meat smoker
/ meat smoker #42
Not really sure you're supposed to be eating them... :eek:
Then what are angel food cakes made from?
I wonder if "Angel" has to be declared on the label.
/ meat smoker #43
Had another thought... May our collective assumption that we're talking about angel people is incorrect.
Is this what a smoked steak tastes like?....
/ meat smoker #44
I dont eat cake but I cook biscuits and sausage all the time on my Traeger and my wife has made bread on it and its excellent. I know folks that swear by pizza on a smoker too. :thumbsup:
/ meat smoker #45
I've had pizza in a wood fired oven, and that's incredible. I've also had pizza from a coal oven. It's different. I think it's an acquired taste.
/ meat smoker
i talked to the tank experts that clean them..He said i have nothing to worry about.the tanks are spray lined with glass epoxy that will take the heat with no fumes or toxics..He said he wouldn't use a fuel tank that some people use.He said they have to wear masks when they clean them because of the fumes....I think I'll just do four or five burns and then throw a rack of ribs on to try:thumbsup::licking:
/ meat smoker
well i really dont trust this coating..I spent a $100.00 trying to sand blast this stuff out but it would blast out.Tried hitting it with a grinder,still wouldnt come out .Im cutting my losses and cutting the tank off and going to build one out of an air compresser tank.This tank is 1/4 inch thick and cleaned up really nice...
/ meat smoker
I went to the barnyard smoke house restaurant last night for some of their blueberry beer and steak cooked in the smoker.wow good flavour..cant wait to get mine going:thumbsup:
/ meat smoker #49
I realize it's a done deal now, but would that coating have burned out?
/ meat smoker
I tryed burning with a wood fire in it..Didnt work thats why i sent it to the sandblaster.Stopped blasting after 100.00 worth of sand.thats why i started building one with a compresser tank
/ meat smoker #51
I built one out of a commercial beverage cooler. Just a big refridgerator. I used a $10.00 electric hot plate with a cast iron pot and apple chips. Not fast enough recovery, gotta do better. I have a separate fire box a friend built for me. Will probably use that at some point. Right now will probably build a lp burner. I used some of that 90 degree angle sheet metal for side racks, attached with tek screws. I can put standard oven racks on them. I smoked some polish sausage over Thanksgiving, hung on 3/4" oak dowels placed on the racks. I used aluminum c-channel from Lowes, made to put on the edge of 3/4" plywood to keep the dowels from rolling. Pics tonight.
/ meat smoker #52
My smoker. Used it over Thanksgiving. More work to do. Will add another level of angle iron for a water pan. Also a bigger burner.
/ meat smoker #53
I remodeled my 125 Traeger a couple years ago for competition and catering. It just wasn't big enough and I didn't have the room in my garage for 2 and didn't want to spend the money on another grill to have enough cooking space.
BBQ folks are in general an innovative bunch when it comes down to smoking meat.
/ meat smoker
well i finally finished building one i can use..I used 100 gal compresser tank and a 100 gal propane tank cut in half for the fire box..Its a reverse flow..When I did the first burn I had temp as high as 400 F and holding with drafts wide open..Going to cook some ribs this week end
/ meat smoker
I forgot to add the tanks are 1/4 " thick..need to put some more paint on to make it pretty....:laughing:
/ meat smoker #56
Looks great the pics are a bit small to get the whole picture but from here it looks well done. :thumbsup:
/ meat smoker
ya sorry ..the pics are small because i took them with my black berry
/ meat smoker
wow used my new smoker today ...cooked ( smoked ) some ribs ..put a rub on them on them bought from sobeys grocery..They turned out great..What a flavour...wiil never go back to bbqing using propane
/ meat smoker #59
Hey good job, I have been doing hams and bacon for over 20 years. Unless you have a lot to smoke then any small time smoker will work just the same as making one, not many cents spent on a small Brinkman. I think my last one was less than 30 dollars. I built a small house smoker building, so unless I have less than 100lbs of meat I use the little smoker.:thumbsup:
/ meat smoker #60
Decided to break out the bbq in honor of a beautiful Spring day in Manitoba.
I'm cooking 2 racks of St. Louis ribs.
When buying ribs I encourage you to buy racks of similar size.
This means your cooking times will be similar.
I've got a greek rub on 1 rack, sweet chili and peppers on the other.
I prefer a dry rib.
A rookie mistake I've since corrected is saucing the ribs too early and often.
The sauce makes a sugary coating and does not allow proper heat thru the ribs.
I will cook them for roughly 4 hours (indirect heat) at 275-325 fahrenheit with a flip at the half way point.
Then bbq sauce and wrap them in tin foil and they sit for an hour.
I'm just over half way thru cooking.
Will post pics later.
2009 Generac SD060 75kVA Standby Diesel Generator (A66734)
2009 Generac SD060...
2013 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2013 ALLMAND...
Unused 2024 Land Pride PFL3048 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
2025 48in. Farm Jack (A66734)
2025 48in. Farm...
Unused 2023 Norden SQ90 Hydraulic Bale Squeeze Tractor Attachment (A66734)
Unused 2023 Norden...
2017 Crane Carrier Co. T/A New Way 31ASL Side Loader Garbage Truck (A66736)
2017 Crane Carrier...
