Mail Box #1 - Good - Bad - Ugly
   / Mail Box #1 - Good - Bad - Ugly #31
Crash, I love your mailbox, but your delivery person may have a problem delivering small packages like medicines and small boxes. You slot won't allow a very big package. Even FedEx is using the post office more and more for small deliveries here. I have the standard sized box and have been considering going to one of the larger boxes because it would make it easier on my delivery person. She is extremely good about bringing packages down to our house for delivery (about 500' driveway), but I could save her some trips with a larger mailbox and bigger door. I have never had any problem with losing my mail or my mailbox being damaged in over 10 years, so I'm probably a little less cautious than you. If your opening was as big as your collection door, it would improve the value of your box in my opinion.
Here are a few pictures of the "Mail Box Row". As you can see there are many "fine" boxes there and all "well mounted' :D:laughing: Only about 1/3 are smashed, have bullet holes, or are falling over. :laughing: Quite a few have a delivery slot that looks like it was cut with a can opener. Sharp edges & the flap folded out.
My delivery slot is just large enough to accept something the size of a CD. I don't get packages or medicine. Or much of anything for that matter. Once in a while I get a check and if it fits through the slot and stays there I am a happy camper. :thumbsup::thumbsup::thumbsup:
Were I building a box for someone else, It would be built to accommodate their needs.
I do plan to engrave a address block out of aluminum and bolt it on securely. Once my paper addresses are discovered, someone will peal them off.
   / Mail Box #1 - Good - Bad - Ugly #33
Jim maybe be a good public relations person for the mail carrier. consider with your skill in making usuable stuff. maybe a wagon type wheel with all the boxes attached so carrier only needs to stop once and spin until yours shows up.
From the number maybe under hung and over the top placed.
Looks like the carrier must sit there 15 min. or more placing mail in proper slot.
Does the new person on the block get the first or last mail box? Looks like one druck driver could take out the whole row.
Need some sun shine have any extra.
ken
   / Mail Box #1 - Good - Bad - Ugly #34
Jim I just came up with a brilliant idea !
Why don't all the neighbors in "THE ***-ociation" get together have you make a much larger version of your new mailbox. Have the mailman stick it all in one (your) box,and they could come over for instance every SAT (10 AM) and have you hand out everbodys mail through a hole in your gate. :D :) :thumbsup: ;)
Providing its legally approved by postmaster general. :laughing:
Boone
   / Mail Box #1 - Good - Bad - Ugly #35
What is this area you live in? I have seen in trailer parks around here where everyone gets their mail at one location they set up a large box thats all keyed like a P.O.Box. It has all the mail boxes in one unit thats stacked up. Of course I don't know if it will work in your situation since the trailer parks I mentioned are owned by one person/company that does this to help the park look better from the road. But who knows, it might be of use to you or someone in the future.
   / Mail Box #1 - Good - Bad - Ugly #36
It was time to put up a mail box. Where the mail is delivered to is near the hwy. Kids catch school bus and then there are the "normal" vandal's".
Wanted it fairly strong and weather resistant. This was the first Mail Box that I have ever built. Even before it was done some minor improvements were figured out, but too late to change the design. Not shown in the pictures is a expanded metal screen that goes inside, should some rain get in, it holds the mail about 3/8" off the bottom of the box.
Most of the cutting, fitting & welding went pretty well. Spent more time finding or looking for tools than actual building. Some of the tools I had just used, laid down and they went into hiding. The pivot pins were zinc coated, even with a lot of sanding & grinding, they still gassed out in places.
Pictures tell the building better than me writing about it.
Really Dumb mistakes!
Most of them came when installing the box. Thinking it was going into soft dirt. Did not point the end of the pipe going into the ground. Put on some good sized wings so it would not turn and 2 pieces of re-bar so it would be hard to pull out. (Forgot to take a picture.) Box to pipe was a very tight fit, with tight holes, a few thousands under size. Another bad idea, Took my light post driver and sort of an after though took the heavy one, 60 /70#. It was not heavy enough, over an hour driving the post. All that pounding partly closed the top mounting holes and flared the pipe out. Did not take a drill, drift or file with me. Another hour pounding the flair out, driving in the mounting bolts. The box must be close to 40 /50#, holding it with one hand while driving in the bolts was a lot more "Fun" than I really wanted. So in only about 2 hours a 1/2 hour job was completed. Naturally the bolt thread were destroyed, so in a day or 3 they will get hammered out, holes reamed and new bolts installed.
Should you need advice on how "Not" to do things, just let me know. Be Glad to "Help",:D:drink:
Pretty heavily built. Years ago I saw people who had a door on the backside to remove mail against traffic and even a little green flag that came up when someone (the mail carrier opened the box) so you didn't have to check it if the mailman had not come. Anyone else see these now days?
   / Mail Box #1 - Good - Bad - Ugly #37
Round here in town (Naples,Fl) many of the condos/apartments/office/busineses have that same set up.
Boone
   / Mail Box #1 - Good - Bad - Ugly #38
Years ago 3 families lived on a dead end dirt road near me, on top of a steep hill that was closed when it iced up or snow got too deep. They usually parked a car at the bottom and took a tractor down if someone had to get out. One even had a garage down there. Their mail was delivered at the bottom of the hill on a different parallel road, in boxes attached sideways, to a cable set up like a clothes line trolley at least 300 ft long. They had handwheels at the top and would crank the boxes up. To avoid cranking it up if there was no mail, they just had small spring loaded rods with a flag on the end that was released when the mailman (or little p-pots) opened it and then would reset the flag before sending the box back down.
They finally got regular service in the early 60's when the steep grade was flattened and road paved.
   / Mail Box #1 - Good - Bad - Ugly #39
Officially they are called "Cluster Mailboxes" and that's all the USPS installs in new housing developments here. I call them "Gang Bang Mailboxes."
Looks like the Afghan army.
   / Mail Box #1 - Good - Bad - Ugly #40
BIL near Peterborough mounted his mailbox on a chunk of 1/2" wall 4" pipe full of and embedded in concrete. Five years later the township wing plow caught it. Would have been a disaster if there had been oncoming traffic as the rear end of the truck wound up well over in the other lane (according to the skid marks) before the truck drove into the ditch...
I used to have a wooden mail box post. I lost track of how many times MODOT knocked it down when pushing snow. The last time I stood in the driveway and watched. I had just finished pushing the snow clear back into the ditch at least 100 ft each side of my box. Truck driver lifted his wing when he got to where I'd cleaned, continued down the road without swinging out around my box, knocked it clear up on the snow I had piled.
I decided I'd had enough. When Spring came I sank an 8" 1/4" wall pipe in a hole full of concrete and poured the pipe full. Then built a heavy steel arm for the box to sit on. I stopped by the local MODOT barn and talked to the Supervisor about my new mailbox. Funny thing,,,,, ten years later and they've not hit it once....... Go figure......:thumbsup:
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
Kubota L4701 (A53317)
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2019 Chevrolet Tahoe SUV (A59231)
2019 Chevrolet...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
