better in tight, highly maneuverable areas. If I was doing as much hay harvesting as in the past it wouldn’t be my first choice. Buying and feeding out hay would be fine. I our situation our equipment may see several operators with varying skills. The HST adds a significant factor of ease and safety.
The M62 is a 60 HP tractor with ~45hp pto. I know the lower pto numbers are because of the extra hp for the backhoe's hydraulics. Does the drive-line also take a hit on hp. At 10,000 lbs, it's going to need some horses to climb a 30-40% long slope (with the BH attached) at anything other than a crawl.
I've got a grapple and 4-N-1 bucket for my JD 4710 that will stay at the house property. Not sure if I can or want to swap back and forth between the tractors.
This is the unapproved wish list:
M62 with Loader and BH w/ aux valves
Tires: R4 (bit worried about the traction)
Hydraulics: Top-N-Tilt, Rear Remote valve kit
3-P: really hope I can find telescoping 3-point arms and sway bars
Loader Buckets: 84" HD round back & 4-N-1 & Grapple
Backhoe: Rubber Stabilizer flip pads
Backhoe Buckets: QA's 18" w/ teeth, 36" smooth ditching, ripper
BH thumb
Rear wheel weights
2" rear wheel spacers if available
Aux work lights
Telematics?
Thoughts?
   / M62 TLB for Maintaining Hilly Land ? #57
Lot of stuff! Quite a package!
Need to improve front grill for grapple work.
Wouldn’t go over 6’ with your grapple or 4 in 1 bucket.
Some have had better reliability from Fit-Rite or other auxiliary hydraulic valves over OEM.
Kubota Soft Ride available?
WSM, filters and oil.
   / M62 TLB for Maintaining Hilly Land ? #58
Wow, it must be nice to win the lottery. On the other hand, how often do you get a chance to buy a new tractor set up with everything?
You do realize that the basic tractor with far less extras will do 99% of everything? It would be fun to see what a BASIC list of extras would look like. Just so you know, everything on SmokeyDog's list would make my list of basics. Particularly a seat upgrade. I'd add a cheater for the SSQA, a tarp, and a spinner knob.
I don't quite follow your thinking on the engine HP vs PTO HP. But for what it is worth, here is the way I see it; tell me if this sounds reasonable.
Engine HP is an advertising spec. Good for beer bets. Basically it is a bare engine back in in the lab on a stand without any parasitic losses - it may not even have to run a fan or water pump... all that is done for it. By doing some indirect measurement - like fuel consuption vs BTU out - a geek comes up with a nice unverifiable HP number. Nobody I know is going to take their engine out and measure HP that way. In fact, there probably isn't any way to hook up to that engine to measure HP directly...
The adverting dept. is free to use whatever Engine HP number they feel their geek can justify.
PTO HP is a whole different animal. PTO HP is verifiable by any mechanic in most full size tractor dealerships. They use the number for warranty claims. The dealer may not routinely measured his compact tractors, but they probably can. You can probably pay to have yours measured next time you are in there.
A PTO dynamometer that reads out in HP is a basic piece of diagnostic equipment that it is hard to do without for Ag tractors - there is really no other way to check if a tractor is making proper power. So it's a common tool in any large tractor dealership. Having a PTO shaft makes a dynamometer check quick and easy to do for any size tractor with a PTO.
The shop manual has a number for PTO power and your tractor should darn sure match that spec.
On going up hills... Most tractors I know won't pull top gear to full RPM on even a slight grade. Our big tractor won't do that and the M59 sure won't. Anything over 2% and I don't even bother to try. And ours is at least a ton lighter than what you are proposing. Now it will pull top gear on a smooth flat road, but not at any grade. Luckily the M59/62 with HST plus has six speeds. You'll find one it will pull.
rScotty
Thanks for the suggestions. Didn't see a soft ride or a grill guard listed as options. If I'm able to pull the trigger on a new machine, hope I find grill guard like you've got.
I had very limited time last year and spent most of it working on my tractor. No desire to start off a new tractor experience having to add valves.
rScotty
May not be able to afford the unit - remains to be seen. Last tractor I bought was in 2006 and the next one I buy will probably be the last.
Just wondered if the M59/M62 drive-line felt under-powered as a tractor since it weighed so much.
Cheater for the SSQA?
Wheel weights is the only extra weight and that would be instead of filled tires.
skeleton / rock bucket (A56857)
skeleton / rock...
1288 (A58374)
1288 (A58374)
2008 Ford F-450 Crew Cab Utility Flatbed Truck (A55973)
2008 Ford F-450...
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
12V Diesel Fuel Transfer Pump (New/Unused) (A59225)
12V Diesel Fuel...
