4310 will not start
/ 4310 will not start #1
95fxdl
Member
Ran fine the other day. Today it started, ran a minute, coughed smoke then died. Has about 200 hrs. on it, to my knowledge no maintenance has been done.
Where do I start? Thanks Dennis
/ 4310 will not start #2
First thing is do a TBN search on "thermistor".
Doing a search I find the 10 series does not use a thermistor, after pulling my fuse block I agree. I could not find one. Solenoid clicks when the key is turned on. Fuel filter? Thanks, Dennis
/ 4310 will not start #4
Always do the least invasive things first...and that would be the fuel filter...actually, if you have your manual, look for the water separator first. But you may as well buy the fuel filter too.
I have a 4400...quite a bit less electronics then your 4310, but I'm pretty sure (from TBN threads) that you do have a thermistor.
Since it's dark now, and you're on TBN...might as well do a TBN search for "4310 Starting Problems" and variations of that query.
2016 JCB 510-56 10000 LB Telehandler (A64047)
2016 JCB 510-56...
2022 EZ-GO ELITE...
2019 John Deere 4044M (A62177)
2019 John Deere...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
2016 Ford F-150 4x4 Pickup Truck (A61573)
2016 Ford F-150...
Reynolds 8CF Scraper (A64047)
Reynolds 8CF...
