6010 connection everlast pro 200
/ 6010 connection everlast pro 200 #1
ejensen
john deere 850
I do understand that 6010 is a welding electrode. How is the 6010 port used on the everlast 200? Does the lead with the electrode plug in here? Where does the other lead go? Positive or negative plug in.
/ 6010 connection everlast pro 200 #2
The ground (work) goes in the 6010 port. There should be a little diagram on the machine above the ports that shows this. Just checked - there is a "-" sign between the two "-" ports.
If you put the stinger in the 6010 port and the ground in the "-" port then both leads will be grounded and you'll get nothing.
If the stinger is put in the 6010 port and the ground in the usual stinger terminal (there should be a big "+" sign above it) then you have straight polarity. (DCEN, DCSP) The machine can be used this way for shallow penetration or hardfacing.
I'd recommend leaving the 6010 port for the ground when using DCEP and 6010 rod.
If using DCEN put the stinger in the unmarked "-" terminal. The 6010 port is set up for a specific set of circumstances and there is no reason to screw with it. Mark from Everlast can elaborate.
Thank you for the information. I just received the Everlast Power Pro 200. In
my opinion it is a great welder.
/ 6010 connection everlast pro 200 #4
You sure you have a 6010 port? I think it is only the power arc 200 and 160 that have that, not the power pros.
/ 6010 connection everlast pro 200 #5
So don't hold us in suspense any longer, how do you like that little PowerArc 200? ;)
/ 6010 connection everlast pro 200 #6
Multi Port 6010 injection? Ports? What in the World ?
/ 6010 connection everlast pro 200 #7
The everlast powerarc 200 has a seperate place to plug the ground lead into, so you can eld with 6010s. Something about inverters not likeing 6010..
/ 6010 connection everlast pro 200 #8
The older model had a 6010 port that gave a higher open circuit voltage I think. The new ones have it built into the normal port.
Ian
/ 6010 connection everlast pro 200 #9
Ian
Actually, I think the newest ones went back to having the 6010 port.
When the ones with only two ports came off of the boat it surprised the Everlast guys. The factory changed it without notification. They called the factory and made sure the next shipment came with the three ports.
Power arc welders, arc welder, arc welding, powerarc welders
Palfinger ILP 3300 3,300lb Truck-Under Lift Gate (A68183)
Palfinger ILP 3300...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
WARREN POWER SYSTEM LIGHT PLANT (INOPERABLE) (A68842)
WARREN POWER...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
1996 International 4700 (A64127)
1996 International...
