Well CR4P!!
/ Well CR4P!! #1
MikeA57
N. Mississippi
Ford 1510
Re-decking my trailer and it's 76" wide. So after careful calculations I came to the conclusion that I needed (7) 2 X 10s and (1) 2 X 12.
According to my calculations and the dimensions of lumber this is how I arrived at what I needed:
7 * 9.25 = 64.75
1 * 11.25 = 11.25
summed = 76
When I put the boards in this evening this is what I came up with after putting in 7 of them. There is no way the last 2 X 10 is going in that slot.
Only thing I can figure is I've had them laid out outside for the last week putting a motor oil/diesel mixture on them. It rained a couple of days and they must've swelled. At this point the only thing I can think to do is go get a 2 X 8 and put it in. Once they dry out some and contract I'll remove it and put the remaining 2 X 10 in. The problem is I need the trailer tomorrow for a hay ride so I don't dare leave it open. The opening that is left open though is 8 1/2" so it's going to be loose anyway but it'll work.
/ Well CR4P!! #2
pull the 2x12 out, go get another 2x10, put 1/4" gap between each board for expansion and contraction with temp changes and call her good
/ Well CR4P!! #3
Rip the remaining board to fit on a table saw, or even using a circ saw. Most trailer decks I have seen have one board ripped to fit.
/ Well CR4P!! #5
A good table saw is a great thing to own. If you were here I fix it up for you in 5 minutes from start to finish. But you can rip a board with a circular saw pretty nicely expecially if you use a saw guide, or If you are very good at following a chalk line you can even do it like that. Good luck.
James K0UA
/ Well CR4P!! #6
Yeah, just rip the last board and your good ! :thumbsup: I rip long boards like that using a couple of saw horses and a woodworkers clamp and then my trusty old circular saw. Works every time. :D Just make sure you got a good sharp blade on it and take your time and it will go through it pretty easy.
Oh, by the way, that's a nice looking new deck you got going on there.:thumbsup:
/ Well CR4P!! #7
I used 2x8's when I redecked my trailer last year. I let them dry out for a few weeks, then I put installed them as close as possible for very small gaps. That way, I can haul dirt without losing too much through the cracks. I did wind up having to rip one board down to about 3" wide to fit the last little bit. I used a regular skil saw, but I screwed a board onto it to give me a guide, so the cut was pretty straight.
/ Well CR4P!!
Well, I went ahead and removed the 2 X 12 and bought another 2 X 10. It was a tight fit but after coaxing it in there it fit Guten-tite. I could've ripped the 2 X 12 but my table saw (which is attached to one end of an 8' work table) was behind a DOA 4 wheeler and a bunch of other junk and I was on a really tight time schedule to get it done. That just seemed to be the quickest option at that point. Got 'er done, loaded the tractor and I was on my way. Now, I just have to get the brakes looked at closer and get a coat of oil on the topside of the boards.
/ Well CR4P!! #9
I just re floored my utility trailer and had the same problem. I wound up ripping the last board for a snug fit. I measured everything perfectly just like you did, but I suppose it is trying to put the dirt back in a hole you just dug. It won't go. Same for floor boards.
/ Well CR4P!! #10
Good thread... I have to re-deck my trailer at some point. The wood is cupping and splitting as it is always sitting over a grass/moisture area. I should really find an area and take the grass/top soil off, lay plastic and a layer of gravel to prevent this from happening again.
/ Well CR4P!! #11
Even better to keep em' indoors in an outbuilding if available. My old hanger building is good for that but most people probably don't have a place to store a trailer, especially a larger one.
Dryer climate verses wet climate is not as hard on a trailer being kept outside but eventually the elements anywhere will do some damage even if stored inside a building, no way around that.
Extreme cold and heat cannot be stopped even by a building unless it's maybe controlled thermostatically.
SOUTHERN FRAC MANIFOLD (A68842)
SOUTHERN FRAC...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
3146 (A63117)
3146 (A63117)
2006 PETERBILT 379 (A67714)
2006 PETERBILT 379...
2019 CATERPILLAR TL6420 TELESCOPIC FORKLIFT (A65056)
2019 CATERPILLAR...
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
