Clearing land options
/ Clearing land options #11
Mike,
What caused me to rent and do it myself was the cost when I had someone else do it. The guy was good, but I could get more if I did it.
* The hired guy cost $1,500 per acre plus $600 to move the equipment to site. He did five acres and did a good job.
* However; I could rent a Bobcat for $900 per eight hours or $2300 for 40 hours. I could do several acres for $900 once I got use to it, which was on the first rental.
I also only rent when tied to a weekend or holiday, so I do not have to let them have the Bobcat back until after two to four days if on an eight hour rental as they are closed on weekends and holidays.
They give me a break or extra hours/day if there is a mechanical issue that prevents me from using it.
This also helped me on taxes. A buddy of mine in Arcadia, OK wanted to rent one to cut his boundary, but the closest was Abiline, TX. Their cost was less than mine.
I am renting over the Thanksgiving holiday to try to cut a boundary and green trail (for deer/turkey) on our West side 2800 feet x 10 foot wide to the river. I clear up to large trees and then go around them as I want to keep them.
This mulching helps with environmetal issues as no roots are removed thus I do not get in trouble with the NRSC or Corp of Eng as I near the river. Nor do I devert any water as the trucks leave no footprint (per se) and I am not "blading anything" which a dozer or FEL would do.
The mulcher cuts to the ground leaving noting to harm the JD wheels or impede the MX5.
Best to you.
Jim
/ Clearing land options #13
As others have mentioned, use the tree's falling weight to help pop the stump out of the ground. You will make a whole lot more work if you cut them down first.
/ Clearing land options #14
Agree. A CUT based TLB can handle up to 12 inch trees without much difficulty by adding a ripper tooth to the BH. A BH is a big purchase but it adds huge flexibility to have your own and you can always sell it after you finish your job. At the rates that a skidsteer or minitrack go for on daily basis, you can justify a temporary BH purchase for just about any project that is more than three or four days work.
http://www.tractorbynet.com/forums/attachments/185530-added-ripper-my-woods-bh90x.html
/ Clearing land options #15
That is true IT. I have a BH, but am so inexperienced with it that I found the BobCat easier and thus faster. I will be learning the BH soon as my wife has given me one last time with the BobCat rental and only because of a free day.
Jim
/ Clearing land options #16
Jim
I think you will find that a ripper can be purchased for about what you would rent a Bobcat for a day so it is a good investment. I recall that my thread discusses my ripper purchase from Michigan Iron. Great to work with them.
/ Clearing land options #17
Good idea thanks..I forgot abbout the ripper as I have never seen one except on TV and here. I will check into one as to the right one for my JD 3320.
Jim
/ Clearing land options #19
Wish you better luck than I had, once we cleared all but the trees we wanted for the lot before building, within two or three years we lost some to winds, either snapping in half or uprooting themselves entirely. Not particularly strong winds either, but once they were no longer protected by surrounding trees the exposure to weather proved too much for some of them.
The first pic is where we decided to clear cut and replant where we wanted them for landscaping, mature trees (maples / oaks) in the background, can make a nice balance.
Row of spruce to the left of the birch were planted 8 years ago, approx 2 feet tall. Are now 15-16 feet.
/ Clearing land options #20
We had a guy with a D6 dozer come in and clear 1/4 mile long strip to reset our fence line to correct coordinates. The strip was angled from about 10 feet up to 70 feet wide at the lower corner. Took him about a half day at $80 per hour to do it all. He didnt have a root rake for his dozer, just a 6 way blade and therefore we got a lot of dirt in the timber pile. After it dried out for about a year, we had some need for a dozer again and while we had him here, we got him to repile the timber and separate the dirt. Took another 3 hours for that. We had him leave all the big pines and oaks and just take out the scrub sweet gums and small trees and bushes. Total time of about 9 hours time to completed the work and much better than we could do it with out tractors.
Best clearing that I have seen done though is with the chipper.
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
iDrive TDS-2010H...
EZ loader trailer (A56857)
EZ loader trailer...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
Richardton 960 (A60462)
Richardton 960...
2020 MACK PINNACLE (A60736)
2020 MACK PINNACLE...
