Narrowed Down to JD 3032e and Bobcat CT235
   / Narrowed Down to JD 3032e and Bobcat CT235 #11
In the case you mention with a John Deere actually being a Yanmar because it has a Yanmar engine is like saying if you pull a duramax diesel from a Chevy truck and put it in a ford the ford becomes a Chevy because that's the engine it has. Kioti makes bobcats frame, the hood, the cab, the ROPS, the loader. They make the whole tractor. Yanmar makes an engine and John deere designs and builds everything else. The loader, frame etc.
Some JD models were ( and maybe a few still are) made by Yanmar.
I have a John Deere 850. It has been a good tractor.
I pretty sure it was made by Yanmar and not just the engine. The entire machine.
   / Narrowed Down to JD 3032e and Bobcat CT235 #12
Not to start a debate about this but the entire tractor is made off of the Kioti frame and chassis and is fairly well identical besides paint. You will even here of bobcat owners getting scratches on their machines and it being Kioti orange underneath. To make the same example with John Deere, John Deere owns hitachi construction who makes excavators. They are identical except color. Not that it matters I would just prefer the original. No real reason beyond that. One of the rare situations that the bobcat actually has a bigger brand name than the who they are having the tractor made by, Kioti. In the case you mention with a John Deere actually being a Yanmar because it has a Yanmar engine is like saying if you pull a duramax diesel from a Chevy truck and put it in a ford the ford becomes a Chevy because that's the engine it has. Kioti makes bobcats frame, the hood, the cab, the ROPS, the loader. They make the whole tractor. Yanmar makes an engine and John deere designs and builds everything else. The loader, frame etc. Not that bobcat/Kioti is a bad thing. If I were to get either of those I would get a Kioti. If I were to get any of the three I would get a Deere. But now were completely off topic.
And btw. Deere makes its own engines for most of its tractors on the 4x20 series and up.
Since you do not want a debate, I will just say that you are flat wrong
They are built on the same line, but they are purpose built for each company
Why in gods green earth would they paint it orange, and then paint it white.
That is ludicrous.
Daedong- Korea makes both tractors Orange for Kioti and White for Bobcat
Please read up on it before you respond
As far as Deere, I did not state which models are Yanmars, I simply said many (should have said some) are. Some only engines, some from the tires up.
I know, I almost bought one a few years back
   / Narrowed Down to JD 3032e and Bobcat CT235 #13
That is ludicrous.
What's different between kioti and Bobcat?
   / Narrowed Down to JD 3032e and Bobcat CT235 #14
50 different items according to Bobcats published literature
Mostly nickle and dime some (like the FEL) totally different
O, and what company first developed the industry standard quick attach?
I forget..............
WAIT, that was BOBCAT!!!!!!
   / Narrowed Down to JD 3032e and Bobcat CT235 #15
You are resting your argument on the loader being different?
   / Narrowed Down to JD 3032e and Bobcat CT235 #16
That is ludicrous.
I heard of it with the attachments and it is probably due to an inventory issue, Kioti has excess inventory and Bob-Cat has none so they quickly send some attachments to the paint shop rather than making more.
   / Narrowed Down to JD 3032e and Bobcat CT235 #17
That's probably THE ONE major problem with just-in-time systems.
You save in inventory costs, but without enough slack built in, any interruptions will cause the entire system to grind to a halt.
Someone on the Bobcat assembly line messed up. But someone else made an evaluation on diversion vs waiting for their system to catch up and then made good decision to divert excess from the Kioti line through the paint department and back to the Bobcat line.
   / Narrowed Down to JD 3032e and Bobcat CT235 #18
I doubt that they have separate lines for Bob-Cat vs. Kioti. Modern manufacturing allows different models to be assembled on the same assembly line.
   / Narrowed Down to JD 3032e and Bobcat CT235 #19
The only Deere tractors left that are designed and built by Yanmar are the 2x20 Series. The new 1 Series, 3E Series and 3x20 Series all use Yanmar engines but the rest of the tractor is designed and built by Deere. The New 1 Series and 3E Series even have Deere transmissions!
   / Narrowed Down to JD 3032e and Bobcat CT235 #20
I'm not saying its a bad thing. Just if I were to get one of the two I'd get a Kioti as it was the original. I don't like it when another company just adds another color to the industry. They are doing nothing more than adding clutter. More options are a good thing but they are the same tractors with different paint. There's nothing wrong with a Bobcat, I'd get a Kioti if I were to get one of the two.
Back to the OP's question though I would advise the 3032E. A Deere is just a much better tractor IMO.:thumbsup:
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59905)
2018 FREIGHTLINER...
1999 John Deere 7810 (A60462)
1999 John Deere...
3ft Metal 5-Point Star (A59231)
3ft Metal 5-Point...
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
