Tire ballast 911
   / Tire ballast 911 #11
Ill get alot of bad feedback, but personally Id put in some tubes.. If the tire comes unbeaded that quickly. I can imagine how it would act in the ''field' with side pressure..
   / Tire ballast 911
I am considering tubes. Just afraid if I get a flat It's a big mess to change.
What is a true tire pump? I am using a compressor.
   / Tire ballast 911 #13
tubes are fine.. tubelss is fine. just get the tires seated.. over pressurize them a bit, then go at it again.
it's no big deal.. don't sweat any of this..
soundguy
   / Tire ballast 911
I give up. Tried everything. Wasted 5 gallons of fluid at least. Can't get the tires to seal. It's sitting on jack stands. Frustrated to all ****. Going to start drinking. :)
   / Tire ballast 911 #15
Here is your tire pump you ask about. I did a quick GOOGLE Search for Pictures and Info - Many companies make them, Ingersoll Rand - Ingersoll Rand Tire Fill System Special Application Pump | Wayfair.
Click on this link - Changing a Tractor Tire - Liquid Ballast | Gempler's
I tend to shy away from showing because of Calcium usage. Do not use Calcium unless necessary - Yes it is HEAVIER than water. We use RV Antifreeze; No Alcohol, not harmful to environment if you do get a puncture.
Tony - P.S. Not recommending anything, just showing to answer the question
   / Tire ballast 911 #16
a good ratchet strap will likely get that bead back seated. if it didn't.. I'd tube it in a hot second..
soundguy
   / Tire ballast 911
Ya. Tried the ratchet strap. Looks like tubes it is. :)
   / Tire ballast 911 #18
not the easiest way.. but is sure fire... a bead cheatah would do it too.
soundguy
   / Tire ballast 911
I have the tires inflated to 35 psi now. So no cheatah necessary. Soon as I let the air out it de-beeds. If I want ballast in the tires I will have to get tubes. :-(
   / Tire ballast 911 #20
real wide rims?
soundguy
New/Unused 2025 CFG QK18R Mini Excavator (A57453)
New/Unused 2025...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
CFG Industrail MX15RX (A53317)
CFG Industrail...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
2017 Chevrolet 1500 Silverado Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2012 Ford F-550 Ext. Cab Stellar EC3200 1.5 Ton Crane Utility Flatbed Truck (A55973)
2012 Ford F-550...
