Loader installing hooks on fel
   / installing hooks on fel #1
mkfriel2
Member
WV
Kubota bx2660
What is the best way to add hooks to my fel. Welding or drill a hole and use clevis style.
   / installing hooks on fel #2
I plan to buy some weld on hooks and weld them to a plate which I will bolt on the loader bucket.
just cann't seem to find bolt on hooks in ontario. might have to order them.
   / installing hooks on fel #3
Weld only... much stronger.
   / installing hooks on fel #5
   / installing hooks on fel #6
I did the same as the previous post except I turned the angle iron around 180 which closes the back of the bucket. 2x3x1/4 angle. This also gives the top of the bucket more srength. 5/16 hooks on each end and 3/8 in the middle.
   / installing hooks on fel #7
Ken's Bolt On Grab Hooks
Kennyd sells them, Not sure if he ships to Canada.
I think with the bolt on there would be more options to make it as durable as possible, thru the use of top and bottom plates etc, if necessary.
JB.
   / installing hooks on fel #8
I see that you have a BX2660. If you are looking for a different option other than welding or drilling a hole, you may be interested in what BXpanded has to offer Bucket Hooks. They mount and dismount in seconds. Attached is a picture of mine along with their brush forks.
   / installing hooks on fel #9
Those look great, I went to the website but still can't figure out exactly what holds them on. Do they wedge themselves in behind the top edge of the bucket?
   / installing hooks on fel #10
Heres mine. Philip.
2012 DODGE RAM 1500 CREW CAB PICKUP TRUCK (A57880)
2012 DODGE RAM...
2025 GPS Trailers (A56857)
2025 GPS Trailers...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
TANK MANIFOLD (A55745)
