rear led work light on 2520
   / rear led work light on 2520 #1
lowechj
Huntsville, ON Canada
Kioti CK3510SE
Just installed a rear led work light ( 24 watt ) on my 2520, works quite well.
   / rear led work light on 2520 #2
That looks very nice.. Where did you purchase it, how much and was it easy to wire in?
Thanks
   / rear led work light on 2520 #3
Do you have any idea as to how the light output compares to a standard 55 watt tractor light?
   / rear led work light on 2520 #4
I bought two of the same one for my Case 1816. I had two of the round ones, and they worked well for a while. One blew out, and I decided to upgrade the front lights by using the square ones for the front, and moving the one good one to the rear.
I used them for plowing snow and they were great. My decision was based upon the very low current draw. The Case doesn't have a real alternator.
Company is So Brite Lighting in Milton, ON. They come in round or square 18, 24 and 27 watts. Mine is the 24 watt, draws 2 amps and cost $70.00 cdn. My 2520 has 2 wires behind the rear seat that are for a rear light and go directly to the light switch so it was a case of putting two bullet connectors on the light and connecting it up. In the spring I might figure out to put one that would shine forward as I find the fel blocks the headlights when it is up.
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A54757)
UNUSED WOLVERINE...
2016 Ford F-550 Ext. Cab Utility Flatbed Truck (A52377)
2016 Ford F-550...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2018 FREIGHTLINER BOOM TRUCK (A51406)
2018 FREIGHTLINER...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
UNUSED TELESCOPIC LADDER - 2.5M+2.5M (A54757)
UNUSED TELESCOPIC...
