Help Choosing a Tractor: Mahindra 1126 vs. 2126 on Hilly 5-Acres
   / Help Choosing a Tractor: Mahindra 1126 vs. 2126 on Hilly 5-Acres
I have a larger Mahindra, made in 2004. My issue has been when I need parts it takes months often to get them, now my repair dealer is not a Mahindra dealer so that could be the issue.
I have heard about that with them. The dealer we are talking to is an actual Mahindra dealer and only sells their product so "hopefully" its better. But I know I'm always taking a chance.
You can buy an inexpensive digital level to measure the steepness of your slope. If it really is 30, that is where few machines are rated for that. That is where Ventrac, Steiner, and Power trac machines are rated.
Cub Cadet also makes some slope mowers but I don’t recall if they make one rated for 30 slope.
I will have a look at something like that. Thank you for that suggestion. I'm not sure if it is that steep, however even walking up the hill it was steep and we were both leaning forward a lot to get to the top of the property
   / Help Choosing a Tractor: Mahindra 1126 vs. 2126 on Hilly 5-Acres #23
My wife and I have talked about not even bother mowing that part and just letting it grown in.
In some of our "I really don't want to mow that" (for various reasons including laziness hah) spaces we've been looking at some of the lower growing meadow/clover/wildflower mixes. What works seems to be pretty climate specific and I don't have experience of any duration so can't make meaningful recommendations but it might be something to see if there's anything for your region. We've gotten some decent looking advice from the local university extension publications as an initial place to look.
Marty889,
Sorry for not responding sooner. Weather in NC is abnormally cold and wind chill is brutal even for someone who grew up in New England and likes to go skiing when every one else flees from the slopes due to the cold. You can ski faster when the slopes are clear of obstacles. :D
I can only provide my experience with the machines I own or have spent ample time on my personal property or help a friend in need as I do not do commercial work or farm. The Mahindra Max 24 TLB ( closer to 2123 and 2126 model than the 1126 ) is clearly a machine where cost to consumer was paramount and Mahindra cut some very significant corners when compared to the Kubota B26TLB.
Kubota uses metal tubing in hydraulic runs and hose where flex is needed whereas Mahindra uses long runs of hose everywhere and hose is more prone to damage than tubing. When damaged the time and cost to repair these long runs is expensive.
Mahindra does not protect the hoses underneath the machine. I know this because I ran over a stick, breaking it and the stick penetrated the hydraulic return line and the entire resevoir of hydraulic fluid quickly dumped itself onto the ground.
Kubota's backhoe valves are set up so that multiple actions can occur at the same time ( ie boom sweep and bucket curl) whereas Mahindra's valving only allows ONE action at a time so the motion is very jerky.
The FEL ( Front End Loader) on the B26 will roll back much further than the Mahindra which allows the B26 to carry a full volume closer to the ground and thereby the machine is more stable. The Max 24 FEL must be raised substantially higher to carry the same volume without spillage and machine is less stable due to higher weight.
The Max 24 throttle is a lever on the steering column that requires significant effort, even when new, to change the throttle setting whereas the B26 is smooth and easy even after a decade.
Kubota is very conscientious about ease of machine maintenance so the grease nipples are well positioned for ease of greasing and nipples are protected by steel collars so they are unlikely to be damaged. Mahindra Max 24 grease nipples are not protected and are pain to access Ive got one nipple on Max 24 that requires a very small right angle bend in the grease gun nipple clamp to access the nipple.
Ive broken the hoses off of the Mahindra's outrigger ( stabilizing legs on backhoe) becasue the hose connection to the piston was not protected. Kubota adds protective metal shields where hoses and connections are at risk of damage.
I view equipment in this way. Initial purchase is one cost BUT, in my opinion, the ease of use is a much bigger cost because if the machine is easy to use then you will be much more productive and happy with your machine far into the future. I will not buy another Mahindra product but I will and have bought more Kubota product ( a KX080-5 two months ago). I've had the Kubota M59 since 2012 and it works as well now with thousands of hours as it did with 230 hours. The B26 is just a smaller version of the M59 and it is as smooth and well laid out as the much more expensive and larger M59.
I've added Max 24 pic to show the hose runs. If you carefully look at the 2123 and 2126 you will see the same type of hose runs.
ps. A tractor used for mowing a 30% incline is going to have much higher center of gravity than a zero turn lawn mower. I personally am not fond of trying to make a tractor do what a lawn mower can do better UNLESS you have lots of nearly flat land and are farming. Cutting and bailing hay is not mowing the lawn
pps. Here is link to % grade and within the article is information about the hosepower to climb various grades. Somewhat applicable to your mowing and similar to another answer about needing lots of horsepower to both climb and power a mower. I'm still of the position a tractor is not a good lawn mower.
Hope this helps.
Wow, thank you for such a detailed response! I appreciate that greatly. We will have a close look at those different options!
   / Help Choosing a Tractor: Mahindra 1126 vs. 2126 on Hilly 5-Acres #25
The 1126 is an all new model and completely different from the emax. The emax is a tym red painted stepchild. The 1126 is made by Mitsubishi in Japan vs South Korea like most others including a bunch of JD’s. With 26 hp it technically has more power than all manufacturers larger non regen sub compacts as well as compacts. Apparently Mitsubishi sunk $30 million into small diesel engine R&D to extract more power and efficiency while meeting EPA requirements. Parts may be an issue as mahendra doesn’t even have the owners manual on their site yet. Looks like a very nice tractor and priced to break into the market.
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
2012 FORD F-250 SUPER DUTY (A58214)
2012 FORD F-250...
2003 Hummer H2 4x4 SUV (A56859)
2003 Hummer H2 4x4...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A56435)
2025 Wacker Neuson...
2018 KENWORTH T800 HOTOILER (A58214)
2018 KENWORTH T800...
