Portable Torch Kits?
/ Portable Torch Kits? #1
Timbow
Kubota L3010GST
Anybody purchase or own a Chicago Electric Welding Systems, Portable Torch Kit with Oxygen and Acetylene Tanks for use heating frozen nuts and bolts and very minor welding repairs and fabrication around the farm and have comments they would like to share. I can get the tanks filled at Tractor Supply. Any problem with this welder?
/ Portable Torch Kits? #2
I strongly suggest avoiding cheap offshore OA kits. I destroy them if I get them in an Ebay lot. I've seen enough bad seals and poor workmanship that I don't trust any of them and will not inflict them on anyone else.
If seals or diaphragms fail, leakage can cause fire and that ain't good.
I took some pics of the last combo torch to cross my path:
Why I buy US-made torches! - Shop Floor Talk
I've used, maintained for students, and recommend the inexpensive (but made In USA) Smith Toughcut outfits with a CGA-510 fitting on the regulator. They are "entry level" but reliable for many years and you may never need to exceed their capacity. If you do, the regulators will support a much larger torch.
If you get the Acetylene kit you can then get a LP cutting tip and use either gas. Throw the included goggles in the trash and get a tinted face shield instead. Goggles are uncomfortable and don't protect your face.
Tanks are exchange items, so I buy those used off trade papers or Craigslist making sure they are ones I can exchange at my local welding supplier. There are articles on tanks on weldingweb, the Hobart forums, and the Miller welding site so I won't repeat them here.
Portable outfits are handy, but the small cylinders don't last long so I suggest getting the largest you can comfortably roll around. A modified hand truck works well. You can carry a BBQ LP jug for cutting and heating fuel, and save acetylene for welding if you like.
Monckywrench
After your advice and second thought on Acetylene gas welding equipment, my primary concern needs to be safety, reliability and then cost. There are times where the consequences of failure due to going cheap far exceed any possble cost savings. Thank you for taking the time to reply.
Timbow
/ Portable Torch Kits? #4
Happy to help.
I wish I'd gotten into Oxy-Acetylene and Oxy-Propane years before I did since it's extremely useful. The equipment pays for itself very quickly.
Irish Fixit just posted these outstanding torch cutting videos, and note he's using a small combination torch. I can't cut near as pretty as that, but the vids supply info that's hard to get except in-person:
How to use a cutting torch - WeldingWeb™ - Welding forum for pros and enthusiasts
/ Portable Torch Kits? #5
i'm currently using the HF HD torch kit ( not the bottles.. just the gauges and manifolds ) that I got? a couple ys ago. working fine..
soundguy
/ Portable Torch Kits? #6
I'm sure most of them work. If the seals ever mess up you can use O-rings from other makers. I used Victor seals to test the example I put to death and they fit fine.
I still like myself too much to take the chance. Fire is hot, and if a leak oxygen-saturates your clothes that can get real ugly.
I'd nail a used or new entry-level set of US gear instead. For example easygo got a nice deal for $120, and I know from experience selling torches he could get a nice chunk of that back and keep one set.
For no fiddling the Smith outfits are around two bills and good for decades. They have nice precise regulators and are a pleasure to use.
I'll save money somewhere else, like with the stuff I make with quality tools.
/ Portable Torch Kits? #7
I didn't know if I was going to really 'get into' using a torch.. I used a 20% coupon one day when the manifold set was already on sale. back when you could do that. got them cheap... I do like having a set of torches now.
If they ever have a problem. I'll get a victor set.. I see them for about 200$. the set i have is a victor clone anyway.. same tips..e tc..
my bottles are tsc / thouroughbred / gas pony. owner bottles.
soundguy
/ Portable Torch Kits? #8
Does Smith still require using their cutting tip? Or is there a newer version where you can use the Victor style tips?
I bought a Smith 3-hose machine torch, and 3 or 4 tips about 10-years ago, and haven't used it yet.
/ Portable Torch Kits? #9
Smith require the excellent Smith tip-mix tips. Generics exist too. Examine your Smith to ensure it doesn't take the old LC tips as opposed to the recent style. If it does, there is a conversion kit for those tips which I've used on a Smith LC and on a Meco Cutmaster torch. Both go cheap on Ebay because folks don't know you can still get conventional tips (with some searching) and this adapter system.
http://weldingweb.com/showthread.php?t=49243
Victors have an internal mixer in the tube which feeds the preheat holes in the their tip so "no swappee" even if the heads were magically switched.
Plenty of tips to be had on Ebay and online for both styles. Do a "best prices" Google search for vendors.
