Chainsaw cut is scalloping
/ Chainsaw cut is scalloping #1
Combustix
NW WA
Kubota B2710
Cutting some rounds to take to my dad my saw started scalloping to the right toward the bottom of the cut so much that the saw was binding and stalling anyone know why and what causes this? I have a husky 350 with a 20" bar if that matters. Thanks
/ Chainsaw cut is scalloping #2
Your bar is wore out causing your teeth to lean.
Quick fix would be to flip your bar, but plan on buying a new one.
Thanks I do flip the bar as I heard it prolongs the life. I did notice some wobble in the chain while cutting. I guess this is due to track wear?
/ Chainsaw cut is scalloping #5
You might also re-sharpen the chain - It may be duller on one side than the other.
/ Chainsaw cut is scalloping #6
Good point, sometimes that happens with electric sharpeners too. Before I learned to hand file decently I got a few back like that from the place where I took them and it was due to their machine being out of adjustment.
/ Chainsaw cut is scalloping #7
Could be one of several things.
Chain duller on one side.
Rakers not set the same.
Slop in the bar
Wrong guage chain for the bar
bar top rails worn
operator error(trying to force a cut)
I would start with buying a new chain. ~$10, and it isnt like it will go to waste either. MAKE sure it is the right guage for the bar. This is the thickness of the drive link of the chain and the opening in the bar(slot).
It should be stamped on the bar:thumbsup: Most common are .043, .050, .058.
If the chain dont fix it, you have narrowed it to the bar. And for how cheap bars are for that saw, I'd just buy a new one.
If the chain DOES fix the problem, you know there are issues with your other chain and probabally need to have it sharpened.
/ Chainsaw cut is scalloping #8
If the chain has been overheated in the past it will not stay sharp.:)
/ Chainsaw cut is scalloping #9
When we sharpen chains we all have a tendency to do a better job on one side than the other and that could possibly be a problem.
The bar rails also wear unevenly because of the lopsided design of the saw which causes one guide rail to wear more than the other but this can be fixed.
This can be verified by removing the bar & chain and holding the bar up and looking at the rails. Often you can see one rail higher than the other.
If you have a belt or disk sander with a tool rest to lay the bar on first adjust the table so it is at 90 degrees to the sander than pass the bar lightly across the belt or disk in a smooth continuous motion taking light cuts this will immediately show high spots. Keep doing this until both rails are even.
You don稚 need to remove all imperfections just the high spots.
This will put your saw back on track.
Tim
/ Chainsaw cut is scalloping #10
Good post as I have the same problem!
Not to hijack, just curious where you buy your chain at $10??? My local place carries Oregon but they are all $25 give or take.
/ Chainsaw cut is scalloping #11
Here is an awesome tip I picked up elsewhere. Ask the manager of any local places that sharpen chains if they have abandoned chains, most places are sitting on a bunch of chain that no one has claimed past their policy period. Many times they will sell you a pile of saw chain very cheap just to clean out their shelves. One guy claimed to literally have gotten a box of chains for $20.
/ Chainsaw cut is scalloping #12
My local Stihl dealer sells used chains at 1/2 price. Some people just buy a new chain each time rather than sharpen the old one.
Ken
Thanks for all the tips. I think I will go with the new bar. My saw is around 15 years old and I use it for 4 or 5 cords a year. I got a new chain from the logging supply company in town. I stay away from the box stores with all things saw. Though I havnt put the new chain on yet. I'm also cutting up cottonwoods which I had a tree guy cut due to the size. The guy at the store mentioned the cottonwood holds lots of water this time a year and that will dry out the chain even with the oiler. I have noticed that the chain is probably overheating due to the smoke coming from the cut. When I get back to the house will check my old bar, but I'm sure I will get the new bar. I'm hoping it's not operator error. Happy T day everyone
/ Chainsaw cut is scalloping #14
Chains for my saw (24" bar) run me ~$24 at the stihl dealer for stihl chain:thumbsup:
Since he was talking about a husky 350, I was figuring it is onl,y like a 16 or 18" bar, and probabally that 3/8" lo-profile chain?????
I know our 14" trim saw, we can buy a 2-pack of chain at places like TSC or Lowes for ~$20-$25, so I figured his would probabally be in that neighborhood.
But the price is really irrelevant. The point is that money spent on a chain is NOT going to be a waste since it is a wear item and he would probabally buy several MORE chains in that saws lifetime.
/ Chainsaw cut is scalloping #15
Until recently I've always just bought a new chain for my Stihl pole saw. Now I have about 8 chains, & I'm still on the first bar, & the bar seems to work fine.
Any time I've ever had "scalloping" or curving, it has turned out to be a dull chain, well duller on one side than the other anyway.
Since it's free, I would try sharpening the old chain first.
If it doesn't work, maybe then you buy a new bar & use your new chain.
90cummins. I took the bar and one side was higher than the other. Took it to the grinder and got it even. Sharpened old chain and took it out for a spin everything worked good may hold off on a new bar
Okay just got a new bar as well. Should be back up and runnin soon
/ Chainsaw cut is scalloping #18
I rotate two chains on each of my saws and flip the bar each time I sharpen the chain, by hand. Also clean out the grooves in the bar each time I remove a chain to swap it with the sharp one. Check and file rakers every few sharpenings and touch up the chain if in the field, when taking a break from cutting to not tire myself past safe use of the saw.
Check the groove in the bar to make sure it is not bound or pinched anywhere along it's length. If I see a spot where the paint on the bar is burned off or the bar is blue from heat the bar may be overheated or warped or bent, twisted, etc. With gloves one should be able to move the chain on the bar with no binding. Stihl recommends slackening the chain after use because as it cools it shrinks and puts excess pressure on the chain, bar and bearings. synthetic bar/chain oil is expensive, but like anything else it's worth what you pay for in increased longevity of the entire saw's life. I use Amsoil's bar/chain oil.
/ Chainsaw cut is scalloping #19
If you put a new chain on a worn bar you will wreck the new chain and your cut will still be bad. Bars are cheap. After awhile they wear out, and your saw won't cut straight. I went through this exact thing last year, new bar and chain and saw was cutting like new again.
/ Chainsaw cut is scalloping #20
The most common problem is the chain...not sharpened evenly on each side. A good store can tell if you are right handed or left handed by how you sharpen your chain. Sharpening technique is important to a good cut. My guess will be it is just your chain but if it's been along time since you've replaced the bar you may do that also.
2017 DITCH WITCH JT20 DIRECTIONAL BORING MACHINE (A63276)
2017 DITCH WITCH...
2022 EZ-GO ELITE...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2023 BOBCAT L28 ARTICULATED WHEEL LOADER (A65053)
2023 BOBCAT L28...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
