Snow 2/4wd lever?
/ 2/4wd lever? #1
timmydk
Kubota BX23
I'm a newbie tractor owner.Bought a Kabota BX23 I pretty much know how to move it, but is there a control lever for 4/2wd. Also do you know a good pdf source for owner manual,and service manual. Thanks
/ 2/4wd lever? #2
dealer is a great place for manuals, if pdf available they'll let you know. Not sure on 4x4 lever but certain there is one. just google.
good luck,
Joel
/ 2/4wd lever? #4
For what it's worth, this forum is the KIOTI forum. There is a Kubota forum too, which will help you with any Kubota questions in future.
/ 2/4wd lever? #6
Congratulations on your new tractor! I haven't looked for a source for those manuals since I already have them for mine. However, I can offer you this I found (for when you may be doing maintenance or repairs) that you may want to bookmark this site that has the parts manual.
Index of Kubotabooks/Tractor Parts Manuals/
/ 2/4wd lever? #7
This might be of some help, look at the bottom of the page for manuals.
Kubota BX Service
/ 2/4wd lever? #8
I have a B7510 and a B3200. On both tractors if you are sitting in the seat the lever closest to the seat on the right has an orange/red handle. The icons show 4 wheels. 2wd is the icon with the white space in the driveline indicating you are using the rear drive wheels. 4wd icon shows them all connected. Stop the tractor, use the clutch if you have one and move the lever to the position desired.
Disengage 4wd when driving on hard surfaces - concrete, asphalt, etc. You will have fewer issues if you only shift into 4wd when you actually need it. A heavy load in the FEL causes the rear end to be light. 4wd will give you better control in that situation.
Your BX should be similar.
The yellow handle engages/disengages the PTO.
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
JOHN DEERE 8' OFFSET DISC HARROW (A64276)
JOHN DEERE 8'...
MASSEY FERGUSON 2605 TRACTOR (A64276)
MASSEY FERGUSON...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
John Deere X380 Riding Lawn Mower (A66285)
John Deere X380...
SITREX DM-7 - 8 1/2 FT HAY CUTTER (A64280)
SITREX DM-7 - 8...
