OrangeToys
It doesn't work like that. You have to post a picture of it so that we can all tell you what you're doing wrong.QUOTE]
Dang I just didn't want all the abuse...but here it goes
What's the rating on those straps?
The Front is a 3" with work load of 5400lbs
The Back is a 4" with work load of 5400lbs
I'm no expert, we can probably find something wrong with all our set ups.
On yours I would say since the loader is detachable, it does need a separate attachment, but using it as the only tie down on the front is probably not kosher.
On the back it looks like it goes behind the ROPS, so that should be good, but I would bring them down to closer stake pockets, to improve the geometry. Also I believe, but am not positive, you would need a separate tie down for a 3pt implement.
I agree with IPF, I wouldn't be very worried of it moving when towing it, just be worried of a safety stop and inspection.
JB
The problem I see with those straps is that the rear of the tractor can move sideways and the longer the strap the more movement is possible.
If it can move then it will move.
Just my experience you know, just sayin![]()
JB
My problem on the front is that I can't find a good place to tie to without putting something on the tractor in a bind or break it. On the Back the length of the strap is long i know but I was avoiding some rubbing on the brush hog, it's typically on the one closest to the fender when using other implements.
I used to tie my JD870 thru the same holes in the front bucket, and tie the rear over the drawbar support. There was no other way to do it. I use 5/16" chains though. QUOTE]
Do you have any pics? I have thought of this but how?
no pics..sorry. I sold the tractor last year. My new tractor is too heavy and large for my current trailer.
What if you went from the right stake pocket to the left ROPS post and visa versa?My problem on the front is that I can't find a good place to tie to without putting something on the tractor in a bind or break it. On the Back the length of the strap is long i know but I was avoiding some rubbing on the brush hog, it's typically on the one closest to the fender when using other implements.
You can put a shackle in the drawbar and use that as the diedown point.I used to tie my JD870 thru the same holes in the front bucket, and tie the rear over the drawbar support. There was no other way to do it. I use 5/16" chains though. QUOTE]
I haul a M9540 with a shackle in the drawbar with a chain passed through it and another chain through the loader arm cross tube. Never had any problems. When I was a kid my dad and grandpa hauled tractors all over the place without even a hay string holding them down and never had any trouble. At least I am doing better than that.
I also haul my M9540 with a 3/8 G70 chain and 3/8-1/2 binder through a shackle in the drawbar on the rear and a 3/8 G70 chain and 3/8-1/2 binder looped over brush guard on front. This is how the Kubota dealer suggested to tie it down. I wish there were holes or hooks to use, but there isn't and I don't really want to start drilling or welding to the frame.
On our JD 4020, I do use two 3/8 G70 chain and 3/8-1/2 binders on front and rear because I am able to find something to hook to, plus it is a heavier tractor.
Thats exactly how I chain mine down. Clevis in the drawbar and I keep a 6 foot long piece of quarter round trim in back of the truck to push the chain thru the cross tube on the loader.
After reading most of these threads I'm going to try and find a way to chain down the front of the tractor and strap the bucket.
Because most of the CUT's are sold with a FEL we forget, at least I do, that the FEL is an implement.
G70 5/16 chains, hooks, and rachet binders.
On the front, I would put a clevis into the bottom of the brush guard on each side and tie off to that or hook onto the frame rails (from the inside) just aft of the grill guard.
That should still clear your loader arms and give you better angles.
Aaron Z
Makes sense in your case, but on a Kubota (like OrangeToys who I replied to has) the brush guard is different. This is the one on our L3830 which is similar to his:I don't think the brush gaurd is designed to hold much more than itself, I do the frame behind the weight bracket. that makes a very short stout connection.
