How do you tie down tractors when hauling on a trailer?
/ How do you tie down tractors when hauling on a trailer? #11
Yes, and so the farming game goes...But you might want the camping trailer later..So..
/ How do you tie down tractors when hauling on a trailer? #12
Double X. Front left tractor tied to front Right of the trailer. Front right tractor to front left trailer, Rear right tractor to rear left trailer, rear left tractor to rear right trailer.
Use grade 1/2" Grade 70 Transport Chain - yes overkill at Working load limit 11,300 lbs, but safety first.
Use 1/2" - 5/8" Ratchet Chain Binders they seem to make things tighter.
Lastly if you want Block the tires.
Do you know how much 1/2" chain weighs and costs? I used 4-3/8" chains to boom down 60,000# excavators.
/ How do you tie down tractors when hauling on a trailer? #13
Probably mis-type on the chain size. Making the "X" front and rear, with chain and binder is a good idea, even if it is not required for under 10,000lb weight.
I use two chains, but they are 20', and I can still make a "X". If one corner gets loose, the other three corners still hold.
I started with ratchet straps. They just got knicked up to easily, especially around all the angular edge on a tractor. I only use them for lumber or hay now.
you were kidding weren't you? any compact that can fit on a 14' trailer is going to be pretty light. i use two 5/16" grade 70 to tie mine down with the loader and backhoe. four 1/2" chains would seem ridiculous. good 2"x1/4" nylon ratchet straps would be plenty adequate too.
i think that the actual model he listed later would be no more than 2500lb with the loader and fluids. kubota lists the tractor at 1550lb - i had to check multiple places, because that just seems ridiculously light. my 24hp jd770 lists 2100lb, and i can't imagine how a similar sized one can be 550lb lighter.
/ How do you tie down tractors when hauling on a trailer? #14
Towed this back home for at 60mph for 140 miles and it didn't move on the trailer.
Strapped the front wheels to each side and pulled the rears to the lashing points at the rear
I always strap the wheels to the trailer then it aint going anywhere, if you pull it to the front with the strap and then pull it to the rear with straps its good and you can always stop after a mile or three and pull them up a click
Best vehicle I ever had on the trailer was a two and a half ton AA van. For those of you who do not know, the AA is Britains premier vehicle rescue service:D
/ How do you tie down tractors when hauling on a trailer? #15
I am curious to know how various people do this -- I am looking into hauling a CUT on a 76"x14' landscape trailer (tandem axle with wood decking and rear gate). This trailer looks ideal for me, but doesn't have tiedowns, and of course with a wood deck there are no chain slots.
I know landscapers around here don't even tie their equipment down for local transport -- they drive on and set the brake.
Don't know what state you are in but here, if its on a trailer it has to be secured. If not its ticket time. I see a lot of zero turn mowers not secured on trailers. They are taking a big risk.
To be extra safe use 4 5/16" chains (or straps) even though only 2 are required under 10K. Some people cross the chains others don't. Either way is OK. Chains or straps can connect to the stake pockets. If you don't have pockets you need to add some D-rings to secure the load.
/ How do you tie down tractors when hauling on a trailer? #16
This is where it gets out of hand though -- my current vehicle, which is paid off, has only 50K miles, and something I am happy with, has too low of a towing capacity for everything. So now I get into needing a bigger tow vehicle. This is a good time of year to buy an F-150 in terms of discounts and tax purposes, but of course I will look around for used options as well.
Anyhow, a $16K tractor purchase is blossoming into a $40K life changing event.
Thats the way it works. But hey, you are making money. Not!!!!
Chris
/ How do you tie down tractors when hauling on a trailer? #17
I see you are beginning to understand.
As for the trailer purchase, I'd recommend you get the 16' trailer. I have a tractor even smaller than yours. Mine is a Massey Ferguson MF 1215. It's 2500 lbs. soaking wet with a loader, implement and a full tank of fuel. I ended up with a 16' tilt trailer with two 3500 lb. axles. I'm even considering adding a 2' fixed section to the front of the trailer to help distribute the load. I had a 14' trailer for a while, but it just didn't give me enough room to position the load, especially when I had my bush hog mower on the back.
The 16' is worth it.
As for the truck purchase, you don't have to get it now. If you're looking for an excuse to trade up go for it, but you can safely pull a heavy rated trailer with a lighter load. Get the heavier trailer so you'll have it when you eventually trade in your truck.
A 16 foot trailer will probably be about 1500 to 2000 pounds. Add your tractor and your load will probably stay right around 5K. What's your current truck rated for?
Chris
In my head, I figure on saving a good chunk of money doing construction on our new land by having my own small tractor. Probably $2-4K up front when I put in the driveway entrance and culvert myself. Then $10-15K when I do part of the clearing and site work, and $10-15K at the end when we do the grading and landscaping ourselves.
I can definitely cover the costs of the tractor and trailer with the savings, and my wife even agrees with me there. It's that new tow vehicle that is going to be the problem. I can get a good deal on an F-150 and depreciate it with tax deductions through my business, but there will still be at least a $25K outlay to buy the truck when all is said and done. That's a tougher one to swallow.
My current SUV (Acura RDX) is rated for a pathetic 1500# towing. That even surprised me when I checked, because I have been hauling 2000-2200# (gross, including trailer) loads of gravel thinking it was OK. I was basically just staying within the limits of my existing trailer and not even realizing that the vehicle had such a low rating.
After asking around, I understand that the vehicle is very conservatively rated, and I was probably fine with the loads of gravel. But even if I get a trailer with brakes, there is no way I will be able to haul a tractor -- not even close. So it's just not a good vehicle for what I need to do. The problem is, it's paid for, has low miles, and I like it otherwise. Not an ideal situation to think about moving into a bigger truck.
/ How do you tie down tractors when hauling on a trailer? #20
How often/far do you plan on towing? I you won't be doing much, why not buy an older 3/4 or 1 ton pickup for towing? There are plenty to be had in the $5k and less which would suit you just fine if you are only towing several thousand miles a year or less. A lot cheaper than buying something new that you don't need most of the time just to haul on occasion.
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
2016 FORD F-350 XL SUPER DUTY EXT CAB TRUCK (A59823)
2016 FORD F-350 XL...
MASSEY FERGUSON DL250 FRONT LOADER (A59823)
MASSEY FERGUSON...
INGERSOLL RAND  G25 GENERATOR (A60736)
INGERSOLL RAND...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
