Snowblower: Width vs PTO hp
/ Snowblower: Width vs PTO hp #21
As it is that time of year again it will not hurt to talk about the speed of travel for a snow caster and its motive power.
The snow caster implement is totally dependent upon-
1. the implement carriers total horse power.
2. the rated horsepower of the power take off for the implement carrier
at the 540 or 1,000 RPM engine speed setting.
3. The rated gearbox horsepower rating for the snow caster implement..
I am familiar with the Chinook winds which batter Stevens Pass in The State of Washington, but I was not aware that they traveled as far inland as your location.
Being strictly dependent on temperature a fresh snow fall can weigh as little as 21 pounds per cubic foot and with freeze/thaw cycles the weight can more than double over time.
The two stage snow caster is totally dependent upon the impeller for its work as the the implement carrier is forcing the snow into the cross auger(s) which conveys the snow to the center of the snow caster where it is forced into the impeller housing strictly with the forward or reverse movement of the implement carrier.
The size of the impeller and the number of paddles in the impeller are what as Kenny Cartman would say "kicks A**" and is the business end of things.
Dependent upon the builder of the snow caster the impeller drum is dependent upon- 1., the number of impeller paddles and thier curvature within the impeller drum if applicable as a curved impeller reduces the amount of snow the snow caster can dispose of and 2., the rotation speed of the impeller at the 540 or 1,000
R.P.M., P.T.O., speed of the implement carrier at the rated engine speed of the for the Power Take Off in the front or rear but I will be using the 540 R.P.M., speed for reference.
In Pronovost's case(yes it is a shameless plug) their snow casters will have four or five or six impeller paddles and the impeller paddles are straight and slightly curved on the exterior edge and have been formed to create a cupping form to carry snow more efficiently to reduce spillage to a minimum(another shameless plug for Pronovost).
The larger the impeller drum in diameter and depth the greater amount of snow can be cast per rotation of the impeller paddles times either 540 or 1,000 revolutions.
Every snow caster will plug and shear pins if the implement carrier is traveling to fast!!!!!
If you travel at three miles per hour you are traveling at 264 feet per minute.
If you have one foot of snow to remove and the snow caster is 7 feet wide you have 147 pounds of snow entering the snow caster each second and 40,000 pounds per minute of snow (rounded higher) entering the impeller and the impeller must be running at its optimum speed(rated P.T.O., engine speed) to to cast the snow away. In the example the snow caster must have the torque to remove 667 pounds per second of the snow fall to keep up.
If you travel at one mile per hour ( I know, boring!!!!) you are only traveling at 88 feet per minute and requiring the snow caster to remove 13,000 pounds (rounded higher)(per minute of snowfall(big snooze, I know) The snow will be cast further and you will have no issues with snow banks. Just like fitting ground it takes time.
@ 21 lbs /cu ft, I get 647 lbs /sec = 38808 lb/min for 1 ft of depth and 7 ft across at 3mph.
/ Snowblower: Width vs PTO hp #22
Herringchoker,
You have answered the question I was about to ask... What is the effect of having an HST.
Seems to me that the infinite control of speed should allow a machine to handle more snow or a larger blower then a gear drive.
Am I wrong in my thinking?
If it is true that the HST can handle more in this case then the gear transmisson, then how much and how should you be running the tractor to ensure that it can handle it?
/ Snowblower: Width vs PTO hp #23
I rounded higher for simplicitys sake. Are you in the Lignite coal portion of the Basin Jerry or near the Wyodak Coal Seam portion?
:thumbsup:
_________________________________________________________________
Pronovost or not at all!!!:thumbsup::licking::drool:
/ Snowblower: Width vs PTO hp #24
Herringchoker,
If its ok with you I will answer that as Herringchoker is off line.
The slower you travel with either transmission type the less shock loading you will have.
An automatic reversing transmission is more tolerant of shock loads but it does
not help much with a P.T.O., the shear pins are there to save the P.T.O., in case of overload. You need to keep the fan running high to pump the oil and power the fan to cool things.
The hydrostatic transmission will allow you to creep even slower to do the job
as less snow will be entering the cross auger housing.
You have to keep the tractors engine up at the P.T.O., engine setting for the mounted implement to work as the gearbox requires this much power to operate efficiently.
/ Snowblower: Width vs PTO hp #25
So the HST might just give you a little more control and allow you to keep the RPMs up at an adequate level to handle the amount of snow entering the the blower...
Thank you.
/ Snowblower: Width vs PTO hp #27
Yes Bruce, it is much faster than a shovel!!!!
/ Snowblower: Width vs PTO hp #28
It will all depend on your location and the type of snow encountered. I would, however, forget a twin auger blower, your TC40 don't have the gonads. Twin augers are for tractors with 100 PTO horsepower on up.
