Tornado Shelter
/ Tornado Shelter #1
NoTrespassing
Elite Member
East Central Illinois
Kubota 1999 L3710 HST FWA
Hi All,
I've been living in a manufactured home for over ten years now. We have no basement and no safe place to take shelter during a storm here in central Illinois. I want to build a cheap effective tornado shelter. I have a bunch of large fence posts left over from a fence project along with a tractor and post hole digger. I'm thinking about sinking a bunch of fence posts in the ground and making a small building out of them and then burying the whole thing. I need to figure out how to keep water out and vent it. Do you think my idea could work?
Kevin
/ Tornado Shelter #2
I'd do an internet search on "Bomb Shelters" (a popular thing in the 1950's) and see what those designs look like.
/ Tornado Shelter #4
Would a septic tank work? They are common and probably not very expensive.
/ Tornado Shelter #5
Here's a link to FEMA's plans for building storm shelters to give you a few ideas. FEMA: Taking Shelter From the Storm
:thumbsup: FEMA has some good information.
Jobguy is on the right path with septic tanks. Some septic tank builders also make storm shelters. Not much different except they make it easier to get into and out of the shelter aka the tank.
Building a wood structure underground is not something I would do lightly. I have thought about it though for a storm shelter as well as a place to ferment beer. :D
The Southern Forest Products Association has a PDF about building permanent wood foundations which is sort what you are trying to do with the exception of covering the structure with dirt. Publications :: Southern Pine. The document is at the bottom of the page in the right column.
I have sketched out a design to build a green house with a basement. The basement being designed from the previous link. The basement was for a storm shelter as well as a beer cave. Since I did not like the idea of putting dirt on top of the shelter the idea of just putting a green house up there seemed like a better idea.
Later,
Dan
/ Tornado Shelter #6
Do you own the land and plan on keeping it? If you do I would consider an above ground solid wall and roofed concrete structure with a steel man door near the entry door of the mobile home.
You could make it look like a garden shed with nice siding for the ascetics of it. This would be something with an easy access door. Sort of like a safe house FEMA has designs for. Sometimes with tornadoes, they only give you just seconds to get into something quick and comfortable and if the small room would have good footers, the wind isn't going to knock it down. But, don't quote me on that.
Many years ago I had an underground wooded room for that purpose and never used it. Mine was so humid and was difficult to get in. Underground things would work but I question how quick a couple could get in it when under pressure, without falling down.
/ Tornado Shelter #7
Adding to this thread, but not about the shelter, is the importance of a good weather radio.
I have two, actually...this one:
[ame=http://www.amazon.com/Sangean-CL-100-Public-Certified-Weather/dp/B003QHXZM4/ref=sr_1_7?ie=UTF8&qid=1327684034&sr=8-7]Amazon.com: Sangean CL-100 Table Top Public Alert Certified S.A.M.E. Weather Hazard Alert Radio: Electronics[/ame]
and a portable that goes into the basement with us.
The warning signal on the Sangeon will wake anyone from a sound sleep. Pretty decent radio for listening to the news and music too, BTW.
/ Tornado Shelter #8
In my case access would be through a regular door. With the slope of our land, and the spoil dirt, we would have a door to walk into not a hole to climb down.
Your point is well taken though. Some of the septic tank storm shelters had little access holes, not doors. Others had doors for easier access. Having to climb down through a hole would be problematic in the dark with a few people and the family pets.
My other concern is once you are in, can you get out again after the storm has passed? Doors should open IN not out. I would want two ways out of an underground shelter.
Later,
Dan
/ Tornado Shelter #9
If you would care to find another use for the posts, a length (6 or 7 ft. possibly) of culvert pipe ( galvanized steel or plastic ) may fit the budget. About 4 ft. in diameter buried vertical, set in concrete would be relatively inexpensive. Steel covers are available as these are known as valve cans in the pipeline world. A simple ladder can be constructed for entering and egress.
