HD Box Blade?
/ HD Box Blade? #1
scoutcub
Ohio
Yanmar LX4900//Cub 7532//Cub Yanmar SC2400//Komatsu D38//Cub Volunteer//Cub SZ60/CAT 289C/CAT 308
Trying to figure out attachments for my new 49 HP compact. Read a great thread on counterweight, so will be filling rears, and want to get a stout Box blade to carry around while "loadering" & "grappling"
My question - obviously not all box blades are created equally....what are the "good" or "better" brand names that are HD and heavy? Does Woods lead the pack or are there other brands equally well made for similar cost?
thanks!
/ HD Box Blade? #2
I'm exceptionally pleased with my hydraulic Modern 7' industrial galvanized box blade, which weighs about 1200 lbs. It's pricey, though.
/ HD Box Blade? #3
You need to look at commercial quality boxes. Pretty much forget about anything that does not weigh at least 1,000lbs. I would be looking at a box width of 72"-84" and hydraulic actuated scarifiers.
To be able to help get your grading just how you want, keep in mind a set of top and tilt hydraulics for your 3pt hitch. ;)
/ HD Box Blade? #4
the best thing is to get a med or heavy duty boxblade.an the best way todo that is talk to your tractor dealer.anytime im thinking about buying equipment for my tractor,i talk to my tractor dealer.an tell him what i want an what itll be used for.an he tells me what works an how much it costs.
/ HD Box Blade? #6
At 49 HP you're not going to be able to use a commercial unit. Probably in the area of a 6 footer. Woods, Land Pride,Bush hog all make good box blades. If you want more weight put a notch in the top and hang a barbell set on it Or you can hang suitcase weights. The only limiting factor is the lack of imagination. Bet you can think of a hundred ways to add weight. Personally I have a Kubota bx2360. For weight I have a farm force 4 foot box blade. I picked it up for a song on Craigslist.
/ HD Box Blade? #7
You might consider the National Farm Machinery Show in Louisville. Most of the manufacturers will have booths there with their equipment displayed. It is February 15-18 and indoors. National Farm Machinery Show
/ HD Box Blade? #8
Why do you say this? He might have a 49hp tractor that weighs 8000lbs. An 8k pound tractor would easily handle a commercial quality box blade. Even if his tractor is not that heavy, he would still be able to make good use of a commercial unit.
The problem with just adding extra weight to a light box blade is that with that extra weight the the box digs far beyond what it is designed for and will fail at some point in time. Weight by itself is not the secret, but to have a unit that is built with heavier higher quality material will get you an implement that will get the job done for a long long time with little to no maintenance. ;)
/ HD Box Blade? #9
thanks!
I'm with you Frank! I told my wife I want a good 7' or 8' box blade that weighs 1200 lbs or more.
I need to give her more specifics!
I've been looking at the Woods Gannon brand BB's but I've not made any decision.
What tractor did you get?
Be well,
David
/ HD Box Blade? #10
I agree, for a 49 hp COMPACT tractor, you do NOT want an industrial BB, nor do you want a heavy duty BB. A good medium duty Woods, Bush Hog or Land Pride will be all you want and can handle. And they are plenty heavy duty for your needs and the tractor's capability. I doubt that there is significant difference in the quality or construction of the three brands, just minor differences in design.
To go to hydraulic operated scarifiers is a LOT more money (double+?) and isn't worth the cost if you are using it primarily for counter weight and occasional grading, etc. The hydraulic scarifiers would only be justified if you were using it on a full time basis for grading.
I bought a 7' Bush Hog medium duty bb a couple of years ago and I'm happy with it. Prior to that I had a 5' used BB for ten years.
Ken
/ HD Box Blade? #11
I have to agree with Brian. I run a Bush Hog MBX 720 (now called the MBX 72) that weighs 640 lbs behind my TC35D. I'd love another 200-400 lbs of box blade myself. Hydraulic scarifiers would be icing on the cake!
I found a used Gannon with hydraulic scarifiers for $1100. The paint was barely scratched so it hadn't been used very much. It was a 66" model. If it would have been a 6 footer it would be mine.
/ HD Box Blade? #12
Ken
Why? Because a person can get by with a medium duty blade? Because you can get by is not a reason to forgo a better unit. As far as not being able to handle it, that is wrong. There are members here on TBN that have 4000 series JDs that have no problems, One of the guys has no loader that uses a 1200lb commercial box blade without problems.
You are right, hydraulic actuated scarifiers are expensive and luxury for a non professional, one of the reasons that I mentioned that I would look for a hydraulic unit. With the OP wanting a counter weight, it only makes sense to have one that is heavy, how much good is 500lbs vs 1,000 or more?
I use a 66" wide 700lb BB behind my 32hp 5,000lb Mahindra 3215HST without ANY problems. I'm sure that most any 49hp tractor can handle a 1,000lb+ BB without any problems.
I'm glad that you are happy with your 7"medium duty BB. If you are using that on the same tractor that you were using the 5' BB on, then I feel sorry for you that you were using such an under sized box all those years.
But whatever works for each of us is all that really matters.
The only draw back to the industrial box blade that I see is the cost. Other than that it's pretty hard to go wrong with a superior piece of equipment.
