rubber flap
/ rubber flap #1
rrrkkk
Quincy IL
New Holland TC 30
well had our first snowfall this morning. I was anxious to try out my modifaction. I added a 10" wide baler belt to the 7' rear blade. I let approx 4" hang below the Landpride blade edge. From reading the posts on here it was said it wouldn't tear up the concrete, and be less disturbing to the gravel in the driveway.
Well it seemed to pull as much gravel as before, I had been out about 2 hours and it cut the belting at the blade edge.
So I guess I'll try the horse stall matt. I have conveyor belting but it appears it would do the dame as what I have.
/ rubber flap #2
Try cutting piece of 2" to 4" PVC pipe and slipping it over the cutting edge of your blade. They don't last long but it works. I've got a couple of tail wheels to mount on each side of my blade. Pull the pin so the blade can float side to side. I haven't done it yet but I'm going to eventually get a hydraulic top link so I can adjust the height of the blade as needed without getting off the tractor.
/ rubber flap #3
This is exactly how I solved this ,also with cheapest PVC pipe
/ rubber flap #4
I'm mid-process of installing a piece of 1-1/4" steel pipe on the bottom of mine. Slit the pipe with my plasma cutter(gawd, I love that thing..!!), and got it slipped on. Got the tabs welded on the backside, to bolt to moldboard. Forgot my 1/2" drill was at the other place, and picked it up today. Will drill the tabs, then flip, and weld tabs on the other side, then get it bolted together.
May venture to the shop tomorrow, and get that project finished.
Calling for near 50 here by Monday, so may be a while before I can try it out. Next year, or year after would suit me fine... ;)
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
John Deere 24in Digging Tooth Bucket Excavator Attachment (A60352)
John Deere 24in...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
