Uses for a grapple attachment
/ Uses for a grapple attachment #1
tpulley
Wake Foest NC
Kioti DK45SE
I figured I would start a new thread. What are some uses you have found for your grapple attachment?
More specifically I am wondering if I couldn't lift up smaller trees I want to clear from a lot. KInda like stick the teeth down into the root bed and rock it back as i push forward seems to me would work ok.
/ Uses for a grapple attachment #2
That works great. I did the vary same thing to clear about an acre of brush and trees up. I was able to remove some bretty good size oaks with a root grapple. The bigger trees were maybe 14" to 18" at the base. I was using a 95hp 4wd. I did bend a couple teeth on a lighter duty grapple. I rented a HD model for $65 for a weekend and it worked better. You can twist the loader pretty good if you're not careful though. Have fun.
/ Uses for a grapple attachment #3
I am also looking into buying a grapple. How is it for removing dirt from piles of brush. I seem to get allot of dirt when cleaning up brush with the bucket.
/ Uses for a grapple attachment #4
If done right, it does a very good job of sifting the dirt out. Of course if the dirt is sticky or compacted like in a root wad, it doesn't do as well. Makes burning brush piles much easier. Also, a grapple is great for tending a burning brush pile. Just be careful of getting too close to the hot spots.
/ Uses for a grapple attachment #6
/ Uses for a grapple attachment #7
I've owned one of these for 3 months or so. I bought it because it was lighter in weight and left me with more loader capacity. I've had no problems with it. Some people wonder if the single grapple is inferior to a double but I haven't found any problems picking things up and holding them. The couplings that come with it will need to be changed to fit your tractor. I think they are set up to work with a skidsteer. I also changed the hoses to something shorter. The cylinder and hoses use British thread so you may need adapters if you change them.
/ Uses for a grapple attachment #9
The add said free shipping you can't beat that but if I lived that close I would also pick it up. Let us know what you think of it.
/ Uses for a grapple attachment #10
I am thinking this is the one for me:
66" LIGHT WEIGHT GRAPPLE SKIDSTEER ATTACHMENT | eBay
I sent the dude an email to see what shipping would cost vs me picking it up. Its about 2 hrs from me.
IMO 66 inches is wider than you need. There are some mechanical disadvantages to wider grapples. 48 works fine for most everyone who has one. 60 seems fine too but the disadvantage with anything wider is that you need two upper grapples which just complicates matters without adding a lot of benefit and especially increases grapple weight.
Lots and lots of stuff on grapples on TBN so no reason to repeat it all here. Just search and you can read for days or weeks.
I have a 48 inch light duty grapple. Works great on my DK40se.
I agree with what you are saying. I was really going by price. The smallest one I saw that had the quick attachement was listed as $900. The 48 inch they listed was for a dingo, toro etc, the price was $599 though. Even better in the price dept if it would only fit.
BTW thanks for posting the pics. This will be its primary purpose...
/ Uses for a grapple attachment #12
Okay, so I have a DK40se also and have been thinking about the purchase of a grapple. I have no idea about the size of grapple I need. If you wouldn't mind and have the time, please explain your reasons for disadvantages and complications to grapples wider than 60 inches. In other words, how does 2 uppers complicate matters? Is it hydraulics? I don't want to dive onto something I would not be pleased with.
I had thought the 48 inch from Wildcat wouldn't fit my tractor so i was overlooking it. I called today to see if the 48" would fit. Since it has the skid steer qa it should. So it looks like next week I am gonna ride up there and pick one up. I will also make the deciscion on the to valve or not to valve and just use the rear remotes. Here is the one I am going with. It saves me an extra $300 which I can certainly use elsewhere.
48" MINI ECONO GRAPPLE SKIDSTEER ATTACHMENT TORO DINGO | eBay
/ Uses for a grapple attachment #14
That is exactly what I would buy today if I needed a grapple for anything from a CK20 to a DK50/55. I have about six years on my Millonzi grapple which is almost identical in construction and it has been an excellent match for both my CK20 and DK40se.
Get'm while they are hot. I cannot believe WildCat manages to sell them for $599 and one of these days they will figure out that the competition is charging $500-1000 more for essentially the same grapple.
/ Uses for a grapple attachment #15
Briefly:
1) lower cost
2) smaller size = more manuverable
3) smaller size = less storage space
4) smaller size means the force of the grapple is concentrated in a smaller area when ripping out roots etc. You have XXXX lbs of breakout force from your loader and you can divide that force by the grapple width to calculate the max force you can exert on a given root/rock etc. Point is that narrower grapples give you greater breakout force concentration which is almost always what you want
5) When raking or pushing with the grapple, with a 48 inch grapple even the outside tines are still lined up or inside the FEL arms. If you hit a stump or big rock with the edge of the grapple there is relatively little twisting force applied to the FEL. With a wider grapple (or bucket edge) if you hit an unseen object with the edge of say a 72 inch grapple you are putting a significant twisting load on your FEL. Not good. FELs are tough but there is little doubt that tractor FELs are designed and engineered for LIFTING, not Pushing. They can push but not a safely as a bulldozer. Consider how a bulldozer's arms are short, stumpy while tractor FEL arms are long and thin in comparison.
6) Although it is understandable that people would think wider grapples will carry more, in practice there is very little difference. Brush is "sticky" so a 48 inch grapple can easily grapple a much larger chunk of brush than is actually contained within the grapple width. 48 inches if fine for any size log for example. Indeed a 48 inch grapple can carry bigger logs because the grapple weighs less so your net lift capacity is greater even though the grapple is smaller.
7) Hundreds of TBN users with 48inch grapples are virtually unanimous that they are happy with the 48 inch size.
8) You can spend the money you save on other implements
9) Small is beautiful
/ Uses for a grapple attachment #16
Ditto to IslandTractor's post. I have a 60" and have said several times that if I had it to do over, I would consider a 48" for most of the reasons he stated. The bottom line for me, based on my experience, is the 48" will do everything I need it to do, so why spend another two grand plus?
/ Uses for a grapple attachment #17
Wow! What a great response!!!
Please excuse the delay. Had to go spend a few days in the woods.
I couldn't have gotten a better explaination from a professional...That's a joke, cause now I'm quite sure you are a pro. I sincerely appreciate your time and wisdom. Just by looking at your pictures, it's easy to see that the 48" is having no problems with moving a tremendous load. Thanks again!
/ Uses for a grapple attachment #19
imdjack99148 said:
I just ordered a 60" grapple for my DS4510 Hope it works out for what I need.
I will need to change out the couplings it comes with the flat face Parker type. Should be able to find them online hopefully.
Thanks
file:///C:/Users/imdjack/Downloads/NEW%205'%2060%20%20GRAPPLE%20ROOT%20BRUSH%20RAKE%20SKID%20STEER%20LOADER%20tractor%20claw%20bobcat%20cat%20etc%20%20%20eBay.htm
Why not get the manufacturer to either give you Pioneer or at least a credit.
/ Uses for a grapple attachment #20
IslandTractor,
He gave me a fifty dollar credit which I thought was fair.
2017 Cat 316FL Excavator (A62679)
2017 Cat 316FL...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
2023 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59914)
2023 KENWORTH T680...
TAKEUCHI TL6R SKID STEER (A65053)
TAKEUCHI TL6R SKID...
2021 Case TV450B (A64126)
2021 Case TV450B...
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
