Looking for NEW shop Compressor
/ Looking for NEW shop Compressor
Congrats on the IR compressor. I can't speak from experience on that model, but I'm really impressed with my small IR compressor. I think that extra amount that you paid up front will be something that you will appreciate over the years and be happy that you did.
If you can't even buy the thing from HF, what makes you think they will support it when you need parts?
Eddie
yep always an issue with about anything anymore for parts. have to look on-line to find a part for about anything... DAYTON heater sold through GRAINGER industrial but they couldnt get me part ;( wouldnt even call me back after 3 calls and 2 emails though my work where we buy a lot from them I looked elsewhere and got what I needed.
need to find some new batteries for my 18volt HF drill set.
Going to get horse stall mat for under the compressor as I'm going to leave it on the skid for now as in floor heat tubes and dont want to drill into one of them ;)
I got the compressor fired up today took almost 5 min to fill up to 150 PSI slight vibration in there without the rubber under it. will re-check oil level next time out in the shop and have to get a good regulator plumbed in yet as well as a main line run.
Mark
/ Looking for NEW shop Compressor #22
Mark
Yeah, the IR used to be a good brand. Guess they still are. Better than whatever it was at HF anyway for sure.
I've got some extra room on the welding trailer now that we got rid of the old SA200 and I think I could squeeze a compressor in there and still have room for the Ranger 225. I was looking at this IR gas powered hotdogs. But with the Ranger I could run a elect compressor. Do you have any suggestions?
If this trailer is outside working then I would say look for something that is going to be rain/weather resistant. the 225 ranger has pretty good 120/240 output when running so you could put a pretty good sized one on there. 2nd thing would be to get a good idea as to size that will fit, then look at specifications to know if it is worth while. If you want to run a huge sandblaster and you only have 2 sq feet for a compressor chances are you are barking up wrong tree.
Mark
CASE 721E WHEEL LOADER (A67714)
CASE 721E WHEEL...
HAMM 2210 SSD PADFOOT COMPACTOR (A67714)
HAMM 2210 SSD...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2020 KENWORTH T880 (A67714)
2020 KENWORTH T880...
CATERPILLAR 324EL LONG REACH EXCAVATOR (A65053)
CATERPILLAR 324EL...
