Buying Advice Massey 35 diesel
/ Massey 35 diesel #1
asi424
I am planning on taking a drive to look at a Massey 35 diesel with a perkins diesel, new tires with rims sandblasted and sealed. Is there anything unique to Masseys that I should look out for?
Thanks,
Dave
/ Massey 35 diesel #2
Thanks,
Dave
Crawl under the tractor clutch housing and locate the weep hole on the bottom. There might be a cotter pin in the hole. If not, use a small diameter drill or piece of wire to ream the dirt out of the hole. If a few drops of oil come out, not a problem. If you get a steady stream of oil, you may have a bad rear seal on the crankshaft or the oil pan seal might be leaking.
1762 (A58375)
1762 (A58375)
2016 Nissan Altima Sedan. (A61574)
2016 Nissan Altima...
TEST YOUR BID BUTTON! (A63291)
TEST YOUR BID...
2016 Ford F-150 4wd 4 Door (A63689)
2016 Ford F-150...
2 new 10'' Pallet fork extensions (A61567)
2 new 10'' Pallet...
1989 Corvette Convertible (A61574)
1989 Corvette...
