Chain Storage and Front Tie-downs
/ Chain Storage and Front Tie-downs #1
wirenut
Summit, MS
Mahindra 5035, MF250, New Holland LS190, JD Gator 6x4
I love my Mahindra 5035, but one thing I don't like about the compact frame size, is the lack of storage space. Also, as one poster noted, a lack of tie-downs for trailering or strong pulling points on the front.
My solution was to make a extra heavy duty open top "box", welded to the frame rails. This gives me a place for several chains, shackles, etc. It also gives me a place for tie-downs and/or trailer ball. Of course, it is "overkill", but wanted to cover all bases, using what I had on hand. Would liked to have added a 2" receiver, but it would not work with the FEL.
/ Chain Storage and Front Tie-downs #2
I will be looking at my LS tomorrow. I have a chain box on the back, but I still have more chains.
/ Chain Storage and Front Tie-downs #3
I don't think there is anything "overkill" when it comes to a tractor. Nice job.
What is the bottom made of and how will water drain out?
Clem
Clem
The bottom is a piece of 10" channel, sides welded to the frame rails are 1/2" plate. I drilled 4 holes in the bottom corners for drain. As it turned out, it holds a lot more chains than I expected. I had built a similar one on my old MF250 tractor.
/ Chain Storage and Front Tie-downs #5
It is certainly a good idea. Look for it on new tractors eventually. I would call it a "selling point."
/ Chain Storage and Front Tie-downs #6
I have an MF 1250 so I will look to see if I can replicate what you have done here.
Thanks for sharing.
Clem
/ Chain Storage and Front Tie-downs #7
Not really enough access on my LS to do it easy. The frame ends too short. Could maybe do it and have a small reach-in on the right side. Since my bucket reaches quite far out front when lowered, I am going to mount an 8,000 lb. Warn winch on the lower front of the brush guard. Maybe I can make a box under that when I do it.
Soil-Max Gold Digger (A64126)
Soil-Max Gold...
1998 Volvo VNL64T Sleeper Truck (A62679)
1998 Volvo VNL64T...
CrusterBuster 4000 Grain Drill (A63688)
CrusterBuster 4000...
PREVIEW DATES AND TIMES (A65563)
PREVIEW DATES AND...
UNUSED WOLVERINE UNIVERSAL MOUNTING PLATE (A64281)
UNUSED WOLVERINE...
New/Unused AGT Industrial SDA-140T Track Loader (A65583)
New/Unused AGT...
