M62 TLB for Maintaining Hilly Land ?
   / M62 TLB for Maintaining Hilly Land ? #101
I use my L45 all over the side of the hills at my place, creek banks too. removing the backhoe and adding the 3 point takes about 15 minutes, once you get a system down not much to it. I would love to swap it out for a M62 just so I could move bigger rocks but the price of those nowadays is inhibiting that.
Some advantages of buying new. Don’t think you will come close to wearing one out. Up at Johnson City Tennessee a couple of weeks ago and noted Mason’s had several used M62s. At least one M59. Popular machines for hillside work.
While the M62 does have some improvements, the pre tierIV emissions of the M59 has considerable advantages for me puttering around on my hillside farm.
Kubota is going to require a down payment for the 0% option which impacts the buy new value for me. If I've got to pull money out for a down payment, I might as well pull a little more and buy used.
Do you have an opinion you'd be willing to share on Mason's?
Assume the L48 would be a bit more nimble but the M62's extra grunt would be valuable too.
   / M62 TLB for Maintaining Hilly Land ? #104
I don't know if I'd swap a good L45 for a newer larger tractor just to get more complex emissions control and the longer reach. There are a lot of advantages to that L45. It has the HST Plus tranny - which IMHO is worth more than another ten HP. The L45 overall weight is within a thousand pounds of the M59, and the L45 carries its weight weight down lower.
As for grunt, the FEL will lift more than you probably should be carrying just as is. It's got a nicer 3pt, too. I can barely lift the heavy Cat. II 3pt arms for the M59.
No, I'm not trading our M59 for anything anytime soon, but the Kubota TLB line is so good that every size has advantages. If I was in the market for a utility size TLB, I'd just get the next really good one that came my way. Regardless of size.
   / M62 TLB for Maintaining Hilly Land ? #105
They have been in business a long time. Large tractor and construction equipment dealer. Seems like they to deal with higher end used equipment which tend to have higher prices. Have talked with them on equipment, shopped their lot but have never bought anything from them. Haven’t heard any complaints. They are about 90miles from me.
Buying used is work and usually who can have their money ready first. Almost all my farm and construction equipment was purchased used. Grew up doing this. More confidence with older stuff than new.
   / M62 TLB for Maintaining Hilly Land ? #106
Well said, Smokey. I certainly couldn't say it any better than that. Buying used gives a person the ability to buy better quality equipment with proven performance and at much lower prices - low enough to stay out of much debt, and that's huge.
Used things can't hide what their strong and weak features are. So a buyer gets to know in advance what part of the design is good, and what will need attention. New ones are a mystery that way.
Most people do take care of their tools and don't use them to full capacity. I will say that construction machinery may be one of the exceptions. The Kubota TLB was one of the few things we've ever bought new.
It used to be that new models featured improvements. Today, I see a lot of new models that feature a lower cost of production as though that was an advantage. When times change, buyers need to change too.
   / M62 TLB for Maintaining Hilly Land ? #107
Here was my solution, you will need wheel weights and the backhoe attached, but this will get you half way between a stock L45 and an M62.
Upsized Hydraulic Clyinders for Loaders
The loader is still fast enough.
I do not recommend cranking up the Hydraulic Pressure beyond 3,100 Psi, and even doing this is only good for +5% additional lift capacity. Stock main pump pressure is 2,900 to 2,950. You should check to see that your hydraulic are running at least rated capacity.
Had some illness in the family and it derailed my equipment quest for a time but I'm considering again.
Are you referring the new M62's improvements as being downgrades or just products in general .
   / M62 TLB for Maintaining Hilly Land ? #109
It was just a general comment. Nothing specific on the M62. As near as I can tell, the M59 and M62 are not all that different in large features..... other than the M62 adding the emissions controls and another two feet to the hoe.
Lower cost of production can also be a good thing when a manufacturer builds on a successful platform. That helps in similar models. The problem from any buyer's viewpoint is finding clues to just how new and old models really differ. Especially in small things.
When I wrote the original post, I had just been tracing the internal circuits on a diagram of the new M62 backhoe hydraulic control valve array. For the record, I'm impressed at the new M62 control valve design. It looks like it does the same job but is a lot less expensive and complex than the old M59 backhoe valve array. I'd say that's a good sign.
BTW, on another subject entirely - we were discussing tractors and hillside work earlier in this thread. And then last week before crossing a dirt hillside I just sort of automatically picked up a log with backhoe bucket+thumb & held it a few feet to the high side to help balance the tractor on the slope that I knew was coming up. Doing that reminded me of some of our conversations about backhoes and slopes.
rScotty
   / M62 TLB for Maintaining Hilly Land ? #110
Back on the original track, a few days ago I had to use my M62 to move a stack of steel pallets that in a former life held Kubota RTVs during shipping. Got a couple dozen of 'em free from the dealer. Got 'em home and stacked them easily using a box blade and about 400 pounds of railroad track on the back for ballast. The spot I picked had a mild side slope, but I didn't have any issues with tipping moving six or eight pallets at a time. This time, though, almost as soon as I lifted six pallets, the uphill front wheel started coming up off the ground. Instead of the weighted box blade on the back was a five foot Bushhog. Much lighter. I had to do the job two pallets at a time, and move very slowly and carefully to keep that wheel down on the ground, especially for the pallets on top of the six foot high pile. Also note that I'd installed six inch wide spacers under each rear wheel. So anytime you're working high with loads on the FEL, that tractor is gonna get tippy on a side hill. Even a very small side hill, like six inches of rise over eight feet.
If I had it to do over again, I'd have tried to find a skid steer track loader that could accept 3PH implements, even if it meant using a wonky SSQA arrangement on the front, just for the added stability on side hills.
2014 Freightliner M2 106 AWD Altec DM48BTR Insulated Digger Derrick Truck (A55973)
2014 Freightliner...
Mini -Excavator Heavy Duty Rock Ripper (New/Unused) (A59225)
Mini -Excavator...
2013 JLG 8K TELEHANDLER (A58214)
2013 JLG 8K...
Water Line Hose (A59076)
Water Line Hose...
2004 Ford Explorer Sport Trac Pickup Truck (A56858)
2004 Ford Explorer...
2023 Chevrolet Tahoe SUV (A56859)
2023 Chevrolet...
