Help identify 3pt snow blower
/ Help identify 3pt snow blower #1
bkc
Member
western ny
I need some help trying to identify my snow blower.
It is 96" wide, side plates are 33"tall, twin 12" augers, and a 27" blower wheel.
Thanks in advance for any help.
Brian
Re: Help identify 3pt snow bloer
Forgot to add.
It was yellow, I painted it red. Im pretty sure it came yellow, I didnt see any other color under the yellow paint.
Brian
/ Help identify 3pt snow blower #3
Wow nice heavy duty looking blower. It's not a lorenz because it has screw type augers instead of the paddles on my old Lorenz. Not a Rad because of the style of augers, but hopefully someone somewhere will have had on and chime in. Definitely looks like it will throw some serious snow.
DevilDog
Thanks, I have spent HOURS looking a pics on here, and google with no luck.
I have a better idea of what its NOT, than what it is.....
It is pretty heavy, and could use a few more hp to take full advantage of that 96"
Brian
/ Help identify 3pt snow blower #5
I have never seen one like it. Not a detson, lucknow, normand, pronovost, IH or other common brands. Its not like any of the old unbranded ones I've ever seen before either.
/ Help identify 3pt snow blower #6
There is a Farm King Y960 and an IFE (Iowa Farm Equip) 96" on Ebay that look similar to this. I'm guessing its a Farm King.
/ Help identify 3pt snow blower #7
There is no bracing running down to the bottom corners from the lower 3pt attachment areas and the big impeller only has three paddles.... so I bet something offbrand... Still a nice unit.... :)
the bracing was removed by previous owner. I am curious as to what it looked like before the surgery. If I dont find any pics, I will weld something in there.
Brian
/ Help identify 3pt snow blower #9
I'm sure someone will show up and the mystery will be solved, what size & brand of tractor are you putting it on?
DevilDog
60HP Mahindra
Brian
/ Help identify 3pt snow blower #11
Brian
Hello Brian,
It looks like a two stage snow caster built by Fair MFG., Weld the bracing back on quick as it is heavy.
you should plan on adding a pair of pneumatic or steel swivel caster wheels to avoid digging in a the corners.
_________________________________________________________________
Oncde you go flail you never go back:thumbsup::licking::drool:
Pronovost or not at all!!!:thumbsup::licking::drool:
/ Help identify 3pt snow blower #15
It's an Erskine 960 rear-mount. Definitely high-end and has a couple unique features that put it in a class by itself. In the hitch-end view, the power to the auger goes out to the right from the gearbox. (Almost all of them go to the left.) The 3pt hitch points are unique too - deep box-members supporting the pin points - very strong.
This basic design has been made for a while - with a few changes. Right now they show a current one at the Quick-attach (Erskine?) website. The biggest difference is the lower auger is now bigger than the upper. The website has a video that shows footage of two different blowers, one is like yours with the drive on the same side. There's also a 96" one listed on the bay too (maybe the same one?).
Erskine (and many others) used to paint equipment with yellow zinc-chromate, back before the environmental police declared war on it. Maybe that explains the original color of yours? Pics below lift & middle are net images of Erskine 960. The one on the right is a head scratcher - either a single-auger Erskine with a JD decal, or ??
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
2025 44in Hydraulic Grapple Bucket Mini Skid Steer Attachment (A61572)
2025 44in...
LOOK! (A63111)
LOOK! (A63111)
UNUSED WOLVERINE QUICK COUPLER 2 (A64281)
UNUSED WOLVERINE...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
