Posthole Digger Looking for a quick and easy PHD stand idea.
/ Looking for a quick and easy PHD stand idea. #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
Guys,
I would REALLY like to build a quick and easy PHD stand for this one that I've borrowed from my neighbor.
It is a @#$% to connect when it is just laying on the ground.
I've got lots of scrap lumber, anyone got a simple set of plans or general idea they can share so I could whip one out before I return this PHD?
Thanks in advance & MERRY CHRISTMAS!
David
Greg,
You are right shipmate. As I posted the thread I thought "maybe I should have searched first"... Thanks for the link, I'm off to read it now...
Seems I'm a "post first, think later kind of guy". :D
Be well,
MERRY CHRISTMAS!
David
/ Looking for a quick and easy PHD stand idea. #4
Made one from 2x4's and some plywood. Stands up about 6' tall , 3' wide , 3' deep, made like a pyrmid . Lower down phd as backing between legs , stop and lift to max height . Get off tractor and slide 2x4 through top and lower phd down . Then unhook pto drive shaft , lift arms , and then center link / end of phd . Should drop or come up a little depending on how it sets on 2x4 . Made two for friends , one for befco phd , one for landpride phd. Will try to get a pic. or two later today. Steven.
/ Looking for a quick and easy PHD stand idea. #5
I use a tree and a length of chain ... of course it stays out in the weather!!
I would LOVE to see pics Steven!
Thanks!
David
/ Looking for a quick and easy PHD stand idea. #7
I do the same! Add an old tarp and a bungee cord and you have it all protection, storage and best of all cheap and easy.
/ Looking for a quick and easy PHD stand idea. #8
Greg, Like your stand. May try that with wheels so I can push it around the barn.:thumbsup:
/ Looking for a quick and easy PHD stand idea. #9
Same here - 2x6" nailed between two trees, about 2 foot of chain and a quick (screw) link. Back under the board, lift PHD to max height, loop the chain through the loop on top of the PHD then over the board, hook the two ends together with the screw link, unhook from 3pt, trap it for protection, DONE. Takes me maybe 3-4 minutes at the most. Plus about it was cheap....
Good luck
/ Looking for a quick and easy PHD stand idea. #10
I have a TPH carryall, so I didn't bother with wheels. Instead I used a pallet for the base, so that I can pick the whole thing up and move it around - sorta forklift style.
//greg//
/ Looking for a quick and easy PHD stand idea. #11
This is as cheap and easy as i could think to do with mine. Personally i remove my auger bit as i have 2 sizes anyways and i never know which one ill be using. Its made up of a pallet and some 2x4's . Then i use a 5/8" steel ground rod that pins the PHD up after its removed from tractor. Its set at the exact height needed to reinstall. And the pallet allows me to move it with my forks.
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
2017 Mack Semi (A64047)
2017 Mack Semi...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
SHELVES WITH HEAVYEQUIPMENT ITEMS (A68842)
SHELVES WITH...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
