Another Time Lapse
/ Another Time Lapse
I couldn't get the software they recommended to work. Here is what works for me and is easy.
Google Avidemux 2.5. You should be able to find it for free. After you take all of your pictures, plug the camera in to the computer. Open the avidemux program. Under video select MPEG-4 ASP (avcodec), and under format select AVI. Go to "file" then "open". Find the location that shows the camera. Mine shows up as "plant cam". Once you get in the folder with the pictures just double click on photo #1. Should be on the top. It should go back to the avidemux program. Now wait. There is no indication that anything is happening and it could take several minutes depending on how many pictures you took. The first time I thought nothing was happening and kept going back trying to figure out what I was doing wrong. Once it comes up, your video is ready. You can play with the frame rate to make the video longer or shorter and all of the other tools. When you're finished go to "file" and "save".
/ Another Time Lapse #22
Are you close to Abingdon or Gate City?
Right smack dab between Bristol Va and Abingdon. And I have family in Danville BTW. It's a small world after all.
/ Another Time Lapse #23
I was raised 15 miles from Kingsport in the country and worked in Kingsport for many years. We live in the piedmont of NC now, about 35 miles southwest of Danville.Small world indeed.
/ Another Time Lapse #24
I JUST got back from Kingsport for supper and cold beers. :licking:
UM AWS-36 HEADER CART (A64278)
UM AWS-36 HEADER...
2012 HARDEEBILT 827PEQ6 EQUIPMENT TRAILER (A66091)
2012 HARDEEBILT...
2024 KOMATSU PC88MR-11 EXCAVATOR (A65053)
2024 KOMATSU...
JOHN DEERE 285 DISC MOWER (A64278)
JOHN DEERE 285...
Dickson Ind. 4080 SX Turbo Blast Asphalt Surface Prep Machine (A64194)
Dickson Ind. 4080...
UNUSED PARBREAK AR650 HYD AUGER SET (A65055)
UNUSED PARBREAK...
