Chipper Looking for a chipper for a Kioti ck27
   / Looking for a chipper for a Kioti ck27 #1
Not Retired Yet
Small farm in North Central Arkansas
2011 Kioti ck27hst
I've got a ck27hst (I think 20.5 pto hp) that I'd like to get a chipper for. Lots of small trees, scrub to clear but not many good burn weekends. It seems like a Wallenstein bx42 is my best bet. I'd like to chip up to 6" but don't think I have the power for it is why I'm looking at the 42. Any suggestions for other chippers or is this best? Pros and cons? Thanks.
   / Looking for a chipper for a Kioti ck27 #2
I have a Jinma 284 That's about 25hp I use a Chinese 6" capacity chipper and it does a GREAT job.I too only chip junk trees/brush mostly pine tree stuff. Some birch and Cherry trees. And I have done up to it's 6" capacity with no problem.I would expect you to be able to use one without any problems. mine was only $1400.00 a few years ago it attaches easily and I lower it on a wooden platform with wheels when I need to store it. Someone must have one near you? There is a few utube videos of the JM-006 in action
[ame]http://www.youtube.com/watch?v=4XMhDEnO9rg[/ame]
PM me and I'll send you some pictures.
   / Looking for a chipper for a Kioti ck27 #3
I have a 6" Jimna chipper and i used it on my JD870 for about 5 years (if i remember right) . that tractor had 25HP at the PTO and was able to chip 6" without an issue as long as i prevented the self feed from sucking in too fast. My new DK45 sucks in anything i throw at it.
20 HP would also work, but id be leery of feeding in 6" stuff.
   / Looking for a chipper for a Kioti ck27 #4
   / Looking for a chipper for a Kioti ck27 #5
I use a BX42 on my CK30. Good chipper. Most of your "chipping" material will be 4" and under.
Thanks everyone. I think I've narrowed it down to either a Jinma 6" or a Wallenstein bx42. I know it's not apples-to-apples since it's a 6" and a 4" but I don't think I've got the HP for bx62. Jinma and Wally seem to be the top two discussed. Now I need to to decide how much I can afford to spend....
   / Looking for a chipper for a Kioti ck27 #7
I have a Wallenstein BX 42 I run with a JD 2320 - 18 PTO HP.
4 inch soft wood is no problem, however 4 inch hardwood like pecan will draw the engine down.
I'm very pleased with the BX 42 - simple design, no belts, well made and getting to the knives is easy plus the opening is 4 x 10 inches.
This makes it much easier to get limbs with bends in them thru the chipper.
I bought the BX 42 mostly based on what I read on this forum and couldn't be happier with it. It's a very trouble free unit.
   / Looking for a chipper for a Kioti ck27 #8
Keep an eye on Craigslist (and use Search Tempest to widen your search). You can find some good chippers on there for a decent price.
My chipper is a Woods 5000 which has a 5" capacity and a shredder for brush, leaves and other smaller stuff. Bearcat makes this chipper/shredder and has the same unit for purchase. Sorry, I don't recall Bearcat's model number.
This chipper/shredder is rated 15-30 PTO HP. I used it behind a 24 PTO HP Deere 790, initially. Did a fine job for the most part. and never stalled the tractor, but I'd get an occasional bogging down of the engine if I fed it too fast. Mostly, I put the limb or branch in the chute and walk away.
With 20.5 PTO HP, you should easily chip 3" branches and limbs. 4" stuff may cause an occasional problem, but just feed it slowly
Thanks, I haven't used search tempest before, that makes it easier! I've been checking you tube videos and sure like how easy it is to bet to the blades on the bx42. The fun part is getting it past the boss.... :)
   / Looking for a chipper for a Kioti ck27 #10
It is easier to beg forgiveness then ask permission...
It turns out a tractor/farm supply dealer that sharpens my chainsaw chains is also a Wallenstein dealer now. They've got a new orange bx42 they'll put in my truck for $2500 plus tax - all I have to do now is get the okay from the wife!
   / Looking for a chipper for a Kioti ck27 #12
I cannot recall the model number either but I have the Bearcat version of Roy's chipper. It is Bearcat's simple PTO model without the truck loading shoot. Solid machine and it has a bigger flywheel than the DR or Wallenstein chippers of this size (I know that is true of the DR, not positive about the Wallenstein). Big flywheel is an advantage.
I used mine on my CK20 and it did a fine job but did slow down with stuff near capacity. Not an issue with my DK40. I'd say the CK27 would be an excellent match. Too bad you don't live nearby as I'd sell you mine for half of what the new one costs.
Thanks for the offer Island and if I was closer I'd take you up on it. (I do have the grapple I use on the front though in large part because of your posts and pictures.):D
   / Looking for a chipper for a Kioti ck27 #14
Hah! My grapple is part of the reason I'd part with the perfectly good chipper. I have found it is even easier to just grapple and cart the stuff to hidden debris piles to rot as it is to chip it.
Hope you like your grapple as much as I like mine.
Absolutely love the grapple! I'm limited on brush pile space and time to burn. I figured chip piles will look better and contain fewer copper heads than brush piles. :)
   / Looking for a chipper for a Kioti ck27 #16
Good reasons to get a chippper!
   / Looking for a chipper for a Kioti ck27 #17
If u have a lot of brush, the ones with shredders are better. The big hopper eats up the small stuff fast. And if u can get two people working, one can chip the big stuff while the other does the brush.
I have a csp100 bush hog, 5" chipper and 11/4" shredder. Its the same as a goosen. I use it behind my ck25 gear. Works great.
   / Looking for a chipper for a Kioti ck27 #18
I have the same Bush Hog chipper. Picked it up for $500. It was made by Gossen and parts are still available. The previous owner took really good care of it and other than needing the knives sharpened, it works very well. Even with dull knives, it has chewed right thru 3" branches like nothing and the shredder is great.
I have it behind a JD2305. It is a little heavy, so front weights are required to hold the front down, but otherwise it is great. I hate brush piles and would rather just chip as I go, than wait for a good day to burn it up.
   / Looking for a chipper for a Kioti ck27 #19
If the shredder on your Bush Hog is anything like the shredder on my Woods, it pulls the brush through so fast, it's almost scary!
   / Looking for a chipper for a Kioti ck27 #20
Agree. I learned never to hold on to brush while feeding with more than a couple of fingers. If you have too good a grip or your glove gets snagged it feels like it could pull you in.:(
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A55745)
2015 VANTAGE...
(2) 6 LUG WHEELS/GOODRIDE ST225/75D15 TIRES (A60432)
(2) 6 LUG...
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
