2320 trans/hydro oil
/ 2320 trans/hydro oil #1
tootallbilly
john deere 2320
anyone know how much fluid a change takes....book says 3.5 gal....I added this much after draining a putting on a new filter and cannot even see it in sight glass......thanks
/ 2320 trans/hydro oil #2
i just changed mine had same prob ,when i drained mine i took out same as i put in 2.4 gal with filter change. then there was no oil in site glass so i added more i wound up putting 3 gal in, dealer told me 3.4,then there was oil in glass about 3/4 make sure u cycle everying check it on level ground.
/ 2320 trans/hydro oil #4
When i did my 50 hr service I kept had the same issue.. I kept adding oil until it came out of the fill hole.. OOOPS..
I figured out that I had to run the tractor AND the rear pto - once i did that the level showed up in the site glass.. Then i had to drain, run and recheck.. Lather rinse repeated until the site glass was 1/2 full..
also dont forget to have the 3pt in the lowest position..
good luck
Brian
/ 2320 trans/hydro oil #5
Hello tootallbilly and WELCOME TO TBN:)
When you didn't see anything in the sight glass did your 3PT happen to be in the raised position. Just by lowering that will put fluid in the sight glass.
As posted,make sure all your hydraulics are relaxed/retracted,tractor is on decently level ground and it has sit for a bit.
Greg
Thanks guys yes the 3pt was up....will recheck with it down..
2016 Volvo XC60 SUV (A61574)
2016 Volvo XC60...
2014 STARCRAFT BUMPER PULL TRAVEL TRAILER (A63569)
2014 STARCRAFT...
(4) Tex Star 205/75D/15 Tires and Rims (A64047)
(4) Tex Star...
2022 FORD F-150 4X4 (A63569)
2022 FORD F-150...
2021 PETERBILT 367 (A63569)
2021 PETERBILT 367...
2002 Ditch Witch 1230H Walk-Behind Trencher (A61572)
2002 Ditch Witch...
