CT 440 Brush Hog size?
/ CT 440 Brush Hog size? #1
powergod1
rolla missouri
bobcat 440
I have a 72" flail mower that I use but would like to get a wider brush hog also for general mowing mainly grass it does get thick at times. Just wondering how wide could/should I go? have seen some nice correctly priced 10-15 ft mowers. Just dont want to buy something that is to big to handle
/ CT 440 Brush Hog size? #2
A 7' model like the Woods BB84X would be a nice match for your needs. Here is a link to the spec sheet:
Woods Equipment Company - BrushBull Extreme Standard-Duty Rotary Cutters
Personally I would limit it to a 6' model for use on brushy areas. A 7' would be fine if you're primarily maintenance mowing in grassy areas. Any bigger would be more than your tractor will want. That's my .02.
/ CT 440 Brush Hog size? #3
You may want to also check out my web page and click on the used,demo,close out link. There is a twin spindle Land pride 1884 cutter in there at a real steal of a deal!
I will also ship it to you.;)
/ CT 440 Brush Hog size? #4
Bobcat makes a 72" Slip Clutch and Shear Bolt unit... Check out your Bobcat dealer he might be able to get you a good deal on one... I have a 72" Slip Clutch on my CT335 and it works great!
PM sent to you
/ CT 440 Brush Hog size? #6
Whats the difference betwn slip clutch and the regular. I got a 72" with my 440 and it doesn't cut worth a durn. I personally don't like it. My previous 335 had the 60" and that sucker was SOLID and cut well. This 72" is not near well built as the 60"
T/A Enclosed Trailer 16ft (A61569)
T/A Enclosed...
UNUSED KJ 12'X20' SINGLE GARAGE METAL SHED (A62131)
UNUSED KJ 12'X20'...
36 Gallon RV Septic Caddy (A61166)
36 Gallon RV...
2012 John Deere 1790 Planter (A63109)
2012 John Deere...
2012 Caterpillar 924K Articulated Wheel Loader (A61567)
2012 Caterpillar...
UNUSED RAYTREE AMBD72S-72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
