Do MIG welder's stink?
/ Do MIG welder's stink? #1
marrt
Northern VA
Power Trac 1845 and 425
Ok, here's a dumb question for you. How bad do MIG welders stink? I've never been around a welder but I have a need for one. I was thinking about picking up a MIG welder and learning how to weld. However, I understand they are very sensitive to wind and I live in a very windy area. So, I would use the welder in my woodworking shop. I'm curious though...will it "stink up" my shop with smoke?
/ Do MIG welder's stink? #2
No, migs are not like stick welders. I weld in my shop all the time with no problems, almost no smoke and smell. The reason wind is a problem is the sheilding gas gets blown away.
/ Do MIG welder's stink? #3
I've got a Lincoln 180 and whenever I weld outside in the wind, I use the flux core wire. It does not take long to switch.
/ Do MIG welder's stink? #4
I do the same thing. Flux core makes a little more mess, but you are outside so it does not matter.
/ Do MIG welder's stink? #5
If you weld inside you can use solid wire with gas,no excess smoke or stink.
/ Do MIG welder's stink? #6
errr... but you do need fresh air circulating.
/ Do MIG welder's stink? #7
You will surely have smoke and iron dust. No way around it. Welding is melting materials and they do create some smoke. You will eventually notice the smoke on the walls..It's worth the trouble though.
/ Do MIG welder's stink? #8
No, not for practical purposes anyway. Argon and CO2 are not going to cause problems at the slow release rate associated with welding. Besides, even if you leave a window or garage door open there won't be enough of a breeze to blow away the shielding gas unless there is a storm outside.
/ Do MIG welder's stink? #9
Im not too worried about the shielding gases, im more concerned with the gases associated with the melting metals. I have a neighbor thats a retired union welder, and hes all messed up with bad eyesight and bad lungs from welding.
/ Do MIG welder's stink? #11
I've never met a MIG welder who smells good :)
Some air circulation is a good thing. Melting metal creates metal fumes to some degree. These are large surface area particles of metal (think microscopic snowflakes) and you don't want that to build up. When welding in my garage I leave the door closed and then open it up when done (usually 10-15 min closed, then setting up the next stuff with door open). Plus I've started wearing a respirator a lot more when welding.
/ Do MIG welder's stink? #12
Must have welded lots of galvanized in his day. Probably from errant arc strikes (bad eyes)....
Yes they do smell! Smells like money to me.:laughing:
Money in or equipment expense out?
If you tried to smell me, I'd slap ya......:laughing:
Try plasma cutting if you want filth. I have a CNC plasma table and it's dirty. Mig is nothing compared to production plasma...
On the OP. Mig is probably the easiest discipline to learn and get good at and new generation pulsed mig machines make that even easier. I look at a mig as a glue gun for metal. A good machine is reasonable price wise and you always have the option of flux cored non shielding gas wire or solid wire with shielding gas or shielding gas required flux jacketed wire which is primarily spray arc.
For ocassional use you still want a 220/1 machine with gas or gasless capability. The 110/1 machines don't have the capability of welding heavier meaterials with the exception of the Miller Passport or the Hobart Trek but both of those machines will set you back as much as a quality 220/1 plug in machine with ample amperage to handle anything you want to stick together.
The Trek and the Passport have the capability of running unplugged (on batteries) so you can weld anywhere, anytime, even if no electricity is available and both have gasless and gas capability.
Just keep in mind that unlike SMAW (stick welding), the materials to be joined must be relatively clean and oxidation free.
Have fun.
/ Do MIG welder's stink? #13
You are describing the Trek. The Passport is a dual voltage suitcase inverter machine and runs on an internal CO2 paintball tank but doesn't have a battery. I love mine anyway.
/ Do MIG welder's stink? #15
I'll bring the marshmallows. ;)
That what I was thinking. Roasted Hot dogs! and get enough for the firemen!
To me a wood shop smells of SAW DUST and PAINT FUMES and SPRAY CANS and thats what bothers me! and Willl
"Fire Hazard"
/ Do MIG welder's stink? #16
Yes I am, the Hobart Trek. Certanily better than car batteries in parallel. The Passport is an umbilical machine but a lightweight inverter based unit nonetheless.
/ Do MIG welder's stink? #17
you got that right....for an electrician a wood working shop ranks nearly at the top for explosion environments......i have to install panel covers that are gasketed even. Thise pesky bits of sawdust are a time bomb.
Just try and find any old saw mills hehe
/ Do MIG welder's stink? #18
While I try to not 'HUFF' any welder fumes.. stick welders by and far smoke more than a mig.
and yes.. since they use a shield gas if in heavy wind.. mig can have some issues. ( stick are maing their own shielding right at the arc :) )
soundguy
/ Do MIG welder's stink? #19
Smoke from a welding operation is not nearly as bad as smoke from a cigarette. To my knowledge, it hasnt been linked to cancer. Likely your old welding friend smoked cigarettes most of his life which contributed to his ill health. I am not saying that you dont need to protect yourself from the fume build up, but it is not like an axe murderer stalking you so just take a few precautions with ventilation and dont sweat the smoke as far as dangerous to your health.
Make sure all that sawdust is cleaned up and no flammable liquids or vapors are harbored in your shop. This is extremely dangerous to work around a woodshop.
/ Do MIG welder's stink? #20
I think flux core mig stinks. I can tell the difference between the smells of 7018 and 6013. Neither are as bad as the flux core mig.
Dan
2014 Ford F-350 Altec Service Truck (A66736)
2014 Ford F-350...
2017 RANCO BELKY DUMP (A67714)
2017 RANCO BELKY...
2005 little wonder high output blower (A64557)
2005 little wonder...
2025 Wolverine ADB-13-1218R Hydraulic Auger Set Attachment (A66734)
2025 Wolverine...
2015 Chevrolet Silverado 2500HD Crew Cab Knapheide Service Truck (A68183)
2015 Chevrolet...
CAT 930 Coupler (A68134)
CAT 930 Coupler...