We had students beating the guano out of the small Toughcut kits I recommend, and the tips lasted an impressive amount of time. A user who actually cares about not beating on the equipment will get excellent life.
Smith resale is excellent too, not that you'll want to unless you accumulate too many to use. Check what their torches go for on Ebay. I wait until someone takes poor photos which drive down the price.
/ Portable Torch Kits? #10
I've had my Victor torch for about 30-years now, still works great! But I don't use it for a hammer, I have a lot of hammers. :laughing:
/ Portable Torch Kits? #11
I am also a fan of smith. I have a blueshield torch kit (air liquide house brand, very nice one), and I got a smith aw-1 aircraft torch. I almost never use the blueshield, as I dont do much torch cutting, and the smith is much nicer for welding. With the thin hose, small handle, and smaller tips, it is very good for sheet metal.
I purchased a Victor CutSkill Portable Totes with bottles online and on sale from Sears last night for $384. About $100 more than the Harbor Freight model, but well worth the extra money being able to get tips and supplies, face to face support at local welding supply stores and at from Sears stores several years down the road.
/ Portable Torch Kits? #13
Victor regulators are compatible with LP per an email from their tech support.
So are Smith. When in doubt, contact your manufacturer!
I asked this regarding their smallest "tote" regs since I like portables for going out to do quick, small jobs.
1/7 Acetylene Withdrawl Rule - WeldingWeb™ - Welding forum for pros and enthusiasts
Subject
Victor Acetylene Regulator - SR160AR-200 (MC) Rear Entry - Light Duty question
Are the internal "soft parts" in these compatible with propane, propylene, etc fuel gases as are those in the larger series Victor regulators?
I wouldn't expect cheaper seals in the light-duty equipment, but better to ask and be sure.
I understand the pressure range is less, but I don't need to run any of my equipment at pressures beyond the recommend range of this regulator.
Yes you are correct . Our fuel gas regulator are compatible with all fuels. You can use a Acetylene regulator on a LP gas cylinder but not a LP gas regulator on a Acetylene cylinder. The reason is of the delivery pressure is to high for Acetylene and this can cause a explosion. And as for the pressure setting there should never be any reason to need more pressure on a Oxy/ Fuel setup.
Hope this helps.
Ronnie Reynolds
HP&I & MANIFOLD TECH
800-569-0547
/ Portable Torch Kits? #14
The Problem with the higher end professional torches is that they Last Too Long for what you pay. Torches like Smith, Victor and Purox that sell for $300.00 can be passed down in your will. Granted they are treated like they deserve.
/ Portable Torch Kits? #15
HF torch kits generally have generic tips you can get at your local supply house. IE.. victor generic.
at least my kit did.
/ Portable Torch Kits? #16
Or more than one will. They are designed for harsh jobsite use and many designs are little changed since the 1920s and '30s!
Keep an eye out and you can score.
My most recent Smith SC 229 was forty bucks shipped. The poor pictures and label under the barrel in this Ebay pic made it look unattractive. Replaced tip, works great. Lifetime warranty. Beats $266 online.
All good LWS will carry at least generic Victor, Harris, and Smith-style tips. I'd rather buy online since it's often less expensive. If there's one in the torch, having two spare is good minimum practice.
/ Portable Torch Kits? #17
1/7 Acetylene Withdrawl Rule - WeldingWeb - Welding forum for pros and enthusiasts
Ronnie Is a guru on Reg specs for sure.. However you can put an LP reg on Acetylene but you need to be very wary becuae it will turn up past the safe regulation of acetylene..So Should you? NO. Can you yes. Change the gauge to a 30psi with the 15psi Red line and set it to the charts. No benifit to going over 15psi on Acetylene anyway..Most people set it too high and add a ton of carbon to the welds and cuts.
/ Portable Torch Kits? #18
Once I seen the picture of your Smith torch I got to thinking, I can't say I've ever seen a combination Smith torch. So I went to their site, yes they do make a combination torch, but I didn't see a rose bud, is there a rose bud that fits a Smith mixing chamber, or will a Victor rose bud fit?
/ Portable Torch Kits? #19
Nope, None of the brands cross over on parts.
2011 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A66736)
2011 Dodge Ram...
19020SFL (A64553)
19020SFL (A64553)
2015 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2015 WINSTON...
(4) ForeRunner 12-16.5 N.H.S. Tires (A64912)
(4) ForeRunner...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
2018 Komatsu D51PXi-24 Crawler Tractor Dozer (A66734)
2018 Komatsu...