Just my opinion, others do vary. ;)
/ HD Box Blade? #13
I agree with Mtn. The weight of the tractor is the key. My 55 hp with 4WD and loaded tires weighs 8K and handles my 7' 1200 lb Modern BB pretty well, at least pushing backwards, which is all I've done so far.
/ HD Box Blade? #14
What's needed to build a good quality HD box blade isn't exactly rocket science. Basic layout is pretty standard. Needs quality steel of the right gauge and strength. Top quality metal bending and welding. Good quality paint job.
It should not be a surprise that there are actually a fair number of outfits that do those things. In addition to the nationally-recognized ones (Woods/Gannon, Landpride, etc.), there are some regional manufacturers making good quality products. Unless you regard your boxblade as some kind of status symbol, it probably doesn't make a whole lot of difference which one you choose, as long as it's a good one.
Which brings us to the recommendations for getting a medium duty one and adding some weight. You can save some money that way, and a good quality medium-grade boxblade can easily handle some additional weight, both for ballast and to help it dig better, if (BIG "if") it's not going to be put into heavy-duty service. If your work is mainly "loadering" (I like that) and "grappling", maybe that would work just as well for you as paying more for a true heavy-duty one.
If you don't have the time to mess around adding some weight and don't mind paying more, then go with any of the good quality HD boxes.
Here's an old thread about box blades, but it has some good info regardless.
http://www.tractorbynet.com/forums/attachments/59301-box-blade-photo-comparision-brands.html
/ HD Box Blade? #15
Thanks for the link, it is a great source of very good, detailed, and useful information. I have an old 66" Rhino box blade that I used with my Ford 4000 that I sold years ago and then put it behind my Kubota L2900. I bought a new Kubota MX5100, 4WD, HST, w/LA 844 loader that is 5,500lbs. + or - in August of 2011 and I want a larger, heavier, and possibly more functional box scraper. I am not willing to spend the $$ required for the hydraulically operated boxes, so I am looking for the best of the ones I discovered in the linked thread you provided. I have been looking at Bushog, Land Pride, and Woods/Gannon. I am now adding Midwest, Buhler, and Befco to the list. I have R4's on my Kubota as I am cleaning out some old ponds on the property and they are really good in the muck, but they don't provide the traction of R1s. I am debating about a 6' or 7' blade. I think all of the manufacturers are represented at the National Farm Machinery show next month and I will check them out there and probably make my decision after that. I also need a new rotary mower, and a good set of lift harrows. It could be an expensive show!
/ HD Box Blade? #16
I just returned from searching for rollover box blades and discovered that Bush Hog also offers a blade with manually retractable scarifiers from the tractor seat utilizing a long handle similar to the rollover blade that will allow you to rip and scrape at the same time and then retract the scrapers without leaving the seat. I could not find any information on the Land pride site that indicated that they still offered a manually operated rollover box. Information on Buhler, and Midwest scraper boxes is limited and not readily available using a search engine. I did find some information on the Befco box.
/ HD Box Blade? #17
MidWest is no longer in biz, the owner died and then the company. :(
Roll over box blades are very good in my opinion, heavy duty-industrial quality. But most of the companies that made them don't any more. :(
/ HD Box Blade? #18
While I was researching box blades, I became interested in rollover blades as well. I don't remember all the details, but I discovered that the basic rollover design - that had been around since horse pulled implements - had been largely replaced by he hydraulic scarifier design. When I found that I could get a hydraulic blade for little more than a rollover, I went with the hydraulic and have been quite pleased with the results.
/ HD Box Blade? #19
Thanks for the information on Midwest. I can't justify the additional expense of hydraulic boxes as I would also have to install rear remotes on the tractor and the prices I was able to glean from internet pricing on hydraulically operated box blades ran $1500 and up more than the manual ones, although they are more versatile. If I were landscaping as a business then yes, the price would be secondary, but since this is occasional use it just doesn't work for my applications. I will check all this out at the Farm Machinery Show next month.
/ HD Box Blade?
Hey lots of good info here, I appreciate all the input! I'll give some more details of my "plight"....the tractor is around #4500 with loader.....loader can lift #2500, and 3-pt can lift #2800. I figure around #1000 lbs of rimguard for the rears? So a #1000 lb boxblade should be no issue. I was thinking at least #800 minimum.
Doing a little research, looks like "modern" makes a good quality heavy blade. And I called a local implement guy, he's got a new 72" but I forget the name. And he didn't know how much it weighs...:confused: But I'll still go check it out. There's a 72" woods on ebay, but I asked the seller he thinks it's only 505 lbs....he said he did a google search to find out....again....:confused: If you sell implements, shouldn't you know what they weigh? :thumbsup:
So maybe it was their light or medium line.....
And I'm still debating on a 72 or 84".....Yanmar sells the 72" for this tractor. Wouldn't mind hearing opinions on 72 vs 84..... maybe a new thread??:laughing:
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
2006 Ford F53 Landau 3645DS 36ft. Class A Motorhome (A61574)
2006 Ford F53...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63688)
2017 Cadillac...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
2025 SF60 60in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
2025 SF60 60in...
