Which QuicK Hitch do you guys prefer??
/ Which QuicK Hitch do you guys prefer?? #41
:thumbsup::thumbsup:
The problem I see with people and their QH's is they cheap out and buy the low grade hitch and then get peeved when things don't work. The JD iMatch is nice but an adjustable top hook is a must IMHO. That is why I recommend the Landpride. Top quality with adjustments. I haven't found an attachment yet that it will not work on.:thumbsup:
No need for a adjustable top hook if your attachments are to Cat 1 specs. If they are not I would rather modify attachments than fuss with adjusting the top hook. Takes the quick out of the quick hitch. :laughing:
Yeah I agree about the cheap hitches. I saw one at TSC that looked like it was welded by a child. I think it was made in china so it probably was. :( What get's me is it was over $200!!! :confused2: An American made JD iMatch can be had for around $280 if you haggle. :laughing:
/ Which QuicK Hitch do you guys prefer?? #42
Not all attachments modify easily but changing the top link is a matter of pulling 2 pins moving link replacing pins. 5 secs. tops.
I have tried the Pat's way and they are still hanging on a hook in the shed. Anybody wants them I will give a smokin deal. :D
/ Which QuicK Hitch do you guys prefer?? #43
I have Never used a quick hitch. If I buy the cheapo H.P. do you have to change the pins on your implements? Confused:confused: Thanks for the help.
/ Which QuicK Hitch do you guys prefer?? #44
and does anybody have a current H.F. coupon for one?:cool: I just printed the one posted until I notice it exp.
/ Which QuicK Hitch do you guys prefer?? #45
mst likley not if implement similar catagory ie cat 1 pins on implement and cat 1quick hitch most problems will be top link connection
/ Which QuicK Hitch do you guys prefer?? #46
I didnt have to change a thing when I bought my QH from HF. Funny thing is I havent seen coupon for HF QH for a long time now.
/ Which QuicK Hitch do you guys prefer?? #47
I got a Landpride QH cat 1 and love it built like a tank and even though this is my first tractor that I OWN ,( grew up driving them on farm) other than being a little pricey I think it was money well spent!!This day and time you get what you pay for:thumbsup:
/ Which QuicK Hitch do you guys prefer?? #48
hf comes in two widths, mine took the 27-1/2---be sure you get the right one if you go this route- i really like mine'
/ Which QuicK Hitch do you guys prefer?? #49
/ Which QuicK Hitch do you guys prefer?? #50
Harbor Freight QH
Thanks to a forum member I got a 40% of coupon on a HF QH. When I called HF they said they had them when I arrived they could not find them. On my third visit they found them. When I finally got home I found the bolts that hold and adjust the top hook vertically on the QH ran into the vertical frame on my rake, BS, & blade, preventing the hook from engaging. Some mod or alternative pin arrangement would be required
On two attachments the BS & RC the hook gap was narrow to engage the top link pin. It appears designed to engage a type two hitch pin (1.125"). These fixed top pins were 1.25" on my equipment. One was welded in place the other appeared to fitted into the support struts and held in place with a large .75" bolt.
On the box scraper the hook was an eighth of an inch to wide (or the attachment to narrow) to enter and engage the top pin.
The rotary cutter top engagement point was higher than the others, although this could be modified if I could do fabrication. Or I would need to adjust the Top hook vertically on the QH.
As I believe noted else where on the forum the type one bottom pins need to be shimmed up to type two size (.75" to 1.125") to fit the QH.
Lastly the tow hitch with cross bar I have will not work at all (at least without a lot of welding).
So in the end I had a list of at least 3 mods to the QH and 3 or 4 to the attachments. So I chose to return it as I figured I would not have time to do all the fixes and would end up removing the QH to hook up at least one or two attachments.
Please don't take this as a gripe or complaint. If I had a heated garage and a little more time I would have enjoyed making the mods and having a QH for the most often used attachments. . I'm mainly kind of documenting my experience I hope
Update I ordered Pat's today after reading this and another forum.
Thank you
/ Which QuicK Hitch do you guys prefer?? #51
My Pat's shipped out of KY Monday . The freight is terrific value for
22lb of metal . USD65 USPS air mail and trackable ; don't know how the US
does it. It would cost USD178 to return it from here !
/ Which QuicK Hitch do you guys prefer?? #52
Harbor Freight QH
Thank you
Yep, back on the first page of this thread I related all these problems and the fixes with the HF QH. I did all the fixes myself and figured I was money ahead when considering the freight + the price of the more expensive brands. Mine now fits everything and use it all the time. Sure saves grubbing around on the ground every time I hook and unhook (I do it a lot) plus the great time saving.
Ron
/ Which QuicK Hitch do you guys prefer?? #54
I purchased the one from TSC, also came with the top link adaptor. HF by far has the cheapest price though for sure.
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
28in Forks and Frame Mini Skid Steer Attachment (A61572)
28in Forks and...
2019 MACK ANTHEM 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 MACK ANTHEM...
PIXALL 36" X 5' CLEATED / INCLINED BELTED CONVEYOR (A63291)
PIXALL 36" X 5'...
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
Caterpillar 814/815/816F Landfill Compactor Service and Parts Manuals (A63117)
Caterpillar...
