Fencing Help
/ Fencing Help #21
Well i built one using 4 x 4's and 1 x 6's. Mine is a yard fence having a top board, a bottom board, and then two making an x shape between the posts. Our ground is alot of clay and so hard auger would only drill so far and thats with my son riding it for weight. So, pour some water in hole and move on to next one, come back and clean it out with hand diggers. When finished, painted it black. When set each post, put one sack of sackrete in hole then topped off with dirt. After four years, looks pretty good from the front, but if you look down the tops of fence its not straight any more. We have used a post driver before building fence. Most of the posts would drive fairly level until about the last few inches and then get off. And you cant straighten it.
/ Fencing Help #22
If this is just an ornamental fence I would suggest vinyl. I have even saw metal stakes you drive into the ground which hold the post upright. That way no having to use a post hole digger at all and no rot. Another option may be to dig holes and fill them all with concrete and put a post connector in the top of concrete before it dries. Again no wood below ground level but as long as wooden post would fit the connection you could still have your wooden fence.
/ Fencing Help #23
I would suggest round posts, for some reason they last longer. I don't know why but I have seen several examples of this happening. A 9" auger will do you just fine and allow you to true your fence a little easier. All of my line posts are 6" and I have done a million of them with a 9" auger bit. Buy a San Angelo bar to tamp with, it will be your best friend and most hated foe by the end of the day!
More than likely the black stuff you are seeing is either creosite or post tar. You can buy a gallon, or 5 gallon, pail of the post tar at TSC. It is supposed to be applied to the part of the post that is in the ground to form a water barrier. It is also applied to the tops to keep water from rotting the post from the top. I don't use the stuff and have not seen where I needed to unless it would be a post in a creek bed. I always top my posts even with an angke to aid in watershed anyhow.
I meant to type 4" line posts...sorry.
/ Fencing Help #24
I have alot of fence. My favorite is the 3 rail white vinyl. I intalled 1320' in 2004 and its still like new ... easy to clean with a pressure washer. I did run an electric wire on the inside, easy to do just screw the insulator to the vinyl post ... that keeps the cows, horse's or what ever away from it.
My least favorite is the 3 rail wood around the house ... the weather is heck on it, boards twist, bow, crack and it always needs maintainence.
I also have 5 strand barbed wire, 5 strand horse wire ... yards with cattle panels ...
Again my favorite is the vinyl ... cost more ... but unless a fire comes thru I don't believe I will ever have to replace it.
/ Fencing Help #25
If I might ask, How Much More?
If my wife hears about it I suspect I am toast...
David
/ Fencing Help #26
Ok, so I am new to all this farming and property owning stuff.
I plan to do some fencing work. 3 board fencing.
Do I use round or square posts? I prefer square posts b/c they are easier to nail baords to.
What size auger bit should I get? I plan to get the 3 point auger attachment at TSC but don't want to buy the wrong size auger bit and have to buy a second one.
I think I will use 4x4 posts if square and round 6" posts.
I see this black stuff on the fencing also. What brand or type should I buy?
What are you fencing in/out? Is the purpose just decorative?
Round posts don't warp like square posts.
What kind of soils do you have where you will be putting your posts?
/ Fencing Help #27
David
Well thats a hard one ... been a few years. I'm thinking the material was close to the $3 a foot at that time or about $4K ... I fiqured it would be the last fence for that 1/4 mile... and it was road side and sure looks good.
Recently I saw on CL a fence company advertising vinyl 3 rail for $5.50 a foot for the material ... discount for large orders.
Now to answer the question ... at the time I think about 20% more than 3 rail wood (treated) ... barbed wire could be bought for $30 bucks a roll and T post where like $1.75 ... good corners where also less expensive than today so a 1/4 mile of 5 strand was cheap.
As for the 3 rail vinyl at first I didn't have the electric wire on it and the cows would put their heads thru to reach the grass on the other side...never broke it or got out ... I didn't like that so up went the wire and solar fence charger.
/ Fencing Help #28
Also if you go vinyl there is a trick to it. Got to be dead on for the 16' rails they have clips to install on the ends to hold the rail into the post.
You can not just pull up a string mark the holes at 8' O.C. and go drill them all cause you will be off and find yourself doing alot of hand digging.
I pulled up 1320' of poly baler twine as tight as I could without breaking ... put in some t-post to keep the string off the ground. Started on one end and blasted in several holes only to find I was reeming them out to maintain the 8' o.c. then I changed up and I used the actual 16' vinyl rail ... laid in the ground centered on the last post installed and then measured the 8' used the hand PHD to start the pilot hole and then another one at the end of the 16' rail and went on 2 holes at a time installing the rails as I went.
I would also go about 100' up the line and get the string height where I wanted it for the top of the vinyl post use a rubber mallet to tap the post down to the string height, plumb the post, pour in sackrete, intall, the rails and move on.
/ Fencing Help #29
Sorry bout that
hedge is what we call it round here
Its actual name is Osage Orange
Osage Orange or the common name here is Hedge Apple is a remarkable wood. You cut it green and it looks like you cut a pipe with sap running out so fast. It is hard enough to creat sparks from a chainsaw chain. It tends to grow crooked and twisted, but if you can find straight enough sections it makes an incredibly durable post. Old timers around here talking about fencing will make the comment, "Osage Orange posts will last longer than the hole."
/ Fencing Help #30
Sorry bout that
I have some of those on the old fence line ... maybe 50 or so years old. Just try to drive a fence staple in one ... impossible to do.
/ Fencing Help #31
I just had to repair mine due to about 10 sections being pushed over by flooding. I used a TSC PHD with a 9"auger for 4x4 posts and I thought it was the perfect size. I have a 5 board design with green mesh wire on the inside. I bought a Passlode framing nailer and staple gun as well as a dewalt battery powered circular saw. It is amazing how fast I could put the fence up after I had the posts in
I struggled with the PHD at first but figured out to use it at a very low RPM and it was much easier. I also bought a chain hoist for my barn. After the PHDs are assembled they are a bear to put on and take off!
/ Fencing Help #32
I fixed that... i bought a vinyl rail crimping tool on ebay...hehe:laughing:
/ Fencing Help #33
Show me ... picture please and I assume it crimps vinyl ... I only wonder where to use it on 3 rail fence. I gotta be educated here ... cause I'm thinking about removing the 3 rail board fence and putting up Vinyl.
/ Fencing Help #34
/ Fencing Help #36
So ... what then? If the rail is to long cut it to fit and put a notch in it too receive the clip?
thats exactly how its done. Thatway if you hit a rock or whatnot while installing, its no big deal as long as you err on the short side. The notch IS the clip. two on each side of the cut
/ Fencing Help #37
Thank you ... if and when I install more vinyl I have to get me one ... wait neighbors always borrow things from neighbors .... ain't that right neighbor!!!
/ Fencing Help #38
Sure, just come on over and i loan it to you....thats only a few miles. Just a stretch of the legs
/ Fencing Help #39
Not that it wouldn't be great to meet thegreat ... and your part of the world sure would be nice to visit. But I think UPS would save me a little time!!
/ Fencing Help #40
or just let the wood silver and age.
Around here, we would paraphrase that to "or just let it rot down" :laughing: I've helped nail up a plank fence, but never set the posts.
Ian
Edit.. nobody's mentioned faced round posts. I think that was what I was nailing to. They plane off a flat spot on the side of the round post to make nailing to it easier.
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
Bobcat 72SDR Seeder (A66285)
Bobcat 72SDR...
2014 MASTER END DUMP TRAILER (A65643)
2014 MASTER END...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