When the concrete floor is poured set eye bolt anchoring hardware to secure the lid. These shelters don't need to be large since we're usually speaking of minutes rather than hours that it takes for a tornado to blow material things all to H**l.
As for being trapped in the shelter, don't worry about that. Disaster people, news media, neighbors, law enforcement and family will soon be there.
/ Tornado Shelter #10
If you stacked Lego's as a kid and you are decent with your DIY skills, you can do an ICF shelter, as seen here:
http://icfresource.com/saferooms.html
They can withstand 250MPH winds and impact from debris. It's basically a steel-reinforced 6" concrete bunker.
If a top rated F5 hits (260MPH-300MPH), then you will do better with an UNDERGROUND shelter. I would be confident that the above ground shelter can take a hit by a F5 but you better be sure that you anchored those walls properly and the footings are deep.
/ Tornado Shelter #12
i've seen metal and metal / fg ones that you can bury.
alternatively.. I know a guy that made a bunch of Y2K shelters and storage units out of septic tanks.. :) ( new ones! )
/ Tornado Shelter #13
How are you going to dig the hole?
I've seen large culverts used for underground bunkers that had concrete on the back and a metal door on the front. It was put in on the side of a hill and if I remember correctly, it wasn't quite tall enough to stand up in, but there was bench seats on the sides with some shelves full of stuff.
Eddie
/ Tornado Shelter #14
If you are going to dig, check you zoning, because that sometimes requires a permit if you are building an underground shelter. They don't want people building underground buildings that can collapse on top of them from poor engineering.
/ Tornado Shelter #15
I've thought about using one of those metal shipping containers, a short one if they make a 10-20'er. Buried 3/4's or flush with the ground then a 3-4" concrete "cap". I've seen some of those containers sell for 3k and less for a 40' one.
/ Tornado Shelter #16
That sounds like it would work. How would you enter? Cut a door on top?
Back in the old days, folks used to use root cellars...anything dug into the ground. It saved them...
/ Tornado Shelter #17
NoTrespassing said:
Hi All,
Kevin
When I read your post, I immediately thought of the traditional root cellar, which has been constructed from necessity since the beginning of time until recently.
Growing up with a root cellar (without a doubt the scariest place on earth for a kid),
Anytime the storms would roll in, we would head to the root cellar. Of course I wasn't worried about a tornado, I was more concerned with the spiders and the supposed 8' long snake my older sister swore lived there. Probably the worst was if ma told me - the 6 year old kid to go to the root cellar for something, by myself. YIKES. Oh the memories.
So I thought it would be an interesting topic to research. People have built cellars from whatever natural resources they had available. Do a google image search, and you will see what I mean. Quite fascinating.
You could use wood, although I don't think it would last long, if it held at all. One interesting thought, we have a concrete products plant a few miles from here. Their yard is FULL of reject boxes. Some of appropriate size for a storm shelter. One of the articles I read, this is what they used and basically got it for free, just had to pay to have it transported.
Here is an image that I found showing wood construction. Obviously it's not a root caller (or storm shelter). I wanted you to see this to show how the wood you have could be used to construct your shelter.
Good luck with your project.
/ Tornado Shelter #18
Two fold ... protect you as well when you shlt yourself ... well?
/ Tornado Shelter #19
i've been looking into this myself. so far, rectangular concrete culverts and septic tanks are all i've found that's suitable. if i'm going to put the time and effort into digging a hole, i may as well put something solid in it that'll last 20+ years is the way i'm thinking.
no prices so far, though. maybe do a search for 'concrete culverts' and look at the industrial end of things. this is where i found the rectangular items-i've got several emails out to manufacturers for info.
/ Tornado Shelter #20
Hi All,
Kevin
I built 1 from a piece of corrugated road tile 6 ft long and 5 ft in diameter. I found a ground slope close to the rental houses and took my backhoe and dug back into the slope. dropped in the road tile, Put a piece of 1 inch thick treated on the back end next the dirt and a heavy wire mesh hinged door on the front. Cost less my labor $300. Ken Sweet