84" rear mount 2 stage single auger and in light stuff (fluffy dry, cold snow, it barely works the tractor, however, busting 4 foot drifts of heavier stuff, it takes every bit of the 90 pto horsepower I have and I can bog the tractor down (and make it blow smoke) fairly easily and I'm turbocharged
What he said :)
/ Snowblower: Width vs PTO hp #29
Thank you.
Your welcome, The thing you must keep in mind is the impeller housing size as I mentioned earlier as the larger the impeller the less plugging AT NORMAL OPERATING SPEED dependent strictly upon snow depth and weight per cubic foot with relation to freeze thaw cycles which will add weight from melt and simple compaction as gravity and heavy snow fall are not your friend.
EDIT: All this mess goes back to the cross auger(s) as the manufacturers are in no hurry to offer solid cross augers as standard equipment OR as an option except for the one or two dual auger models by Pronovost using a solid auger on the bottom ribbon/auger.
If they implemented a solid cross auger with narrow flighting the snow caster would work wonders and cast the snow a long distance
/ Snowblower: Width vs PTO hp #30
Leonz, your explanation was well said. The HST is perfect for jobs such as snow casting, where you have to vary the ground speed to maintain a constant load on the PTO.
BTW, you would lose the wager on where the salt comes from. ;) It used to come from Pugwash, but around here it now comes as a by-product of the potash mine in Penobsquis, N.B. I am about 60 miles northwest of Pugwash and 35 miles northeast of Penobsquis.
Aw, Leonz, planting mums! I just finished cleaning up and tilling the vegetable garden on Friday, which is the latest I've ever done it, what with the mild fall we've had here so far. But that's about to change, based on the latest weather forecast! Hope you get 'er done, sir. All the best! :thumbsup:
/ Snowblower: Width vs PTO hp #31
Can you explain that further?
What do you mean by "solid", and how could that help the OPer in selecting a blower?
I get the impression that it would control the flow of the snow better, but I can't quite see how. Would this make the difference between buying a 72" vs 84"?
Do you have a picture maybe?
/ Snowblower: Width vs PTO hp #32
I have a JD3320 with 33hp. Living in NW Iowa I have had no troubles with my 85" chief snow blower. This thing will eat anything I feed it ( including one of the kid's toys that happened to get left in the yard ) still picking up plastic ......
/ Snowblower: Width vs PTO hp #33
I wonder if thier potash is like everyone elses with the Halite salt bed seam on top of the Potash seam? The folks at Irish Salt have a thick bed of potash they are mining below the salt bed that they are mining as well under the Irish Sea.
Herringchoker, how far are you from the new deep soft coal mine that was recently opened? Are they mining at the five mile depth near where the older workings were?
/ Snowblower: Width vs PTO hp #34
Sure,
The Schmidt picture I have uploaded shows a single stage unit with
a gathering wing but the theory of operation is the same as the auger may
be used to operate that fast feeding the impeller but some experimenting would be needed to obtain the proper speeds for the snow caster auger to feed the impeller.
If you look in YouTube - Broadcast Yourself. for european snow casters you will eventually find snow clearers used for highways and there are a herd of them built and sold for Mercedes Unimogs which are single stage and the casting distance is huge.
The snow casting drum would not have to rotate that fast with a two stage unit but the casting distance would be just as far or further.
A solid auger is nothing more than a grain auger of sorts with
narrow flighting which is the distance between each section
of ribbon on an auger.
The key is having a large diameter drum that the ribbbon is welded
to which limits the amount of snow that can be metered to the impeller
with zero flooding and jamming.
A larger diameter drum and ribbon would be very easy to use and operate
with two stage or single stage rear mounted snow blowers.
If the flights were 10-15 degrees apart and 4 inches deep the snow removal
with a two stage or single stage snow caster would become a zero issue, but the snow caster would cost a bit more to build and purchase.
/ Snowblower: Width vs PTO hp #35
I'm not sure and I stand to be corrected, but I think the salt seam is above the potash.
There's been some talk about re-opening the deep mines on Cape Breton Island (about 300 road miles east of here), but as far as I know that's all it is...talk. Those shafts are out under the Atlantic Ocean. There were also very deep coal mines at Springhill, N.S. (near the Pugwash salt mine) but the big mines closed after the disasters in 1956 and 1958.
/ Snowblower: Width vs PTO hp #39
Herringchoker,
Sorry to but in but the HST doesn't allow you to handle more snow. it allows you to match the blower's capacity to the ammount of snowfall by having a variable ground speed at constant pto speed.
As I stated in my original post, the snow throughput , from continuity, equals the snow depth x the width of the snow blower x the speed of travel. With a geared transmission you if you set the blowers speed to rated pto speed, the speed of travel is fixed by the gear ratio. In an HST, you can tailor the speed of travel (within some limits) at constant engine speed. So it allows you to lower the through put through a drift , for example, by only altering the tractors cround speed and keeping the blower at rated pto speed.
/ Snowblower: Width vs PTO hp #40
:thumbsup:
Your 147 lb per sec must be a typo then.
I live in the Mission Valley .
