2320 trans/hydro oil
   / 2320 trans/hydro oil #1
tootallbilly
john deere 2320
anyone know how much fluid a change takes....book says 3.5 gal....I added this much after draining a putting on a new filter and cannot even see it in sight glass......thanks
   / 2320 trans/hydro oil #2
i just changed mine had same prob ,when i drained mine i took out same as i put in 2.4 gal with filter change. then there was no oil in site glass so i added more i wound up putting 3 gal in, dealer told me 3.4,then there was oil in glass about 3/4 make sure u cycle everying check it on level ground.
   / 2320 trans/hydro oil #4
When i did my 50 hr service I kept had the same issue.. I kept adding oil until it came out of the fill hole.. OOOPS..
I figured out that I had to run the tractor AND the rear pto - once i did that the level showed up in the site glass.. Then i had to drain, run and recheck.. Lather rinse repeated until the site glass was 1/2 full..
also dont forget to have the 3pt in the lowest position..
good luck
Brian
   / 2320 trans/hydro oil #5
Hello tootallbilly and WELCOME TO TBN:)
When you didn't see anything in the sight glass did your 3PT happen to be in the raised position. Just by lowering that will put fluid in the sight glass.
As posted,make sure all your hydraulics are relaxed/retracted,tractor is on decently level ground and it has sit for a bit.
Greg
Thanks guys yes the 3pt was up....will recheck with it down..
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
2012 CATERPILLAR 316EL EXCAVATOR (A51406)
2012 CATERPILLAR...
1984 Ford LTD Crown Victoria (A52377)
1984 Ford LTD...
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
