rear led work light on 2520
/ rear led work light on 2520 #1
lowechj
Member
Huntsville, ON Canada
Kioti CK3510SE
Just installed a rear led work light ( 24 watt ) on my 2520, works quite well.
/ rear led work light on 2520 #2
That looks very nice.. Where did you purchase it, how much and was it easy to wire in?
Thanks
/ rear led work light on 2520 #3
Do you have any idea as to how the light output compares to a standard 55 watt tractor light?
/ rear led work light on 2520 #4
I bought two of the same one for my Case 1816. I had two of the round ones, and they worked well for a while. One blew out, and I decided to upgrade the front lights by using the square ones for the front, and moving the one good one to the rear.
I used them for plowing snow and they were great. My decision was based upon the very low current draw. The Case doesn't have a real alternator.
Company is So Brite Lighting in Milton, ON. They come in round or square 18, 24 and 27 watts. Mine is the 24 watt, draws 2 amps and cost $70.00 cdn. My 2520 has 2 wires behind the rear seat that are for a rear light and go directly to the light switch so it was a case of putting two bullet connectors on the light and connecting it up. In the spring I might figure out to put one that would shine forward as I find the fel blocks the headlights when it is up.
Patterson water pump (A59230)
Patterson water...
2016 Ford Escape SUV (A61569)
2016 Ford Escape...
SDLL60 Mini Skid Steer (A64047)
SDLL60 Mini Skid...
2019 Maxx-D 40' Gooseneck Trailer w/ Mega Ramps (A64047)
2019 Maxx-D 40'...
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
