Wild KAT attachments
/ Wild KAT attachments #11
Rather than putting expanded metal on the grapple itself, how about just adding it to the grill guard? That way it won't obstruct your view.
Actually, that was the plan when I bought the 4'x8' sheet of expanded metal, but I couldn't figure out an easy way to do it and still cover all the vitals.
Putting it on the grapple itself was really simple. It didn't seem to block my vision much when I tested it out.
I'll wait to see what MP comes up with before I do the grill guard.
/ Wild KAT attachments #13
There's a 3/8" gap between my loader's locking lever's pin & the implement's locking notch surface that keeps the bucket from being secure. I can wiggle it all around by hand & have to figure someday it'll fall off unless I modify it.
Yeah, I've been reading about ill-fitting QA SS attachments in quite a few threads lately. There was a lot of talk about shims and such to try to fix it.
/ Wild KAT attachments #14
I decided to go ahead & contact Connie at Wild Kat to see what can be done to make the bucket fit securely, & she responded quickly saying they will make it right & asked for a pic.
No idea how they will fix this, but we shall see. (hopefully)
/ Wild KAT attachments #15
The photo you showed was not what I expected. The pins are obviously short but what you labelled as the 3/8 inch gap reflects the pin length. If the pin were longer that gap would not exist. Was the photo taken with the grapple lifted off the ground? If so then the mount fits and the pin is just short (I think). If the grapple is on the ground then perhaps there is a gap up at the top. It does seem that the mount is pressed against the grapple tightly and that if that pin was another inch longer it would fully engage the grapple mount hole. Is that right?
/ Wild KAT attachments #16
The photo you showed was not what I expected. The pins are obviously short ...
No, they are standard, un-modified pins that are in their locked-down position in the picture, & the only reason they appear to be short is because the metal they should butt up against is 3/8" away, which along with that piece being correctly sloped, that surface is also lower than it should be. I do see that they appear too short, but they aren't - Anything that looks awry in this area can only be from erroneous design and/or construction of this Wild Kat bucket's SS QA members.
... but what you labelled as the 3/8 inch gap reflects the pin length.
I was trying to show that the distance between the pin's sloped securing surface & the equivalent mating surface on the bucket is 3/8".
There is no way to make the pins longer without major mods to the standard Kubota SS QA system, which of course should not be needed. These pins work perfectly with my OEM Kubota bucket, just not with this Wild Kat bucket.
Yes.
Just can not be.
It does seem that the mount is pressed against the grapple tightly ...
It is. In this pic all of the bucket's cantilevered weight is jamming the bottom of the bucket against my loader's SS QA mounting surfaces.
If the pins were longer, my OEM Kubota bucket would no longer fit :eek:
/ Wild KAT attachments #17
Yes.
Just can not be.
I understand your points. What is confusing is that there does not appear to be a gap at the bottom of the grapple. Obviously the photo angle is wrong to gauge that properly so perhaps there is a 3/8 inch gap. The tip of the pin should protrude below the grapple mount. If I am remembering what mine looks like, just a half inch or so is visible below and not the whole tapered part of the pin. That is the measurement I think you want rather than the gap at the back of the pin as indicated in the photo.
/ Wild KAT attachments #18
The dimensions & locations of all the structural members that make up Wild Kat's bucket's SS QA section are just right ... except the metal to the right of the pin in my pic should extend toward the pin by 3/8" more. If the metal was 3/8" longer toward the pin like I'm describing, that metal would contact the pin's sloped securing surface at the same location that it does with my OEM Kubota bucket, & the Wild Kat bucket would be held securely in place by the pins.
In other words the slot the pin slides down into is 3/8" too wide. The length of the pin may look in the pic like it's an issue, but it's not.
/ Wild KAT attachments #19
Interesting. This whole time I was under the impression that it was the vertical distance that you were talking about. So is the WildKat slot simply wider than the Kubota or is it moved forward? I won't be able to measure my grapple slots for a while but maybe someone else can compare. What is the width or depth of your grapple slot. Did you compare that to the standard one of the posters linked to?
Your problem is a bit harder to fix and will require welding in a piece or building up the area with a weld. A shim on the bottom is what I was thinking was needed but obviously not.
/ Wild KAT attachments #20
I'm not sure, since I haven't directly compared them that way, but I'd guess the Wild Kat slot is wider, but it would be that the Wild Kat's slot is moved backward, toward the rear of the tractor (if "moved" is the case). I'll check it out & report back.
I'll have to measure it. I'll measure the slots on both my Kubota bucket & the grapple.
Not sure what you link you're referring to ...?
Yeah, I can't envision how there's gonna be any kind of quick-easy fix, but I'm awaiting a reply & hope there is one (reply & fix!).
500BBL WHEELED...
2025 30in. Forks and Frame Mini Skid Steer Attachment (A59228)
2025 30in. Forks...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
