We Got Snow!
/ We Got Snow! #1
Jerry/MT
Elite Member
North Idaho-The Palouse
New Holland TD95D, Ford 4610 & Kubota M4500
It started snowing yesterday (Wednesday) morning around 9:00 am and it hasn't stopped. We had 18 inches on the ground at 9:00 am this morning. I plugged in the Ford 4610 and two hours latter I was blowing snow with the old ARPS Model 70. It was about 18°F and the snow was dry. The blower threw a 7 foot swath about 30 ft. It took about 2 hours to do our lanes and then I did some lanes in the pastures so I could feed easier. The snow was dry and I had no problem with snow sticking on the augers.
I had to raise the blower about 3-4 inches because the blower wouldn't take all the snow. I then made another pass and got the rest. I looked like a snowman when I got done because my tractor is an open station!
It supposed to warm up tomorrow so I'll have to get an early start so I won't have a sticking problem.
Thanks for all the advice you folks gave me after my initial run last month. I pretty much have the hang of it now.
/ We Got Snow! #3
Open station, 18 degrees, I sure hope the wind was nil or at least light.:thumbsup:
/ We Got Snow! #4
You must have got the leftover from our last blow. We got about 12" total over 3 days.
Got in a few plows for the road association...so im happy.
/ We Got Snow!
It was calm but I got covered with snow. Today I went out to get the 8 inches we got ovenight and I put a rain slicker on and stayed dry. It was 20°F and we had some sun breaks. The weather folks are predicting some rain tomorrow (ARGH!) followed by more snow.
/ We Got Snow!
We got a real dump ~24 inches. There was 16 inches on the ground yesterday morning. and another 8 inches overnight
/ We Got Snow! #7
Fingers cross that winds don't start howling,than the blower will really get work out.
/ We Got Snow! #9
Its 40F and windy here. All snow is turning to slop. I plowed all the drives and walkways. Now im shedding the barn so i can blow it all out before the horses pound it into a mountain that will last till springtime.
/ We Got Snow! #10
Yes, we also have snow and anyone missing their snow can come on by and retrieve it, :laughing:. It started snowing midday Tuesday and did not stop until midday Friday, :confused2:. Snowblowed 4 times, always wait until about a foot of snow before snowblowing, ;) , not too little and not too much snow for snowblower, :thumbsup:. Today was #5 snowblowing, the snow from the roofs started coming off. The most at one time built up on the roof really traveled further out from the house and took out two of the wifes greenhouse plastic panels, :mad:. We are getting close to the amount of snowfall from last winter on the ground. B.T.W. tomorrow will be #6 snowblowing as more snow slid of the roofs, :smiley_aafz:. KC :D :D :D
/ We Got Snow! #13
It got to 39F yesterday, and all the buildings shed their snow. Funny thing is, i was heating the horse barn with two 175,000 btu salamander heaters, but that building took longer to shed then the unheated ones.
Go figure.
After they shed i got piles of WET snow about 3 feet high and ,maybe 8' wide.
I got out the new loader mounted blower to give it its first workout on tightly packed wet snow.
It did a great job, and so much faster than the way i used to do it.
In the good old days i would have to use the loader to break up a section of the deep pile, turn around tractor and blow it out. Then use the loader again,,, etc.
Each side of the horse barn used to take 1 to 1-1/2 hours to do. Took about 12 minutes now.
Also, the shedding from my shop used to take more than an hour to do, it took 5-1/2 minutes.
The shedding from the carriage barn was another 1-1/2 hour ordeal in deep wet snow, it took 8 minutes yesterday.
What is saving the time are 3 things.
1. I dont need a loader to break up the high piles cause i can raise the blower up as needed.
2. Wet snow use to clog my old blower ALL the time, and i had to dig it out. When the new blower gets clogged, i simply tilt it and tap it on the ground,a nd the clog dislodges. No need to get out of the cab.
3. No shear bolts to replace anymore
I have some new video that i will convert and past later today. It was sure fun to play with the new blower.
/ We Got Snow! #14
Heating the barn may cause it to take longer for the snow to slide off because the heat is melting from the bottom up. The roof steel is warmer so the snow against it melts abit but then the snow above it is colder so it refreezes and actually sticks more. Wet snow is stickier than dry frozen snow.
/ We Got Snow! #15
makes sense, but i usually have to heat it to shed it when it gets too heavy. It wasnt too thick this time, i just wanted it to shed so i could practice with the snow blower
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
ELECTRIC POWER WASHER (A64278)
ELECTRIC POWER...
Bull (A64557)
Bull (A64557)
2019 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A64556)
2019 Peterbilt 579...
2006 International 4200 2,000 Gallon Water Truck (A64553)
2006 International...
2019 KUBOTA KX71-3 SUPER SERIES EXCAVATOR (A65053)
2019 KUBOTA KX71-3...
