Dry rotted tires
/ Dry rotted tires #1
1401rider
Member
Illinois
Yanmar 1401
Hello all,
I'm ready to replace the front tires of my 1401. Needless to say they are shot. I have looked around for 10" front tires and found not much to choose from besides the ribbed field tires for my tractor. I have found a few other tires, but they are rated at 375lbs each. Anyone have an opinion if these would be too week for my tractor. I have found the tractor specs showing the the tractor to be approx. 1080lbs. By the way, the tractor is a 2wd. Also I have considered getting 12 inch front wheel/trailer tires to replace my originals. Does anyone have any idea what bolt pattern I would need ?
I know this is the place to ask and appriciate any help on the matter.
/ Dry rotted tires
The tires that are on the front now are 4.5-10. Figures I would forget to add that to my own post lol. The tire I end up replacing those with can't be too wide or they wont clear the front axel frame.
/ Dry rotted tires #4
The bolt pattern is metric,and there is probably some other Yanmar model that uses 12" that would fit? The only other option that I can think of,would be to get a set of 12x7" rims and tires from Hoye.On the home page,at the bottom of the left side,they have a list of what size tires fit what.
/ Dry rotted tires #5
when i switched my 1602 to turfs, i went through jdparts and found the exact size i needed. so many deeres are built with yanmar insides that i was able to find many different choices of rims for my tractors.
/ Dry rotted tires
I will have to check out the jd parts list and see what they have. Its funny how I thought I could just find a 10 inch trailer tire to put on my 1401 and be finished with it. I think the 12" tires are easier to deal with. I'm still considering the ones I found, but still a little shy because of the 375 lb load ratings. I will have to look a bit more before I decide.
/ Dry rotted tires #7
Are you looking for a lesser expensive tire than the AG tire? or are you simply looking at other choice options? there is a car tires size 165.70.10" that will fit size rim between 4.5-5.5 width and is under 20" tall, has a weight load of 783 lbs. although this tire is pricey @ 100+ each,
there is also a trailer tire size 205.65.10" that has a weight load of 1100 lbs. although tire width is 8" and I think would be too wide for the rim,
do you know the weight load of your existing tires ( AG ) tires? I think you'll find that they are only rated at or around 400 lbs, each...
so if you find an inexpensive lightweight trailer tire that has a rating of 375 lbs. if you were to use an inner tube this could give a little more weight capacity, ;)
do you have a FEL on the tractor?
There has been mentioned using a 12" wheel/tire .... I removed the pair from my tractor when I upgrade to a larger wheel/tire... I been holding onto them just in-case these larger wheels didn't pan out, although after now using them for a couple months all seems to be good, so I might be willing to sale the 12" wheel/tires although they are the ribbed AG tires and you might be trying to get away from these type:confused:
/ Dry rotted tires
deepNdirt I want to thank you for your reply. My tractor doesn't have a FEL on it. I really don't need heavy duty tires for the front. I just need reasonable priced replacements for the old ones. I did find some online that are 4.0-10 lug tires. A little narrower than mine are now but they should fit my rims. They are the ones rated at 375lbs each with 4 ply. I was skiddish because of the weight ratings. I had no idea the ones I have now " AG ribbed" would possibly be rated around 400. I'm not hard on the tractor and mainly use it to blade snow and I have a carryall for moving heavy items. I realize the more weight on the back equals a lighter front end. Perhaps im a little too cautious but I hate the idea of blowing a tire. As I said on my earlier post, I know this is the place to ask just about any question I would have.
/ Dry rotted tires
Just out of curiosity, I was wondering if any other owners of the YM1401 or 1301 replaced their front tires and what did they replace them with ?
/ Dry rotted tires
Found tires on the internet and replaced the old ones today. Here's a pic of the old and the new. Old Tires.jpg
/ Dry rotted tires #11
Those were pricy i bet and probably a bit more rolling resistance! But look cool! Just wondering why not just put tubes in the olds and been done with it. There are plenty of old tractors with dy rotted tires on them. With out a loader to be relly unstable at a bad time if one blew you really should have no worries. The worst thing is that one blows out while your plowing or cutting and have to wait till the next week to fix it, right? The fastest my ym2000 goes is like 10mph or less i think. If i blow at that speed i hardly think i will loose control or anything, and i only go that fast on pavement. Im at the most maybe 2/3 that speed doing anything else.
/ Dry rotted tires
They really were not that bad price wise. My old tires were coming apart literally. The sidewall was cut by a stem while hauling some logs this summer. It appears the tire pinched a hole in the tube causing a slow leak. I was able to patch and use the old tube with the new tires though. The tubes themselves looked to be in good shape except for the small hole. These are 4 ply and rated at 375 lbs. each. I was hesitant about trying these out at first because of the load rating. After installing them I think there is nothing to worry about.
/ Dry rotted tires #13
Yea cause what did you say tractor weighs? I lookes 1100lbs! So if you split that your only looking at 550 lbs in the front and probably there is less than that the witht distributin is prolly more like 60/40 or 65/35 back to front. That would leave you 200lbs till the capacity for front ballast, and like you said once you have an implement in the air the front lightens up. I would not worry myself! Like you have figured out.
/ Dry rotted tires
Yes, I think I will be ok with the tire ratings. The way I figure it I can't go wrong with doing a little research with the experts on this website. I'm not sure about your Yanny, but it doesn't take much to pull the front end up with any weight at all in the back. At this time I only have an extra 50lbs of weight up front bolted under the bumper. It helps a little but my brother inlaw has sprawled across the hood several times while I was moving stumps with my carryall, just to keep the front wheels down.
/ Dry rotted tires #15
I have about 175#s up front bolted to the bumper. And at about 550ish on the back the front gets light. Im thinking about another 100-150 is when it bout starts to become neutral with out much weight
/ Dry rotted tires
If I can figure how to bolt my brother inlaw to the front I think I may have my light front end problems solved. But then again, I might have to start all over again and find heavy duty tires for the front. I would be starting from scratch wouldn't I ? :)
2014 FREIGHTLINER CASCADIA 113 S/A DAY CAB TRUCK TRACTOR (A69167)
2014 FREIGHTLINER...
2025 KOMATSU PC130LC-11 EXCAVATOR (A65056)
2025 KOMATSU...
Set of 4 Unused ST205/75R15 Radial Trailer Tires (A66734)
Set of 4 Unused...
1998 CHEVROLET C7500 (INOPERABLE) (A67714)
1998 CHEVROLET...
2016 FREIGHTLINER CORONADO 122 SD (A67714)
2016 FREIGHTLINER...
2007 AMERITRAIL  GOOSENECK TRAILER (A67714)
2007 AMERITRAIL...
