Aluminum flatbed for F350
/ Aluminum flatbed for F350 #1
yellowdogsvc
S. Central TX Hill Country
Anyone use an Aluminum flatbed for a pickup? I have a late model F350 and I want to swap the bed out for a flatbed. I have hauled for years with steel beds after I removed the factory bed on F350s but have never tried aluminum. I want to save on weight and make my black truck stand out. I haul up to a 2300 lb bobcat attachment on the back of my flatbeds (with a rubber mat to cushion).
My trailer dealer tells me that aluminum will NOT hold up to hauling things around. I disagree but don't have enough information other than what sales guys tell me. Another dealer tells me the flatbed will hold up just fine. I use my truck's integrated hitch so I only need the flatbed to carry an air compressor, attachment, and a small transfer tank.
Any experiences?
/ Aluminum flatbed for F350 #2
Obviously, aluminum is softer than steel, but aluminum flatbeds/rollback bodies have been around for years and years...
/ Aluminum flatbed for F350 #3
The biggest problem I've seen would be sliding heavy objects across the bed will scar aluminum much easier. Had one friend who felt the need to buff his aluminum bed once a year to make it shine, probably no more time consuming than touch up painting a rusty steel bed though.
/ Aluminum flatbed for F350 #4
Make sure if you do get a bed make sure they order one for a pickup, not a cab and chassis. The Fords have a different rear clip on the 350 up if its a cab and chassis and different frame width.
Chris
/ Aluminum flatbed for F350 #5
Aluminum will hold up just fine to a point. Like DT86 said, you can scratch it. Mostly though, just taking a little care to place your load or throwing a piece of plywood down first for something really nasty and you will be fine.
If you get a bed with a rub rail, be careful if the rail gets pushed in. If you try to pry out a dented rub rail, place clamps over the rail where it is welded to the stake pockets. Those rails take a lot of pulling with nylon straps. Take a crow bar to a dent and the weld can pop right off the stake pocket.
Which does bring up a point. Straps with J-hooks are more friendly to the aluminum then chains. Also, look for standard sized stake pockets. Eby for one makes a smaller stake pocket. Stock J-hooks will not fit in the pocket without squeezing them in a vise.
Brite aluminum is easily dulled out with strong cleaning agents. I don't know the grades but the more "standard" aluminum will oxidize and standard washing will not bring it back. You can find places that will "acid wash" the bed to really clean it up. It is going to look "white" but won't really ever shine again if it ever did.
Overall, I think it is kind of a "wash", aluminum over steel. For a small truck application, I do not see a big savings in weight. Brite aluminum is going to require a lot of cleaning to keep it looking brite. A regular aluminum bed will over time dull out but will be somewhat "presentable" with occasional maintenance. A steel bed requires regular touching up with paint to repair the scratches. I have had both and everytime I loaded something on my steel bed, I would scratch it. Screw ups are an easy fix on the steel bed. The aluminum maybe not so depending on your local welding resources. A steel bed with piano hinges for storage boxes or a gooseneck hitch cover will rust and be hard to keep looking good.
A lot of beds have a simple flat plate that folds over to cover the gooseneck ball if you have one. Eby for one makes a nice cantileverd cover that holds up well.
Lastly, I had a steel transfer tank on my aluminum bed for several years. I placed a piece of rubber horse stall mat under the tank rather than bolt the tank directly to the bed. The mat I used had ~1/8" grooves on the back side. As I said, I place those up. I figured the air space would preserve the steel which it did. When I did remove the tank, the aluminum had not oxidized under the rubber at all.
I say, go with the look that you want. Hope this helps.
/ Aluminum flatbed for F350 #6
Any experiences?
Gooseneck in Bryan, Texas sells some nice aluminum beds.
Gooseneck Trailer Mfg. Co. - Custom Trailers, Frac Tanks & Truck Beds
You might want to run some of your questions by them. They are the manufacturer.
thanks for all the info.. and the link to the manufacturer in TX.
All good points to consider.. Have a black F350.. was wanting it to look sharp.
/ Aluminum flatbed for F350 #8
Two 1996 Ford F350's 4x4,diesel,DRW. One has a steel dump bed and is needing replaced. The other has a alum. flatbed and looks as good as new. Ohio has a rust problem and the results on my trucks favor the ALUMINUM. This being said the aluminum bed came on the truck when it was bought used. Cost may play a factor. Chrome simulators look great on a black truck, but are hard to keep from getting torn off.
/ Aluminum flatbed for F350 #9
I can't add much on the aluminum vs steel problem. I may replace the flatbed on my truck in the next few years, so I'll be watching with interest.
However, if you decide to go aluminum check out Pro-Tech. We have one of their headache racks on a Kenworth at work, and I've been to their factory outside Nashville. They do good work, and the rack we got from them has held up very well.
